What Are You Building Today
Are you running the Bambu Labs Carbon now. L?  I put a deposit down for one as I got to play with one here locally and I hope it keeps the tiny, tiny smell out of the air that Kasia claims is giving her cancer. Even with a massive BlueAir unit running at full speed.
  • Replies 2k
  • Views 496.3k
No I’m still using my Prusa. And like you everything I do is for something I’m going to use to build something. Planning on making battery mounts soon once I figured out how I want them mounted. If I need a second machine or find the need to do a lot of printing I’ll pick up the Bambu. Right now it’s minimal.
Edited by naamanf
The new P1 series goes on sale for Black Friday and has many of the features of the carbon, without the two big ones, enclosure and LiDAR. Should be a perfect hobbyist unit really as it can accept much of the accessories from the big guy.
Now you guys are just throwing fake phrases out there to fuck with me.
And it's working.
And it's working.
Don’t worry, Ebony is always superior over plastics.
Battery holder printed well clips in right. Going to mount them to the wings of the drill cabinet to allow for my fat fingers to access the buttons.
More decorations. Tea Light Trees.
Will be expecting the VPI vibrator any day now. Make sure you put the correct tab on the end so that it can fit into a Sawzall.
I bet he's the Shagsall guy.
Edited by swt61
I need to laminate some things together and it’s not possible to clamp them. I want to just screw them together and later use the hole from the screw as a guide for a forstner bit. I am using West System 105 and 207 epoxy.
My question is, will I be able to back out the screws? I assume so but if not that would be a huge fail.
2 minutes ago, naamanf said:
Wax/release agent on the screw.
Cool. That seems reasonable. Thanks!
Both great tips. You can even use a bar of soap to lubricate the screws.
If you use a bar of soap, I would highly recommend Irish Spring.
It's manly, but I like it too.
(That only makes sense if your over 50)
9 hours ago, shellylh said:
You should trust Steve - he’s knows all about lubrication. 😂
Best post of the year!
Finally finished the last part of my side deck that will store various water things.
Making the gate hard - I kinda made things up. I think maybe I did it all backwards, but oh well - there is no other entrance to this area so the gate stoppers are visible and since it’s all on a slope the had to be cut different lengths.
It works and kinda matches the hog wire. At some point I would like to put something on the gate - some art of some kind, maybe need to enlist the ping-pongers :)
Oh and you can see the concrete slopes where it meets the deck - grinding that down was super fun!
Your estate is large enough to need a second gated entrance to store the toys?
No wonder I pay so much for Prime.
