- Past hour
- Yesterday
Neujahrskonzert 2026 / New Year's Concert 2026 / Concert du Nouvel An 2026 by Wiener Philharmonic Orchestra (2026) https://open.qobuz.com/album/nhabo81gvrobc Example: Nice recording and all the Waltzes that you can waltz to.
Happy Belated Birthday man!
I found a 2.3mm receptacle contact with a lantern-type spring insert, which should be able to tolerate some radial misalignment without too much change in the mating force. I've been toying with the idea of a multi-part jack. The pin center diameter was chosen to be 10.75mm in order to accommodate the Stax, the Hifiman and the less accurate Kaldas plug with the acrylic base. The contact retainer washer is made from Teflon which also gives a bit of flexibility. The connector and shell can be made from PEEK but I can't help trying the PEI (Ultem). Its translucent color matches with the gold plated contacts quite well. There are two variations of the design, with the retainer sandwiched between the shell and the cap, and with the retainer secured flush with the cap. The latter requires better precision from machining.
Belated Happy Birthday! Tickety-Boo and all that still. Hope you enjoyed the day!
Happy birthday, former Skylark tenant!
https://archive.org/details/dan-tyminski-2026-01-15
Happy Birthday, homeowner!
Happy Birthday Graham! Glad the stress of moving is behind you.
Happy Birthday Grahame!
Happy usual Birthday, matey!!!!
Happy birthday, Grəm! Hanging on in quiet desperation is the English way... (party favour noise)
Went from Via To They say that moving is a major life stressor. I can believe it. It's almost like I feel a year older! Time for bed!
Squeaking in under the wire with birthday greetings in your new home! Hope you had a great day of usuals and nibbles and such! Cheers! 🥤
Yeah, I always felt that way too. This is a fun read. https://reactormag.com/all-cats-have-three-names-reclaiming-logans-run-the-novel/
- Last week
Knuckledragger replied to Knuckledragger's topic in Miscellaneous
I have been going down the anamorphic rabbit hole for ages now. The more I learn, the less I know. I have discovered some fascinating bits of trivia along the way. This guy's 🇫🇷 accent is something else, but the camera is spectacular in its insanity. Also, Cool Story Bro: the fence at the 4 minute mark in the video is a rather famous one in Paris. A guy I know on Flickr photographed it in 2006 with an 85L. Note the 1/8000 shutter speed. His 5D classic was crying. -
Peter Doig built a sound system using parts from old cinemas and then Brian Eno did a DJ set on it.
1.25L DC - 🤘
