What Are You Building Today
Got the drawer dividers cut, glued and clamped up. I cut the drawer material to height, but a tad bit long and wide. I want to wait until the box cures, then I can un-clamp and measure to fit nice and snug.
I have some drawer glide tape coming. This will attach to the bottom of the drawer sides and allow the drawers to slide with minimal friction. The box is too small for mechanical drawer glides.
  • Replies 2k
  • Views 497k
Three sides of all four drawers are cut, assembled and bottoms slid into place. The drawers will be left natural, with a clear lacquer finish. Except the drawer fronts, which will be stained to match the box. The box sits atop the drawers for weight, to ensure that they dry flat.
Tomorrow I'll cut the fronts to fit and stain them.
Not sure what finish I'm going to use on the box, but I  think it'll probably be boiled linseed oil, with a top coat of Tried-N-True.
I am working on my sailboat motor attachment and am using some 5/16” carriage bolts in the end of the transom so the heads are flush. The material will be something called Starboard, which is a marine HDPE plastic. It will be two 3/4” sheets put together. I am wondering how much material I need to make sure the square part of the bolts catch in the material? Should I just drill 5/16” or go 3/8”? The square part is .32” * .32” so the long diagonal of the square is .45”.
Edited by luvdunhill
I'd be tempted to drill the main hole the diameter of the threaded section and then try to use a countersink or maybe a forstner bit to enlarge a shallow portion to accept the square portion of the neck.  The HDPE is probably hard enough that you don't want to assume much engagement between the neck and the material or you likely won't get it to sit flush.  Some trial and error maybe required but at least it doesn't sound like you have to do this 100 times.  If it's possible to do this on a drill press you should have no issue iterating to get the right combo of depth and size.
Would the countersink diameter be say 3/8” - just enough to be able to get the bulk of the the square piece in? Yeah, I just need probably 4 or 5 holes.
At that point probably just best to use a hex head bolt and counter sink it…
When using a carriage bolt, I've often just let the pressure of tightening the nut pull the squared part of the shank into the material. It should work even better in a plastic material.
Depends on the relative hardness of the plastic.  With wood I use the same methodology as you and let compressive forces do their thing but have no experience with HDPE.
Construction complete on the incense box. First coat of boiled linseed oil applied.
The shop assistant approves.
Thanks. Fitz isn't looking at this thread, because he wants it to be a surprise when it arrives. I hope he likes it, as he just gave me the dimensions he wanted, and gave me free reign after that.
Nice! Would some small adhesive Teflon tape or something on the bottom help the drawers slide in easier? It seems if you apply the pull or push force on the end of the drawer it might bind up?
The drawers slide in and out easily now, even though I kept the tolerances tight. But as Doug pointed out, I have 1/64" thick glide tape coming. It's made out of the same thing as a butchers cutting board. That slick, White plastic.
That detail was only in the part you had to read. I just looked at the pictures and gave my own opinion - is that what the kids do these days?
They make memes.
My experience has been if they can't make any build fit in a Tik ToK video it doesn't get done.
If I  built a Grandfather clock in a Tik Tok video, would that be irony?
This was anticipated in 1875:
My grandfather's clock was too tall for the shelf
So it stood ninety years on the floor
It was taller by half than the old man himself
But it weighed not a pennyweight more
It was bought on the morn on the day that he was born
It was always his treasure and pride
But it stopped, short, never to go again
When the old man died
Ninety years without slumbering
Tic toc tic toc
His life's seconds numbering
Tic toc tic toc
etc
I'm pretty happy with the finished product. May it house many fine incense boxes.
23 minutes ago, swt61 said:
Uhm, I'm Otis?
Spunkmeyer I assume.
