The Headcase Stax thread
The issue with any Omega is that they are not that well built so you never know what you are going to get.  Some are just fine while others have issues, you can see that with the discussion about different serial ranges sounding different.  Now I've owned 30+ units over the years and when they work as they should... they all sound the same.  If the "grounding resistors" have broken down internally, internal frame issues, micro cracks in the stator supports and other issues... they will sound different but that's because they are slowly failing and need to be fixed.  It's similar to tube rolling while not actually using tubes with similar specs... true shock that they sound different.  :palm:
Those are some nice Omega clones.  Where are those from?
  • Replies 14.4k
  • Views 3.5m
  • bwck2000
    bwck2000
I tried to buy them but without success
same story with Chinsettawong Omega or Orpheus or JF
I was looking for them for several years and everyone I talked to didn't want to sell them
https://www.head-case.org/forums/topic/21643-a-diy-shangri-la-headphone-for-hifi-xmen/
same story with any of these headphones
they are simply impossible to buy anywhere
Wow, they've made replicas also for Stax... What a life's today's life!
I know these aren't Stax, but have any of you tried Audeze CRBN2 in lieu of the 007s? Bob Katz seems quite enamored with them using one of Birgir's Carbons as the amp. Kinda expensive, but not sure what 007s are running these days either.
https://positive-feedback.com/reviews/hardware-reviews/imersiv-d1-dac/
I like the DAC discussed in the P-F article!  Looks like it'll be about $12K USD though......
Nelson Pass apparently mentioned it at Burning Amp last weekend. I wasn't there so don't know what he said about it, but the insinuation was that he was favorably impressed by it.
I like them a lot and they are technically proficient but lately I've been a bit off on ported designs as they lack involvement to me.  Not enough engagement compared to the greats but, not nearly as bad as the Hifiman Shangri-la mini where the sound just hangs there.  I've been meaning to make a proper review of them but this year as a whole has just sucked.
This has to be the week of stupid mods, cue this 727 in for full surgery and mods.  Nothing abnormal on top but below I find this:
Hmmm not quite stock that input wiring
In and output wires from the volume pot were simply cut and this new monstrosity was sliced into ends.  The plan was clearly to bypass the volume control but this is a 727... which has a switch to turn off the volume control and bypass it!!  Just flip the switch the volume control does nothing...  fucking hell...
One more thing, can anybody make heads or tales of this monstrosity?
That's two three conductor cables, basic mic cable would do the job but why set it up like this?  Each conductor is screened and they are bridging it ever 10cm or so for moar cancellation?  Ground for your ground... for your ground?
Also, I'm not truly prepared for the 727 to be almost 20 years old at this point.  The caps in this one had a date code from early 2007.  :kitty:
Time is sneaky.
sorry this is my fault, we were using it as a prop for a Cronenberg film....
Great video for all you Stax fans. Very rare insight which actually shows proper parts of the factory
I'm slowly working on replacements but nothing that is ready for release yet.
The Dekoni pads are well made but I wouldn't pick those as they are too big and I'd never use fenestrated pads due to the air leaks.  You'd ideally want 105mm pads with a fairly large opening and there aren't all that many out there off the shelf.
On 6/20/2025 at 1:11 PM, bwck2000 said:
It is interesting that the SR-007S is sharing the same OFC cable as the entry-level SR-X1, rather than the HiFC cable from Hitachi used in L300 / L500 let alone the silver plated ones.
So, after doing some experiments with a friend. I don't believe the 007S cable is the same OFC cable that the X1 has...
It has different colour paint lines on it now. And it sounds BRIGHTER than the L500 HiFC cable. Whereas the X1 OFC cable sounded a little warmer than the L500 cable.
With some other anecdotes: it is likely a SPC cable either the same or similar to the L700 cable.
It is also contributing to the 007S brightness up top. The L500 cable makes the 007S better.
Did the color change on the cables from the first release?  My first batch sets (X1, two of them and 007S) have identical cables in every way.
https://staxaudio.com/earspeaker/srs-x1
Maybe im wrong on the colour thing, this site shows a blue lined cable at the bottom. but that could just be an error.
My X1 also had the bronze painted cable.
But the strange thing is the sound....Unfortunately i sold my X1 so i cant compare to the 007S now.
If you have both, are you able to switch the cables and try?
I am going by the following:
1) I swapped X1 and L500mk2 cables and it was 100% sure , the L500 cable brought out a bit more in the upper trebles, and was a hint less bright
2) X1 is not present. but swapped 007S and L500mk2 cables onto the 007S, and the L500 cable was significantly less bright up top. Anecdotally there was an 007S X9000 owner in USA who swapped their cables and found they sounded the same.
I have both in front of me and they have identical cables.  The L500Mk2 has the old cable with the white line (the blue was just on the SR-L300) so that should be pure copper.
On that note, I've compared all the cables and there is no difference at all to my ears.  They all have the same specs that actually matter (capacitance) so they should all perform the same.
One update on my ailing SR-X1, I went in one last time and coated them again and that seems to have done the trick.  No imbalance at all and just some mild buzzing from the driver as some debris got in there.  I might go in and try to clean it but yeah... that's the good news.  Now for the bad one as I'm afraid the X1's are not long for this world.
So this was the first time I took the driver fully apart and whoever designed this needs to go and look at how Stax used to be made.  I've never seen them do this before but the diaphragm is only attached to one ring, not sandwiched between two of them.  So the spacers they use (also the insulation from the stators) are different from one side to the other.  The side with the metal ring is very thin indeed, probably 0.2mm or so.
I didn't want to snap a picture as the whole thing is so fragile but yeah, the diaphragm is hanging on 2-2.5mm or so of metal spacer and mine was already lifting off the ring as the PEEK seemingly doesn't adhere well to it.  I'm sure I didn't cause this and it is very worrying as they have so small a support for the film.  I have some SR-X NB diaphragms here and there they used 4mm spacers and glued on both sides for a much smaller diaphragm.  That means the films are still just fine after 50 years in service which I doubt will be case for the X1's.
I for one don't see an issue with gluing just one side as I do the same on my DIY drivers, but the contact area has to be bigger and mylar behaves differently to PEEK.  Right now this set works fine but I'll continue to monitor it and I'd like to know if anybody else has had these issues.
I finally got around to watching this and a few interesting bits, they are clearly still making 009 drivers as they were pulled out of a drawer in the soaking oven even through they are long out of production.  Odd that they don't swap them out with 009S drivers as they have done with every other model.
I did roll my eyes when only 30 X9000 drivers could be tested by one person... sure... why not
I found it interesting that they test the drivers like that, as the reflection off the table is surely messing up the test by loading one side of the driver differently.  I always thought they would slot them into jigs with microphones on each side as this way makes no sense to me.
Btw. I feel their museum severely lacking...  I know a few people who have a lot more Stax stuff in their collection than that.  ;D
I heard that Stax is still producing some models called 009D or something similar, which feature black casings and replaceable cables, possibly custom-made for recording studios. The replaceable cable design should also be applied to the 009S in the future.
Interesting, the 009 cable entry surely can be adapted for that and it makes sense to make just one cable for everything.
Edit:  I've designed a new cable entry for the 009 project I'm working on but with a fixed cable as I have so many in stock.  The stock cable entry is a bit of a joke with that flimsy piece of plastic covering half of it.
Edited by spritzer
Mine's been working fine with daily use, but this is not encouraging. At least it's cheap enough that if it fails I can just get another one.
I would have replaced it with the EX-1a but I just don't want to pay orange man his tariffs.
I just checked them and the channel imbalance has drifted a bit but not as bad as they used to get which was completely dead.  I'm not sure why they are getting worse though, could be because the coating is too thick.  I could barely touch the diaphragm from fear it would rip off the ring completely.  I might go in again for a second try or just design new rings to hold the diaphragms.
The coating on the DIY sets seems to hold up just fine as I'm currently listening to the Senn HD600e and they are perfectly balanced.
The EX-1a is a great and there are still ways around those pesky tariffs for those so inclined...  ;)
In Stax related news, I just stretched my first ever SR-009 replacement diaphragms tonight.  I've already redesigned the spacers a bit but we'll see if these work for a first try.  New dust covers and a new way to mount the earpads too which doesn't take an hour to do.  These drivers were completely shot but I'll have to wait on some o-rings and screws to work any more on this project.
IMG_7475.jpegGo to post
NEW PRODUCT
New Product News – November 2025
STAX
SR-009D
electrostatic headphones
The pinnacle of high-end headphones – electrostatic headphones with detachable cable design, offering an even wider soundstage
We proudly announce the new flagship STAX model: **SR-009D**. The first model with a detachable cable structure, delivering further sound quality improvements. Compared to the previous SR-009S, it increases the amount of sonic information, enhances detail, and expands the soundstage. Equipped with the newly developed **MLER3** driver and a dedicated cable for the 000D, it achieves extreme transparency and resolution.
**■ MLER3 Driver (New)**
The newly developed **MLER3 (Multi Layer Electrodes 3)** driver was created exclusively for the SR-009D. Compared to the previous MLER2, it delivers more sonic information, improved detail, and a wider soundstage. The MLER3 features an enhanced electrode mounting method, ensuring more uniform diaphragm vibration and reducing distortion to an absolute minimum. This results in transparency and resolution that surpass previous models.
**■ Detachable Cable Support**
The SR-009D is the first STAX model to support cable replacement. It comes with a newly developed dedicated cable for the 000D. Cable swapping allows sound tuning and customization to personal preferences. Additional official STAX replacement cables will be released gradually.
**■ Launch Campaign (Until End of December 2025)**
All customers who purchase the **SR-009D** will receive the official **SPC-009** cable (retail value: ¥55,000 incl. tax) as a gift. Every buyer during the campaign period will receive the SPC-009 cable free of charge. Limited quantity – early reservation recommended.
**Campaign Gift:**
1.5 m official OFC headphone cable
**Specifications:**
- Type: Push-pull open-back electrostatic headphones
- Frequency Response: 5 Hz – 42,000 Hz
- Electrostatic Capacitance: 110 pF (including cable)
- Impedance: 145 kΩ (at 10 kHz, including cable)
- Sound Pressure Sensitivity: 101 dB / 100 V r.m.s. / 1 kHz
- Bias Voltage: DC 580 V
- Left/Right Indicators: L / R
- Ear Pads: Genuine leather (lambskin), partially synthetic leather
- Cable: 6-core parallel silver-coated 6N OFC + silver-coated copper wire
- Weight: 454 g (with cable) / 383 g (body only)
**STAX Co., Ltd.**
33-1 Honcho, Wako-shi, Saitama 351-0114, Japan
TEL: (048) 483-1801
FAX: (048) 293-1802
URL: https://www.stax.co.jp
are your ready for new 009D?
I'm curious about the pricing and how it compares to the ES-2a.
Looks to be 350KYen...
Funny they are going back to the silver electrodes and they look identical to the first ones I have sitting on my desk.  The plastic housing has been changed though
Edited by spritzer
