What are you Grilling now?
Back when I did meat, I always liked to do St. Louis ribs in the oven, at very low temp.  Looks good to me, though, Mike.
  • Replies 891
  • Views 182.8k
  • I did sous vide picanha for the first time today. A simple rub of spices, smoked salt and olive oil, then cooked in the bath at 133F for 6 hours. The 'grill' part comes from very briefly finishing on
  • shellylh
    shellylh
    Having an infrared side burner on the grill is pretty fucking awesome. Thanks for the tip Marc. Indirect heat @225F for 30 minutes and then a 30 second sear per side on the infrared burner.
  • Smoked chuck roast. Much better than I expected. And a great excuse to use plenty of horseradish cream sauce.
Not seeing any negatives in those results! I would want to eat all that bark at once!
I note that you didn't bring any crackleftovers to Leelanau! I'm guessing it was too good for leftovers to remain.
How did your brisket work out?
Crack & Cheese paired very nicely with Makers Mark.  No left overs.  Difficult to compete with Yak and Alpaca :)
My first ever brisket, a flat.  Good bark, nice smoke ring, bursting with flavor, pulled apart perfectly but was a bit dry.  Most likely the meat.
I haven't grilled since we switched from charcoal to propane.  Back at it with the pellet pooper.  I'm having fun and some success.
Such red... like the vodka...
Churrasco. Brazilian bbk. Diaphragm flank steak, known here as entranha, or fraldinha do diafragma.
On 7/22/2017 at 6:57 PM, EdipisReks1 said:
Back when I did meat...
Sadly, many of my conversations now start exactly like this. :(
I kinda figured you'd have a comment on my comment.
Hey grillers, a Kroger in my area had the Char Broil Akorn Komado on sale for about two hundred bucks.  They had several, so I think it's worth checking out in your own area, if you have Kroger stores.  It's not a Green Egg, of course, and you probably want to use some high temp silicone sealant or furnace cement around the gaps, but once fixed, that's a damned cheap price for a good grill.
4 hours ago, n_maher said:
I don't, but you have to start somewhere.  Besides, the "Texas Crutch" isn't the end of the world.
Substitute a bald, bearded helicopter pilot with fairy wings and you'll know what you've done today.
Need to be able to multi-like!
Almost time for the crutch!
I'm sure it will be delicious and tender.
It was pretty good, but not perfect.
Oddity #1 - the thicker part of the brisket was the least tender.  Not sure what is going on there.  Possibly just a function of being the flat as opposed to the point.
Observation #1 - I used too much rub.  Not a problematic amount, but more than needed.  Otherwise the flavor and smoke were very good so at least I got that part right.  Also need to work on my trimming skills.  The fat cap I left was a bit on the thick side as it remained on a majority of the pieces but was easily trimmed.
Magic Pink paper! Never disregard a fairy!
Probably more fat on the point which is why it is more tender.
