January 28, 200917 yr comment_200705 How long do/did your ESP950 drivers take to charge up to full volume with Stax and Koss amps? Report
January 28, 200917 yr comment_200729 How long do/did your ESP950 drivers take to charge up to full volume with Stax and Koss amps? Instantly, but IMO it always sounds best with a little warm-up of the amp. Report
January 28, 200917 yr comment_200876 I get full volume out of the ESP/950 using either the E/90 or the SRM-1/mk2 about a second after I hit the power switch. Report
January 28, 200917 yr comment_200891 The diaphragm should charge up instantly or there is something wrong. Amp warm up is another matter though. Report
January 28, 200917 yr comment_200984 Electrostatics that haven't been used for many years take longer to charge up, though. My SR-5NB took about 15 seconds when I first got it, now it takes about one. I still don't know what the hell is going on with my ESP10, though. spritzer, if the channels are reversed when I fool around with balance control does that mean I wired it wrong? Could it just be that the foam inside disintegrated and is shorting things? Report
January 29, 200917 yr comment_200995 Well, I mentioned previously to Spritzer after I got them that the APS modded ESP950 he sold me take 2-3 minutes to fully charge, and for the first 4-5 seconds the are silent. Both drivers charge equally slow, and after several minutes they are both loud and strong and normal volume. No imbalance, but none of my other stats take minutes to charge, and they've been like this for as long as I've had them. I'm afraid to send them to Koss because I worry they will undo the APS cable and dampening mods. Report
January 29, 200917 yr comment_201065 Justin posted an update on his Web site today - 3 weeks until the first BHSEs ship! And he posted more pics here: HeadAmp - Audio Electronics (Blue Hawaii SE Electrostatic Headphone Amp) Report
January 29, 200917 yr comment_201066 That can't be right. There aren't any wall warts in the power supply. Report
January 29, 200917 yr comment_201073 Does Accutech ever respond to emails? They did for me in May when I was asking them how much an arc assembly would cost. Report
January 29, 200917 yr comment_201075 They did for me in May when I was asking them how much an arc assembly would cost. One of my exact questions to them. What phone was it for and how much? Report
January 29, 200917 yr comment_201078 I wanted it for my SR-Lambda, so it was for the SR-202 arc assembly. They said the SR-303/404 arc assemblies are more expensive. Here is their first email response to me: Hi Justin, Thank you for your inquiry and your support of STAX audio products. The original SR-Lambda arc headband assembly has been discontinued and substitute are available and they are $100 for the assembly. Please contact us at 310-324-7406 to provide payment information or please fill out the attached credit card form and fax back to 310-324-7422. Should you have any questions, please contact us again. Best Regards, YEI / ACCUTECH Yama's Enterprises, Inc. Importers of Fine Audio products Here is their second: Hi Justin, The substitute replace part would be from SR-202, the only black color headband available. Other colors (olive green & brown) are available and slightly higher in price. The newer assembly Report
January 29, 200917 yr comment_201087 I still don't know what the hell is going on with my ESP10, though. spritzer, if the channels are reversed when I fool around with balance control does that mean I wired it wrong? Could it just be that the foam inside disintegrated and is shorting things? Can you show me how you wired it? It's been well over a year but I'm certain that the stock Koss cable can't be rewired for Stax duty without cutting off the plug. I would remove the foam and replace it with anything you have handy. The major damping is done by the felt pads at the back of the driver. You could also swap the foam for wool and line the crappy enclosure with bitumen. Justin posted an update on his Web site today - 3 weeks until the first BHSEs ship! And he posted more pics here: HeadAmp - Audio Electronics (Blue Hawaii SE Electrostatic Headphone Amp) Brilliant news to say the least!!! Report
February 1, 200917 yr comment_202035 I finally figured out what I wired incorrectly. I swapped the bottom two wires, bias and R- or something. I'm definitely with you on the crappy enclosure. Everything sounds like I'm in a cave. It's even worse than a stock K340 with cotton removed. I took out the disintegrating crappy foam because every time I opened the cups up more of it broke off. I'm going to upgrade the caps later on top of redamping or whatever it is I need to do. Report
February 1, 200917 yr comment_202055 I think I might be dumber than I thought, which is not a surprise. The channels are still reversed. At least there isn't any distortion... everything still sounds cavernous, though. Report
February 2, 200917 yr comment_202288 Someone in NYC needs to have a go at these: STAX ELS F8 rare electrostatic speakers - eBay (item 150324182082 end time Feb-06-09 17:58:00 PST) Report
February 2, 200917 yr comment_202289 What's the going price of the Normal-bias SR-Lambda (by itself) these days? I did some Google (and HF) searching but didn't turn up anything other than a general ballpark of somewhere <$200. Report
February 2, 200917 yr comment_202291 Someone in NYC needs to have a go at these: STAX ELS F8 rare electrostatic speakers - eBay (item 150324182082 end time Feb-06-09 17:58:00 PST) I had an opportunity to pick up a working pair of F81s for similar price and did not as I did not like how they sound. Report
February 2, 200917 yr comment_202300 I had an opportunity to pick up a working pair of F81s for similar price and did not as I did not like how they sound. If you don't mind, how did they sound? Stax speakers intrigue me. Report
February 2, 200917 yr comment_202322 Anyone for a Sigma? [url=http://cgi.ebay.fr/CASQUE-ELECTRODYNAMIQUE-STAX-SR-SIGMA-AMPLI-SRD-X_W0QQitemZ190283547571QQcmdZViewItemQQptZFR_LC_TV_Son_Home_Cinema_Accessoires_Image_Son_Casques_Ecouteurs?hash=item190283547571&_trksid=p3286.c0.m14&_trkparms=72%3A1526|66%3A2|65%3A12|39%3A1|240%3A1318]CASQUE ELECTRODYNAMIQUE STAX SR SIGMA + AMPLI SRD-X en vente sur eBay.fr (fin le 09-f Report
February 2, 200917 yr comment_202360 Anyone ever modify a SRM-1/mk2 for 620v bias, or even sketch out a schematic for the stock bias supply? Report
February 2, 200917 yr comment_202363 Anyone ever modify a SRM-1/mk2 for 620v bias, or even sketch out a schematic for the stock bias supply? I think I may have a schematic somewhere.. I'll check tonite. Report
