grounded grid
  • Replies 386
  • Views 143.4k
  • Just like Carbon we built. Same box, same PS. Relay=120s. Separated filament transformer.
  • Another Grounded Grid lives.  Have been listening to it for about a week. Powered by the same GRHV/GRLV PSU I use to power my KGSSHV, Carbon and Blue Hawaii. 400VDC rails and 20mA plate current.
bh modern? how's the prototype (assuming you've built one)
I thought the main issues around this were the fets needed to drive the el34 inputs
have not built one yet.  may change the drive transistors to ksc2690A
been thinking about this a while, saw no reason not to do the board.
5.6 x 4.7 inches
board file posted  :D
I can do the same thing with the nanotube, for the ultimate in gigantic.
fets, triodes... its all the same thing...
maybe the tube circlotron will be similar sized if you've got tubes instead of heatsink
fun projects are getting more fun though, no parts headaches ATM
This will form the basis of the new Blue Hawaii I'll build next year.  Good thing here is that tube failure is far less catastrophic plus it should sound better.  :)
I have some original bh boards here maybe I should case it so they can use the same power supply
No problem running this at +/-400V but it can go up +/-450V.  We could even do something like the T2 CCS and push it even further.
Thanks for the belated Christmas present Kevin. :D
What is the intended current thru each tube?
updated file
current thru the tube designed to be 20ma, so a bit more than previous
driver transistor is ksc2690a only, dissipates a little less than 1W, needs very small heatsink
you loose about 45 volts across the tube, so +/-450 is ideal
What does the tube socket pin numbering refer to?
Edited by sorenb
ignore the tube pin numbers, they do not show up anyway. its how that socket was made when I did the t2
picture above updated
would cascoding the 6S4A with  KSC2690 be possible as well?
apart from the j79 being obsolete would that be a suitable replacement for 2690?
Very cool Kevin.  I've modeled this as well and definitely want to build it.  Thanks again for pushing us along :)
In a KGST?
I don't believe it would work with a CCS on the tail as well as on each plate. That's a different circuit topology with a grounded cathode,  rather than the BH, Carbon, and Kevin's latest grounded grid variants.
in the original kgbh, the 2sj79 can be replaced with a ksa1220A and the 2sk216 can be replaced with a ksc2690a. Not the same pinout.
someone would have to test, but synthesis shows it would definitely work. in fact the ksa1220a and ksc2690a are faster and lower capacitance parts than the originals.
im up for testing them in the original boards, need to get that thing finished anyway. does that make them similarly applicable in other designs like the t2, or the 6c33c amplifier?
the 2sj79 and 2sk216 are 200v parts, the ksa1220a/ksc2690a parts are 160 volts.
would probably work if you are careful.
A very dumb question.
How large is the heatsinks req for the 10M90S.
Looking at the holes a L aluminum bracket is required to mount the board to an external heatsink.
Or I am missing something here
16 watts per channel for the 10m90s plus another 10 watts for each power supply
AWSOME!
it seems that can use the KGSSHV-PSU( 450v ver) , carbon-PSU and BH-PSU.
i can`t wait to be the first one to build it.
How about 2SC5171 / 2SA1930?
180V, Lower Cob(16PF), Flat hfe-Ic
In Japan, popular than 2SC2690(A).
