The issue with any Omega is that they are not that well built so you never know what you are going to get.  Some are just fine while others have issues, you can see that with the discussion about different serial ranges sounding different.  Now I've owned 30+ units over the years and when they work as they should... they all sound the same.  If the "grounding resistors" have broken down internally, internal frame issues, micro cracks in the stator supports and other issues... they will sound different but that's because they are slowly failing and need to be fixed.  It's similar to tube rolling while not actually using tubes with similar specs... true shock that they sound different.  :palm:
Those are some nice Omega clones.  Where are those from?
I tried to buy them but without success
same story with Chinsettawong Omega or Orpheus or JF
I was looking for them for several years and everyone I talked to didn't want to sell them
https://www.head-case.org/forums/topic/21643-a-diy-shangri-la-headphone-for-hifi-xmen/
same story with any of these headphones
they are simply impossible to buy anywhere
Wow, they've made replicas also for Stax... What a life's today's life!
41 minutes ago, skullguise said:
I like the DAC discussed in the P-F article!  Looks like it'll be about $12K USD though......
Nelson Pass apparently mentioned it at Burning Amp last weekend. I wasn't there so don't know what he said about it, but the insinuation was that he was favorably impressed by it.
  • Like 1
I like them a lot and they are technically proficient but lately I've been a bit off on ported designs as they lack involvement to me.  Not enough engagement compared to the greats but, not nearly as bad as the Hifiman Shangri-la mini where the sound just hangs there.  I've been meaning to make a proper review of them but this year as a whole has just sucked.
This has to be the week of stupid mods, cue this 727 in for full surgery and mods.  Nothing abnormal on top but below I find this:
Hmmm not quite stock that input wiring
In and output wires from the volume pot were simply cut and this new monstrosity was sliced into ends.  The plan was clearly to bypass the volume control but this is a 727... which has a switch to turn off the volume control and bypass it!!  Just flip the switch the volume control does nothing...  fucking hell...
One more thing, can anybody make heads or tales of this monstrosity?
That's two three conductor cables, basic mic cable would do the job but why set it up like this?  Each conductor is screened and they are bridging it ever 10cm or so for moar cancellation?  Ground for your ground... for your ground?
Also, I'm not truly prepared for the 727 to be almost 20 years old at this point.  The caps in this one had a date code from early 2007.  :kitty:
  • Confused 2
  • Sad 1
Time is sneaky.
sorry this is my fault, we were using it as a prop for a Cronenberg film....
  • Haha 3
I'm slowly working on replacements but nothing that is ready for release yet.
The Dekoni pads are well made but I wouldn't pick those as they are too big and I'd never use fenestrated pads due to the air leaks.  You'd ideally want 105mm pads with a fairly large opening and there aren't all that many out there off the shelf.
  • Like 1
On 6/20/2025 at 1:11 PM, bwck2000 said:
It is interesting that the SR-007S is sharing the same OFC cable as the entry-level SR-X1, rather than the HiFC cable from Hitachi used in L300 / L500 let alone the silver plated ones.
So, after doing some experiments with a friend. I don't believe the 007S cable is the same OFC cable that the X1 has...
It has different colour paint lines on it now. And it sounds BRIGHTER than the L500 HiFC cable. Whereas the X1 OFC cable sounded a little warmer than the L500 cable.
With some other anecdotes: it is likely a SPC cable either the same or similar to the L700 cable.
It is also contributing to the 007S brightness up top. The L500 cable makes the 007S better.
Did the color change on the cables from the first release?  My first batch sets (X1, two of them and 007S) have identical cables in every way.
https://staxaudio.com/earspeaker/srs-x1
Maybe im wrong on the colour thing, this site shows a blue lined cable at the bottom. but that could just be an error.
My X1 also had the bronze painted cable.
But the strange thing is the sound....Unfortunately i sold my X1 so i cant compare to the 007S now.
If you have both, are you able to switch the cables and try?
I am going by the following:
1) I swapped X1 and L500mk2 cables and it was 100% sure , the L500 cable brought out a bit more in the upper trebles, and was a hint less bright
2) X1 is not present. but swapped 007S and L500mk2 cables onto the 007S, and the L500 cable was significantly less bright up top. Anecdotally there was an 007S X9000 owner in USA who swapped their cables and found they sounded the same.
I have both in front of me and they have identical cables.  The L500Mk2 has the old cable with the white line (the blue was just on the SR-L300) so that should be pure copper.
On that note, I've compared all the cables and there is no difference at all to my ears.  They all have the same specs that actually matter (capacitance) so they should all perform the same.
One update on my ailing SR-X1, I went in one last time and coated them again and that seems to have done the trick.  No imbalance at all and just some mild buzzing from the driver as some debris got in there.  I might go in and try to clean it but yeah... that's the good news.  Now for the bad one as I'm afraid the X1's are not long for this world.
So this was the first time I took the driver fully apart and whoever designed this needs to go and look at how Stax used to be made.  I've never seen them do this before but the diaphragm is only attached to one ring, not sandwiched between two of them.  So the spacers they use (also the insulation from the stators) are different from one side to the other.  The side with the metal ring is very thin indeed, probably 0.2mm or so.
I didn't want to snap a picture as the whole thing is so fragile but yeah, the diaphragm is hanging on 2-2.5mm or so of metal spacer and mine was already lifting off the ring as the PEEK seemingly doesn't adhere well to it.  I'm sure I didn't cause this and it is very worrying as they have so small a support for the film.  I have some SR-X NB diaphragms here and there they used 4mm spacers and glued on both sides for a much smaller diaphragm.  That means the films are still just fine after 50 years in service which I doubt will be case for the X1's.
I for one don't see an issue with gluing just one side as I do the same on my DIY drivers, but the contact area has to be bigger and mylar behaves differently to PEEK.  Right now this set works fine but I'll continue to monitor it and I'd like to know if anybody else has had these issues.
On 10/23/2025 at 10:12 PM, Kabeer said:
Great video for all you Stax fans. Very rare insight which actually shows proper parts of the factory
I finally got around to watching this and a few interesting bits, they are clearly still making 009 drivers as they were pulled out of a drawer in the soaking oven even through they are long out of production.  Odd that they don't swap them out with 009S drivers as they have done with every other model.
I did roll my eyes when only 30 X9000 drivers could be tested by one person... sure... why not
I found it interesting that they test the drivers like that, as the reflection off the table is surely messing up the test by loading one side of the driver differently.  I always thought they would slot them into jigs with microphones on each side as this way makes no sense to me.
Btw. I feel their museum severely lacking...  I know a few people who have a lot more Stax stuff in their collection than that.  ;D
  • Like 2
