This stream auto-updates
  1. Past hour
  2. Test build of Super-Carbon up and running to see what is what: PSU angle brackets are recycled from a previous, very tight, build, where those cutouts made perfect sense . Two small issues worth mentioning on amp boards. First, TTC004b and PZTA42 have opposite pinouts (ECB vs BCE) so if using TTC004b, transistor front needs to face heat sink. Second, you need to add some current limiting on the CS LEDs if you intend to use them. Running at +/-550V. No listening yet; need to build a more permanent CS supply solution first and also tidy up in general.
  3. Today
  4. Happy birthday.
  5. Happy Birthday :3
  6. happy birthday
  7. I feel the same way. Pacing is glacial.
  8. Belated Happy Birthday, hope it was great!
  9. I binged it in a couple of days. Some things are aesthetically Gilligan but overall I found it slow. Like the whole season could have fit a couple of episodes.
  10. Plur1bus season finale
  11. I meant the wh1000s sorry.
  12. Happy Birthday!!!
  13. Happy Boxing Day Birthday!
  14. Happy Birthday!
  15. Happy Birthday, Joamat!
  16. Happy Birthday!
  17. Happy Birthday!
  18. Happy Birthday - cheers -
  19. Happy Birthday!
  20. Hope you've had a great birthday Joachim! Cheers!
  21. Yesterday
  22. https://a.co/d/dvFqpzY If she's an iPhone user, probably pretty hard to beat these - pun intended.
  23. Thanks Dusty, and I think you are right about the Sonys because I just found those
  24. The Cure's Perry Bamonte Dead at 65.
  25. I agree about wired, but I will still say: Beyerdynamic DT770 Pro -- $180-ish $160 open box at Sweetwater ...because nothing isolates like they do, other than IEMs (nothing I've tried other than the Koss Pro 4AAA or whatever the nomenclature was, and those are uncomfortable as heck) There's a trick to making them not boom, but I don't remember what it is -- match the impedance? Headamp pico? Also, for $200-ish, you can get them in all black. Dan probably meant the WH1000 XM6 (my current housemate has the XM3s), which are over ear, sound good, and isolate enough that she doesn't hear me if anything is playing.
  26. I think Doug is correct, and I would be happy to learn who is making a reasonably priced BT headphone. I don't know the budget but I will pass along Steve's suggestion. If Google directed me correctly, Dan, the Sonys are ear buds and she has some already but gets ear infections and wants something over the ear. If that is not what you recommended then let me know.
  1. Load more activity
