Head Case Motorsports
Still in the claims process.  Will just end up being a re-powdercoat eventually.  The curb damage I did on the bottom of my front bumper at Justin's today will be a much larger fix.
  • Replies 2.1k
  • Views 414.6k
  • First day in two months the high has been below 55 and first day in almost 3 its snowed.  Hopefully this bad luck isn't a sign of how things will go with the new toy i just took delivery of..
  • I learned a ton and had a blast at my Driver's Academy class on Saturday. There were 24 students, about 16 of the 24 were teens and young-twenty-somethings and the other 8 of us were older drivers. Fo
Not visible.
Some of the very good Audi turn out.
And some others
One for Brent
And some for the VW crew.
Welding up 'o' ring grooves ?
Yes, Leve.  I found the cooper o-ringed gaskets to be too much work...leaked too often in my application.  I push a bit of boost through a 406 C.I. motor.
HS
Those are some great pics, VPI.  Particularly like the shot of the Cobra knock-off, aftermarket...whatever they're referred to as these days.
HS
And a very special one right up Brent's alley.
Edited by VPI
One more to show how screwed up that Subaru was.
I would say at least a third of the tire makes no contact.
Nope.  Ride height went up, camber stayed the same.
Negative camber....
A bit of negative camber is great for a road course.  That crap hurts to look at.
HS
While on the way from Carson City to Virginia City I spotted something that caught my interest
So we pulled over to investigate further
And were not not disappointed
Turns out it was something that's been going on for 44 years
https://www.virginiacityhillclimb.com/?page_id=2
So we carried on, and saw it from the other end
I bought some stuff from Chemical Guys, got my windows tinted and replaced my rear view mirror, which had floating oil from the auto dimming feature. I also am considering replacing one of my headlight assemblies due to fogging plastic. Can I post here?
I have a few spots that have paint on them, where likely my wife scrapped up against our garage. Is there a recommended way to remove this? Is this what "clay bar" is all about?
No.  Claying is a method to remove very small particles clinging to the finish.  To remove paint, etc., try polish or polishing compound, in that order.
Believe it or not Marc, I've found the Mr. Clean eraser foam bar very effective at removing the rubbed on paint. You may then need to polish the spot to get the sheen back.
I'm not familiar with the Gunk brake cleaners (there are six different ones here), but most brake cleaners damage paint and other finishes and specifically warn about that on the cans.
What guzziguy said. I use different levels of polishes (more coarse to finner in series depending on nature of issue) from Griot's. I cannot recommend brake cleaner. It may dull your paint and it will fog plastic in my experience.
I have a friend that swears by charcoal starter....a petroleum based product, but I have never tried that personally.
Just watch to make sure you're not down past the foreign paint and down into some primer native to the vehicle's paint
Good luck.
HS
PS i have had some joy with a microfibre cloth and rubbing alcohol on my boy's vehicle.
Made it back to the US in time for the last Katie's of the season, unfortunately it was kind of rainy, but the lighting was nice.
Katies9-12-13-X2.jpgKaties9-12-2-X2.jpgKaties9-12-7-X2.jpgKaties9-12-16-X2.jpgKaties9-12-1-X2.jpgKaties9-12-6-X2.jpgKaties9-12-14-X2.jpgKaties9-12-5-X2.jpgKaties9-12-19-X2.jpgKaties9-12-18-X2.jpgKaties9-12-17-X2.jpgKaties9-12-10-X2.jpgKaties9-12-9-X2.jpg
