DIY cable gallery
Great work nate! :angel:
Hmm, evidently this cable is shielded. In fact the shield and the two largest conductors are all tied to ground at the plug. Seems like an awful lot of effort since headphone cables have never been known to pick up noise that I'm aware of.
Unfortunately I've personally had headphone cables picking up noise before though. :D
  • Replies 606
  • Views 265.2k
  • Harvested an old Cardas Headphone cable to make a balanced cable for the HD800. Neutrik 4-pin XLR connectors. The HD800 connectors are from Parts Connecxion and a royal PITA to work with.
  • luvdunhill
    luvdunhill
    Even scarier
  • I made some cotton sleeved speaker cables - going to get them hooked up to my horns which I moved my rack over to the side and as such needed two different length cables… couldn’t find any coconu
Well, most cables aren't shielded so you guys must be extreme like Patrick to need shielded headphone cables. :)
Well, I just move my stuff away from the noise generating sources. :dance:
The two 18ga conductors act as another shield I guess since they aren't tied to the Senn plugs, only the 1/4" plug. Again, pretty odd construction but hey I like the way it sounds so I should really stop complaining.
They're not shielding anything, it's just extra bulk to make the cable thicker. The wire costs practically nothing for a length like that, so I suppose it's worth it to be able to charge more for the cable than they would be able to if they left it much thinner.
  • 5 weeks later...
quick Q that i've always been embarassed to ask about...
those RCAs connectors you're using, the centre pin looks normal, but the outside extends way out, won't this have problems with certain RCA jacks?
Nate beat em to it, but I spent a few minutes typing, so I'm posting it anyway.
That is the special design of the connector. The ground part retracts into the plug. The idea is that when you go to plug in the connector, it will make a contact with ground, thereby avoiding popping noises.
So your assumptions would be correct, but the 'outside' retracts into the connector itself.
I have a set of these:
This is the first image in the first post. Maybe mine is a first edition of these, I am not sure. I am now using a set of Virtual Dynamics Nite RCA-RCA cables with the Cardas Rhodium adapters XLR-RCA to interface my Lavry and my Yamamoto.
Those particular jacks use a spring loaded ground connection and when installed look and work just like any other plug. Kind of hard to explain but if you ever use one you'll see what I'm talking about.
thanks guys, makes a whole lot of sense, wonder why these kinda of connectors aren't more popular.
ground first is better than signal first i think. esp those times when the centre pin touches the ground on your amp as you go to plug it in...
They are a tad expensive. Not prohibitively so, IMO, but they cost around $13 a pair.
  • 5 weeks later...
Perhaps the world's first Apogee Duet Breakout Cable
Note, there is no designation for L or R on that cable because apogee doesn't assign L or R on their freakin' pin-out diagram. There's your homework assignment, Dan.
5 Left
15 Right
My cable should have inputs too :)
5 Left
15 Right
Thanks Dan, and yes I know that your cable should have inputs as well. But I'm all out of RCA plugs and wanted to get a proof of concept put together for you to test. So that cable will be headed your way on Monday to test fit and function before I invest more $$ in the project. :)
Wow, that's a great looking cable. Where would order one of those?
ALO. The prototype is pictured. The production model will have camo techflex so you can record your hippie shows out in the woods secretly.
ALO is the first company evAr to amek the Duet breakout cable, as well as the first company to make electricity. I would make sure to buy that breakout form them.
I lol'd. Literally.
