This stream auto-updates
  1. Past hour
  2. Do you truly believe, all other things being equal that class B will sound better than class A? In the world of amplification for speakers class AB, B or even class D is tolerated because its more efficient than class A and at high output powers pure class A is often impractical, and prohibitively expensive. For headphone amplification efficiency is not an issue given the tiny output power required - which makes pure class A very practical. Because of this there are few reasons to design anything other than class A headphones amps (portable headphones amps excluded because efficiency and power consumption matter here). Kevin Gilmore has designed and helped us build many fantastic Stax amps, for example the blue hawaii (which several companies sell), and of course the T2. He is incredibly experienced and is generous enough to open source his designs AND support those who build them. I would strongly think again about criticising his competence.
  3. This is absolutely hilarious. Kevin Gilmore's point is indefensible, so you jump out to make personal threats? Is this how your little 'High Rollers' club discusses technology? When someone questions the guru, the enforcer comes out to shut them up? Stop waving that bullshit 'welcome message' around like it's a royal decree. If you had any confidence in his argument, you'd counter me with technical facts. Hiding behind the rules to make threats just proves that you and your guru are both cowards who are nothing without your echo chamber.
  4. From your welcome message when you joined all of an hour ago "Don't mistake our familiarity with each other as familiarity with you" "Spend some time reading before you start to post. Get familiar with what is going on, and who the various people are. Don't just jump right into the fray." "This is your only warning"
  5. Today
  6. Heh, I got you. https://www.discogs.com/release/7077621-Clipse-Lord-Willin See some for around 67, but have found used for around 50-55 without looking too hard. It's totally worth that, IMO.
  7. Equating 'Class B' directly with 'garbage'? That just exposes the limits of your own technical skills. Don't assume that just because you can't get good measurements from a Class B design, nobody else can either. That's a classic projection of your own failures.
  8. Marta's debut album is a collaboration with Tricky, so of course it's good. Moody as shit, too. I'm in.
  9. Kinda interesting to compare size of the full frame Sony RX1R III f/2 and the $200 cheaper medium format Fuji GFX100 RF f/4.
  10. Thanks. I guess nobody likes to receive fake parts. But if it’s a low-current, 1200V or better grade IGBT, its characteristics can come very close to the SiCFET we use in threshold voltage, transconductance and even input/output capacitance. It might actually work, at least in the GRHV. I’d be interested to try it out. Well, we should probably stop talking about SicFET or IGBTin this thread, as they are irrelevant to T2.
  11. Warm Day - Hot Funk. (50yo) Mothership Connection by Parliament (1975) https://album.link/mvfsbw8h7rrmb Example: There is only one Example needed.
  12. Yesterday
  13. So this dropped yesterday, I am not sure there is a new album in the works or just this track. I am not sold on it, not bad, but it also does not do much for me at all. But I thought I would share regardless.
  14. The place looks strangely familiar. (Leica SL2 + Canon 135/3.5 LTM) There seem to be quite a bit of hate on this camera, which seems to be the same whenever Leica comes out with Anything - so well done to Sony to go full premium. Some are annoyed that it is still the "same old" lens - that's exactly what makes it appealing in my book, albeit also appalling at manual focus and it might break down one day. New lenses are coming by the bucketloads, but a lot seem to go overboard and look boring, sterile - coincidentally exactly the same phenomenon as some modern headphones. But yeah, paying full MSRP on any high-end compact (or any camera) is the definition of luxury. Apart from Fuji they loose so much value. I've once again bought an RX1RII for 1/3rd of the price (AF not great, otherwise similar rendering), fingers crossed it's a good one. But I still question the legitimacy of these things. Some of the interchangeable lens cameras are getting so good now, is it really worth saving that much with size and weight - if it is a case of whether they let it in to a big concert or other event, it might worth it. Will make photos every bit as good or better as the Pro photographer with his or her pro camera + 24-70/2.8 lens (around 35). But my fav lens system is still the Leica M-mount and I need to mount them on a big. heavy SL2 - I won't even start
  15. RIP to poet (and more) Andrea Gibson. I hadn't really listened to her, only HEARD OF her. But with her death, I watched and listened. And....she was STUNNING! I watch several of her talks/poems and often times I cry, for her pain & beauty. Examples:
  16. I'm not in the mass production business, so I'm not going to BUY expensive devices, meters, analyzers, for basic hFE determination. Over the last ten years, I've built many different versions of electrostat amplifiers. Yes, not all of them worked. Yes, I didn't like all of them. For example, the mini T2 really disappointed me. assembled version called carbon, I am happy for two years. But many music lovers always want something better. I hope that T2 will outplay Carbon.
  17. Today I received the main part for T2, the boards. I drew the boards taking into account that changes have occurred in radio components over the past ten years. I fit into the dimensions of 300x150mm with power supply units.
  18. I tested the first series of SR-4070 headphones and couldn't quite understand Stax's testing approach. The fit was extremely challenging, which made them seem not ready for commercial release. In contrast, the SR-4070 Mk2 models were a noticeable improvement.
  19. Finally! That's what I thought when reading Grahame's post announcing it
  20. Just look at the original 4070... they never estimated a person with a certain shape of the head so fit for those is not great.
  21. They thought of the human head as a flat test fixture...ignoring the fact that the head is an ellipsoid with a small curvature at the front and a larger curvature at the back. I can only say that I just overestimated Stax's design capabilities in the past.
  22. Damn, and here I was thinking it was just another singer/songwriter with a uke. Wowzers, so glad I finally got around to listening to (and watching a little) this VIRTUOSO! Thank you! Virtuosity without abandoning musicality, my beloved. I was in Guitar Center today (selling guitars, didn't buy anything), and I was severely tempted by a Fender Fullerton Jazzmaster Ukelele. Oh well, maybe I'll get an Enya Moon 5-string Taimane Signature Ukelele after I make big Epstein Didn't Kill Himself Files Do Exist Bucks.
  23. priority SINAD, nothing else matters
  24. Last week
  25. Speaking of expensive... Anyone remember Kai Wong? In earlier days of YouTube, he hosted a bunch of photography related videos on DigitalRevTV, out of Hong Kong. DRTV doesn't really exist anymore, but Kai maintains some degree of celebrity in the online photography world. He's got his own YouTube channel. I'm not subscribed and have never watched any of his videos (before today) but YT's algorithm has taken note that I have been consuming a fair amount of photography related material recently. (I've been doing a deep dive on TTArtisan glass, the OG Canon EF 15mm F/2.8 Fisheye -- more on that later -- and of course specific M42 mount lenses like different iterations of the Asahi Takumar 50mm F/1.4. I learned that my non-multicoated 7 element version is probably radioactive.) I guess that explains the giant orange hexagon, but I digress... Well, ol' Kai managed to get his hands on a vintage French-made cinema lens, the Som Berthiot Flor 55mm F/1.5. I don't know a thing about the Flor 55mm or Som Berthiot in general. I do know that cinema lenses tend to be several orders of magnitude more rare and expensive than ones designed for still frame. They were made in comparatively infinitesimal numbers and only a small fraction were sold to the general public. Additionally because motion picture cameras feed the film through vertically, many cinema lenses don't make an image circle sufficiently large to cover the 35mm film plane on a still camera. The Flor is one such lens and it can be adapted to fit Leica rangefinder bodies. Consequently a clean example goes for upwards of 60,000 British Pounds in the rare event where one comes up for sale. I'm not necessarily suggesting anyone watch (most) of this video. In spite of Kai's best efforts with his little handheld wireless mic, the sound quality is lacking. Add to that the rather thick accents of most of the subjects and it can be a challenge to figure out what they're talking about. The example shots taken with the Flor are ...fine, but nothing dazzling. I own a (not so) small army of manual focus primes. While none of them match the Flor's specific unsharpness and color transmission, I can get to an equally interesting optical space with fair number of my vintage lenses. I can't mount any of them to Leica body, however. (Which is mostly fine with me, I have never coveted a Lecia digital body, but I would certainly give an M6 with a 35mm Summicron a go.) I'll go a step further and say that if there was lens that offered identical optical performance to the Flor, but was made in much larger quantity by a less storied maker (Yashica, for example) it would sell for maybe $100 on eBay.
  26. This shit is pretty dire but I expect it got glowing reviews all over the place...
  27. Yes, it's pricy. My eye is on the Fujifilm X-T50 but the phone will do for now.
  28. I showed three samples, one of the demonstrated ones, the device defines as IGBT. I assumed that I was not the only one who encountered fakes...
  29. I always do, but at that price it would be a different model.
  1. Load more activity
