KGSSHV, Balanced Dynahi Rev A and DynaFET board run
  • Replies 448
  • Views 124.1k
  • Cool Package to Deepak seems to be affected by the hurricane... Got stuck in NY for the last 5 or 6 days already Hopefully he won't receive a soaking wet box.
  • Just got my boards. It's a bit startling just how much smaller the Exstata V2 amp boards are compared to the KGSSHV given that they were once identical...
Payment sent as well. Thanks for organizing the board run Hoa!
Payment sent.
THANK YOU VERY MUCH FOR DOING ALL OF THIS WORK!!!!!
Bạn là người đàn ông!
Can you mark me down for one more kgsshv psu board? Thanks. Will send payment upon response.
Done.
Looks like we are reaching the goal, there are only a few people left and I expect the list is fulfilled within a couple days.
I'll finalize the quantity and make an order tomorrow. Production should take 14-15 working days. I'll try to update to status in the spreadsheet as things go on.
Uhh, use FA as oppose to RA heatsink for 2.5 inch heatsink at mouser or wait til 19th for the aavid parts get restocked at digikey. 4170G might be too wide - 13.97mm width of the pads vs 12.7mm distance between the mounting holes. Its better to get 4171G at future electronics. FQPF8N80C available at mouser.
Edited by ujamerstand
Thanks. :) Made some changes. Didn't know why I missed the FQPF8N80C from Mouser...
Shouldn't we use terminal blocks on the amp boards? Or are we supposed to solder those directly to the input/output?
Terminal blocks indeed!
They sure made my life more bearable during multiple hooking-up/unhooking sessions
while testing and rebuilding my KGSSHV over and over. But then YMMV.
You may be one of the lucky ones who hooks em up once and is done with it. :P
Edited by livewire
is the LED in any way used for biasing, or simply for indication? if there is a required spec, what is it?
also, the amp lists the 180 ohm resistors twice (mouser 660-MF1/2CC1820F)
are the 1N914 diodes missing from the BOM, or are my gerber files really old?
Edited by El_Doug
Fixed those, thanks for the catch.
Sent payment. Thanks for the late add. :)
The list should be locked now, I can't take any more addition. :) Kerry got the last spare sets.
<snip>
I believe they do affect bias as they are in the same locations as the original KGSS amp.
These days KG specifies a 2.1 volt red LED in the BOM, sourced from Mouser.
Has there been any movement on a group buy for T2 style heatsinks? I remember seeing it mentioned in the KGSSHV thread, I think by El_Doug. If so I would definitely be interested
I would be interested in custom heat sinks for Modushop Pesante Dissipante for side mount amp boards. I guess one would be able to buy the case without those heat sinks later.
I definitely do not believe KG or Justin is interested in producing them.
no one wants to produce them, and they wouldn't work for the pessante case anyway
