Damn, just ordered most of the parts (everything minus transistors which are coming from AMB) for my Dynalo + Sigma 22 build. It was surprisingly tiring! I can't imagine ordering parts for the more advanced builds. Must be a many day affair.
I should be able to get that thing together by this weekend. Assuming I don't mess anything up too badly.
  • Replies 1.5k
  • Views 455.2k
  • Craig Sawyers
    Craig Sawyers
A few beginner questions-
1. Is there any advantage in using dual pole mains switches?
2. When soldering through hole parts onto a both-sides-plated PCB is it important to have neat concave solder spots on both sides?
3. If some parts happen to stand quite high from the PCB, should I make an effort to push them as close to the plate as possible? Some of my Dynalo resistors are standing unevenly and frankly I hate how that looks. Common sense tells me that doing so may minimize signal path.
2. Apply some flux to the join, (I use a flux pen), heat the join up sufficiently (approx 2 sec) before applying solder. You should have a nice smooth neat concave join on both sides of the PCB.
Not super important but something to aim for, the success rate gets higher with practice.
1) Depends on whether one side of your mains is grounded or not. But generally it is a good
idea to have a dual pole switch because that is the world standard. Its all about safety.
Ok, I'll try to apply the flux more often.
Scratch the switch question. I might have an idea how to do an amp with a switch that's beyond awesome (yet slightly impractical and most probably toxic).
Does anyone know of a source for a panel mount 3.5mm TRS jack that can mount in a thick panel? They make these in 1/4" for guitars, but I have been unable to come up with a smaller one.
How thick of a panel?
Have you thought about using something like this?
http://m.markertek.com/product/detail/http:%7C%7Cwww.markertek.com%7Cmobile%7CConnectors-Adapters%7CAudio-Connectors%7C3-5-2-5mm-Mini-Connectors%7CConnectronics%7CTN-MFS.xhtml
The jack itself is most likely threaded for attaching into the shell. Remove the shell, tap the panel appropriately, screw it directly into the panel. Perhaps a dab of loctite to keep it secure.
Just a thought....
Anyone know of a reputable source for FQA19N20C/FQA12P20?
I am looking for a quad to build an F5 and having trouble sourcing these (or at least sourcing parts that have a better than average chance of being real).
Is this too good to be true?
http://www.ebay.com/itm/50pair-OR-100PCS-Transistor-TOSHIBA-TO92-2SA1015-GR-2SC1815-GR-A1015-GR-C1815-GR-/270978998458?pt=LH_DefaultDomain_0&hash=item3f179b60ba
My local suppliers are almost out of these transistors. And the ones I got so far from them seem to be somewhat unstable.
The picture looks fine (from what I remember). For $3, you aren't risking much. Test them for sure.
Edited by Pars
I'm pretty sure this is how this business works. If shipping won't be too long then I'll bite.
Edit: Damn, shipping is more than two weeks. I'll pass. One of the local guys had bad luck with this seller.
Edited by RudeWolf
Let me see what I have laying around...
I don't know what shipping would be like, but Mouser has the Fairchild version of these for 7 cents apiece, or 3.7 cents in 100. Unfortunately, they don't have the GR grade in the C1815 NPN.
http://www.mouser.com/ProductDetail/Fairchild-Semiconductor/KSA1015YTA/?qs=ljbEvF4DwONgdKizIuxI5UKMGOiR5dCFrGZORl6qhPg%3d
http://www.mouser.com/ProductDetail/Fairchild-Semiconductor/KSC1815YTA/?qs=ljbEvF4DwOPz7O2KUMOsr34RMcYiO0wN
MCM has them for 5 cents:
http://www.mcmelectronics.com/product/2SA1015
http://www.mcmelectronics.com/product/2SC1815
For the Dynalo circuit would there be any meaningful difference between GR and YTA designations?
Probably not. GR would be preferred because of the higher hFe (not sure why)?
Note: hFE (1) classification O: 70~140, Y: 120~240, GR: 200~400
Not sure who the preferred Euro suppliers are. I see Dalbani has them in GR:
http://www.dalbani.com/CGI-BIN/LANSAWEB?WEBEVENT+L062A634E589221006B28003+M36+ENG
Edited by Pars
My preferred suppliers would be Farnell and Elfa Distrelec but none of them seem to carry it.
As I said two of the local electronics stores have them but I have a bad feeling that they get them from ebay. Some of the local diy-ers who bought transistors from them got fakes.
In any case I'm in progress of doing a full transistor test on my Dynalo.
anyone knows where to get 512-KBU4M (Fairchild Bridge Rectifier)? it's non-stocked on both mouser and digikey and will only be shipped at >200.
I was going to use the Vishay alternative 625-KBU4M-E4, and it was in-stock when I checked few days ago, but now it's 7 weeks backordered. comp26.gif
