The Multi Amp aka Dynalo Mk2
2 hours ago, rumina said:
Not a Mini Dynalo but a small one. Finished my Dynalo today, thanks to this forum and the members the build was easy and free of trouble, thanks everyone. Was fun to put it in a small case and solve this puzzle. Also a big thanks to Kevin Gilmore for this design and sharing it with us.
http://www.diyaudio.com/forums/gallery/showgallery.php/cat/2231
Thanks to sbelyo for the group buy of the pcbs.
man..same thoughts here, but I failed squeezing GRLV in it,lol
  • Replies 1.6k
  • Views 539k
  • johnwmclean
    johnwmclean
@pars thanks for the info, was puzzeld about the 3th rectifier and didn't take much time thinking of it, a bit of wiggling and it's out now. Something new learned about the grlv, used it the first time. That's a part i love about head-case, helpful people and always something new to learn.
@ang728 look nice your amp, building this in a small case is like a 3d puzzel, part of the fun for me.
Hi everyone! I also finished my build of Susy Dynalo! Still doing run-in of the amp but it already sounds really great even driving a HD800!
Since the layout from Mr.Gilmore is a little bit too large and cannot fit into a 10cmx10cm pcb, I have to redraw the layout. But good thing is that an extra inductor was added to the power rail of input stage as well as the VAS to prevent distortion from output stage. Also the rails are surrounded by "guard rings", aimed to avoid EMI problems.....
Sorry for the crude casing... just carved it out from kinda plastic flowerpot...
Some detailed specs:
Quiescent Current of Input: 1.2mA
Output stage bias: 6.7mA per transistor
rail voltage: 18.5V, tried 20V but it's too hot.
Gain: Approx 3.
Also some interesting results. The THAT340 was then replaced by hand-matched ksc1815/ksa992, beta deviation within 0.1% - Huge improvement in transparency and details!
The power supply based on Jung's regulator, but an extra transistor was added after the error amplifier to lower the load seen by the Op-Amp, works well.:D
That case was designed to sit in an oft-flooded basement.
1 hour ago, kevin gilmore said:
no no no, swimming pool, it floats
with reference to ground?
Does it impart a liquid sonic presentation...?
In other words, it will send more than tingles down your spine......:blink:
lol, indeed the "casing" was dug up from the basement. A water-resistant version...:P
And the amp sounds a little bit too bright, so the compensation cap was added upto 15pF, much better now
Noob question to all.  On Kerry's 1.4 Dynalo v1.4 SMD board, on the bottom side, there are a couple of masked points with silk marker "AOT" and "0".  What are these, jumpers?  Thanks for any pointer!
the 0 is ohms (used as jumper) R27,R45 on BOM
LRC-LRZ1206LF-R000
think from schematic that AOT is a voltage adjustment
I was hoping someone would ask... cause I'm not sure either
Edited by congo5
Thanks many, I'm in the process of populating the board...will jump the 0-ohm!
AOT is a resistor (R62) spot in parallel with R54 (10K), feeding the sense line on U3 (TPS7A3301RGWR?) to ground. Maybe used to tune V- to match V+? No value listed in the BOM for it.
Yes.  AOT means Adjust On Test.  It's not required but can be used to finesse the output voltage on the negative rail.
Thanks Kerry, for the clarification and providing us the board design.
Any advice on the best way to solder the TI 7A4700?  That thing's tiny, I ruined one board doing this already.  I'm thinking melt some solder first on the pins and then put the chip on.  I got a rework air gun, not sure it's the best way though.
watch Louis Rossmann - YouTube
I used a candle warmer to preheat the area.
clean the pads
 liquid flux
 tin the pads
clean
reflux
use hot air station
solder with silver content helps with gold plating.
clean the pads
 liquid flux
 tin the pads
clean
reflux
use hot air station
I watched part of Rossmann's video soldering a chip on a Mac or the like...damn.  Soldering free for all.  That man doesn't play.  LOL
HS
Yep, real world actual work  not 5 takes and edited
Thanks
and he definitely does not hold back on opinions...no inside voice...LOL
Thanks for posting, congo.
HS
Any idea what brand/type of flux he's using?  I bought MG no-clean flux but it's too thin and evaporates too quick (doesn't hold the smd piece still for alignment).  Thanks!
I haven't a clue.  He has a video where he describes all the parts he uses as I believe he receives many questions.  It's over an hour long...
HS
under video description click "show more"
✖ TOOLS USED:
● Flux: http://bit.ly/2cYIx7t
● Solder paste: http://bit.ly/2epK1JE
● Soldering Iron: http://amzn.to/2cKkMyO
● Preferred tip: http://amzn.to/2d5MgPn
● Micro Soldering Pencil: http://amzn.to/2d5MWUP
● Micro soldering tip: http://amzn.to/2eYrF4a
● Hot Air station: http://amzn.to/2d5M7Lw
● Hot Air EXPENSIVE: http://amzn.to/2cYI6tY
● Tweezers: http://amzn.to/2d5NBpi
● Multimeter: http://amzn.to/2cYJY5T
● Multimeter Probes: http://amzn.to/2cKkvMh
● Fume Extractor: http://amzn.to/2d5MGoD
● Microscope: http://amzn.to/2iLrE16
● Microscope LED light: http://amzn.to/2d5Mh5T
● Solder: http://amzn.to/2cKkxUp
● Crest CP500HT Ultrasonic cleaner: http://bit.ly/2iv3aci
● Branson EC cleaning fluid: http://amzn.to/2cKlBrp
● Jumper wire THIN: http://amzn.to/2eqF5T7
● Jumper wire THICK: http://amzn.to/2eAJ5AU
● Nitrile gloves: http://amzn.to/2iUfumS
Bench PSU: Agilent 6542
I'm using Kester.
turn down the blow.
hold with twezers
mask off  blow zone with aluminum foil?
Good stuff, congo.  I like the look of the Hakko micro handpiece / pencil.  Might have to spoil myself with one of those.
HS
Yes, want! don't have small pencil
on Flux: its a big deal, what he has is way better, the kester boils off quick and leave's more residue but works
I got the positive regulator on the first try, but took three times on the negative   Had too much solder under and some side pins would not make contact.
flux dries> solder won't stick> start over
going slow and careful as I only have one board, that took half a day ;-)
Really want the microscope + camera.
