September 13, 201511 yr comment_703147 The AC in your house could be causing that or the transformer just has a bit of hum. Some do, some don't. Report
September 13, 201511 yr comment_703154 The AC in your house could be causing that or the transformer just has a bit of hum. Some do, some don't. Thanks spritzer. It used to be silent but at this point must go under the desk. Report
September 14, 201511 yr comment_703212 Did you add any new stuff to that mains wiring? Computers, chargers, that type of thing? They could be causing the hum. Report
September 14, 201511 yr comment_703217 Did you add any new stuff to that mains wiring? Computers, chargers, that type of thing? They could be causing the hum. There's a new line interactive UPS for a PC that is sharing the same circuit. However, that video was made from a different room which may or may not be in the same circuit as the office. I'll try a mass unplugging of devices including the UPS. Edit: No joy I'm afraid Edited September 14, 201511 yr by dripf Report
September 14, 201511 yr comment_703226 I really don't see any other reason why the transformer would suddenly start to misbehave unless it is simply failing. I take it is set to the correct voltage and not say a 100V unit plugged into 117V or something like that? Polarity of the mains can also be a factor if the plug is reversible. Report
September 14, 201511 yr comment_703230 The 323S is PJ sourced and powered by a 240-100 V transformer. I asked on H-F and the one respondent thought it was a case of delamination that was benign. Report
September 15, 201511 yr comment_703270 Doesn't Stax put a sticky rubber dampener between the transformer and chassis to minimize noise? Maybe it came loose. Edited September 15, 201511 yr by n3rdling Report
September 16, 201511 yr comment_703401 009 take on the lamda driver? maybe it'll help some of the low end Report
September 16, 201511 yr comment_703403 Now somebody is speaking the right language. Interesting, Isn't that funny, Sr 50"8" Edited September 16, 201511 yr by Hennyo Report
September 16, 201511 yr comment_703406 I thought that's what the 009 did under the hoodhopefully only 1k or so for a pair, somewhere between the 507 and omega Report
September 16, 201511 yr comment_703411 The problem with the Lambda has never been the drivers but the housing. We'll see if they ever change that... Report
September 16, 201511 yr comment_703420 Here's a link to a picture of the SRD7SB Prohttp://stereonomono.blogspot.com/2014_09_01_archive.htmlNope. SRD-7/SBmk2, and AC-Powered SRD-7 Pro.Ali Report
September 16, 201511 yr comment_703422 The problem with the Lambda has never been the drivers but the housing. We'll see if they ever change that...Lambda drivers + Orpheus housing, for instance ? Ali Report
September 16, 201511 yr comment_703432 I would like a Lambda that doesn't suck, mainly for more casual listening than the 007. The 007 is great but the finnicky fit and comfort aren't ideal. If I can get a Lambda that isn't brighter than a bus full of MIT students and still has that airy open thing going on that would be great. Also provided it doesn't cost an arm and a leg. Report
September 16, 201511 yr comment_703433 Lambda drivers + Orpheus housing, for instance ? AliYup. Report
September 16, 201511 yr comment_703444 It'd be a long time before we actually see a production release of a specific model. They had a new amp at one of the Tokyo shows 3 years ago and no word of it since. Edited September 16, 201511 yr by DefQon Report
September 17, 201511 yr comment_703497 Looks like a "basic" stiffening of the stators, they could easily stick that in a SR-507 housing and call it SR-509. I say "basic", but maybe some wachara-level dude would tell I've no clue about it Ali Report
September 19, 201511 yr comment_703750 This is a ridiculous post i know. But after lots of electrostatic listenening I can't stand to hear normal speakers anymore. They're too boring and I need to take a break.Somehow this doesn't happen with the SR-X MKIII. I just really enjoy listening to them. I put velour pads on my SR-X MKIII and I can happily listen to them all day long now.I just wish I could find a way to make my speaker cables sit in the shitty SRD-7 wire terminal easier. A speaker wire falls out on occasion. I'm absolutely not going to be one of those people who chops off the cable receptacle...Anyone who has a SRD-7/SB they don't want should let me know, It would be nice to have one without a power cord Hands down I'll take a SR-X MK III and SRD-7 over any other Stax I've heard to date... Edit: Finally worked up the courage to wash off the headband with a damp cloth with shampoo and another damp cloth to wipe away leftover soap. Yeesh, glad I did. These headphones really showed their age on that paper towel Edited September 19, 201511 yr by 4tray Report
September 19, 201511 yr comment_703756 Given a choice between an original BH and KGST (400v if it makes much of a difference) is there any consensus on which would play best with the 007/009, SR-Ω & HE60? Hard enough to find someone who has heard one of the dozen or so Headamp BH's out there, let alone a comparison with any of the subsequent KG amps. Edited September 19, 201511 yr by ericfarrell85 Report
September 20, 201511 yr comment_703785 DIY T2Pipe-dreaming is the closest I'll get to a T2 (that or if Andy decides he doesn't like his any more). BH and KGST/HV seem to be the only procurable options. Report
September 20, 201511 yr comment_703794 nothing wrong with the kgst to cover the 009 corner case you'd probably need to audition that on the bh to compare Report
