October 29, 200917 yr comment_290243 Like a maroon, I'm getting the itch to ditch my highly enjoyable and convenient active Quads for some passive P3ESRs. This means I'll need an outboard amp, which is going to be a tight fit on my already-overloaded desk. So I guess I'm looking for suggestions on amps that are modestly sized and modestly powered and might have modest synergy with the Harbeths -- which are a 6 ohm load and 84dB sensitive and will be used in the very nearfield. There are a couple of Class D options which obviously fit the form factor -- Headroom, Bel Canto S300 -- but I'm not sure about the sonics. An Aleph 3 would work, but might just burn its way through to freedom. I nearly pulled the trigger on an Ayre V-3, but realized sadly that 18"*15" and 55lbs does not really a desktop amp make. Toob options I know next to nothing about. Open to any and all input*. Thanks. (* So's your Mom etc. etc.) Report
October 29, 200917 yr comment_290245 All I can say is I'm glad your wife makes lots of money Linn LK-100? Edited October 29, 200917 yr by Dreadhead Report
October 29, 200917 yr comment_290246 Oddly enough Quad is another option. Also Cyrus. Edited October 29, 200917 yr by swt61 Report
October 29, 200917 yr comment_290249 simplese is what you need Too bad it's already sold*. *not to Stretch Report
October 29, 200917 yr Author comment_290250 ^^^ See, I knew that. Chris, I did see an older LK-280 going pretty cheap recently. I've never heard any Linn stuff, though. Report
October 29, 200917 yr comment_290253 Seriously Stretch, I think a key to this is to get the amp off the desk. Report
October 29, 200917 yr Author comment_290256 You're just looking to sell some more 25ft custom interconnects! Hmm, Quad 99. Report
October 29, 200917 yr comment_290259 ^^^ See, I knew that. Chris, I did see an older LK-280 going pretty cheap recently. I've never heard any Linn stuff, though. I have a Linn Classik for my speakers and really like it and think it does detail well. I am no speaker expert though and my room is far from ideal. I think they are fairly well respected. I have not been able to determine what class (A, A/B etc) they are though. Report
October 29, 200917 yr comment_290260 Monarchy SM-70 Pro .... runs hot .... but very compact 1/2 size chassis and great sound from the single ended, zero feedback, Class A, MOSFET design. Monarchy Audio Report
October 29, 200917 yr comment_290261 How much power do you need? There's the Exposure 2010S integrated which has a few solid positive reviews and isn't too expensive either at $1.1K. Or if you just need a power amp, you could try maybe the Parasound Halo A23. Report
October 29, 200917 yr comment_290263 W4S ST-250 Stereo (ST-250) - Stereo Amplifiers - WYRED 4 SOUND the comparative d-sonic model is probably cheaper but the the wyred4sound stuff does look nicer Report
October 29, 200917 yr comment_290264 Quad 77 integrated, 77 power or 99 stereo. 77 is prettier, 99 has a bit more power. The 909 is also surprisingly compact. Report
October 29, 200917 yr comment_290265 Monarchy SM-70 Pro .... runs hot .... but very compact 1/2 size chassis and great sound from the single ended, zero feedback, Class A, MOSFET design. Monarchy Audio AudiogoN ForSale: Monarchy SM-70 That one isn't even that far from you Stretch. Report
October 29, 200917 yr comment_290268 Small, light, lots of power. AudiogoN ForSale: Peachtree Audio Nova Piano Black Another if you want all SS look for a used LFD int. they are really great with the Harbeths. Or are you just wanting a stereo amp and have your preamp already. The Quads 99s come up pretty often for under $400.00 on Agon. Report
October 29, 200917 yr comment_290279 be a man and get one of those stonking great Thresholds and help support Nate while you're at it! Report
October 29, 200917 yr comment_290296 Are we talking integrated, or power amp? Musical Fidelity XT100 (if you can find one)?Like a maroon, I'm getting the itch to ditch my highly enjoyable and convenient active Quads for some passive P3ESRs. May I be the first to say: DON'T DEW ET! And if you do, and after you compare the two, and decide to stay that way, sell me your active quads. I want to put together a surround system in the office. Say, winter/spring 2010? Report
October 29, 200917 yr comment_290324 X3 on the Monarchy. I'd forgotten about them. Also Nuforce. Report
October 29, 200917 yr comment_290328 How about this: AudiogoN ForSale: McCormack Micro Power Drive Seller has two listed. If one isn't enough juice you could run them mono. Report
October 29, 200917 yr comment_290329 I do quite like my HeadRoom monoblocs with my Harbeths, and they are nice and compact. Report
October 29, 200917 yr comment_290336 I do quite like my HeadRoom monoblocs with my Harbeths, and they are nice and compact. Shill! Report
October 29, 200917 yr comment_290338 Aren't I supposed to get something from HR or Tyll for shilling? I've never gotten anything more from them than a HeadRoom mug with some good bourbon in it. Come to think of it, that was some pretty good bourbon! Hey, maybe I am a shill. Report
October 30, 200917 yr comment_290360 And if you do, and after you compare the two, and decide to stay that way, sell me your active quads. I want to put together a surround system in the office. Say, winter/spring 2010?You stay the hell away from mah QUADs!!1 I do quite like my HeadRoom monoblocs with my Harbeths, and they are nice and compact. And if you wanted even more compact you wouldn't have to get the monoblocks. One of the 2ch amps would probably do nicely too. Report
October 30, 200917 yr Author comment_290362 Did I not mention they were already spoken for? Thanks all for the suggestions. Much to chew on. Like, if Harbeths are all about mids and Quad amps are all about mids, will the combo blow just the middle of my head off? Incidentally, I did a little experiment this week and only listened to the 12Ls, no headphones at all. Speakers are still moar better. Report
