current feedback electrostatic amp
so sorenb really wanted this, so here it is
http://gilmore.chem.northwestern.edu/cfaelectrostat.pdf
the outputs are 300v darlington transistors  just need to find a suitable npn match for the stn9360, and this can be done all surface mount
tiny, fully complementary, fully dc coupled, decent input impedance (none of this 75 ohm nonsense) push pull output...
edit:  PBHV2160ZX looks great for the npn.
so you can add one more set of outputs and run up to 500v power supplies
balanced input only, and you need 4 of them
  • Replies 282
  • Views 89.6k
  • Another electrostat CFA lives. This one born on the 4th of July? The PCB is congo5's layout. The amps is powered by my GRHV PSU with ~405VDC rails.  Many thanks to Kevin for another wonderfu
  • Finally cased my ES CFA amp.  Returned the bias resistors to 1M with the larger heatsinks. Running 20mA bias for the output sections.
  • kevin gilmore
    kevin gilmore
    build it, put it in a super fancy box, and sell it for $37k betcha it sounds better than the high priced spread, at least no stupidly expensive and useless input transformers. its a push pul
am i the only one imagining kevin drawing this up with one hand and basting a turkey with the other?
this needs the plug in card form factor to get the full msb experience
actually 3 hands.
(updated schematic with great respect to you know who)
1 hand for turkey baster  (actually making casserole at the moment)
short hand for mouse
1 hand holding 50 year old single malt
we will definitely be building this one :D
don't hold it for to long, it might get old:rolleyes::D
See, this is the real idea behind the Stax mafia.  They pat you on the back for building one of their designs while they're sucking money out of your pocket by posting a new one.;)
No LV supplies and no sinking, seems like this was what the exstata should have been.
can't catch up with the mafia...
looks like a nice, low cost, all sand design.
It will need some heatsinking if we are to run it at reasonable current levels aka. mafia style.  That said, nothing too excessive.
If everything can be surface mount, how small a footprint can it be?  It would be nice if it can be a small and portable amp. :)
what are the typical ways of sinking smd parts? i saw kerry do it with the transportable dynalo and it seemed a bit unwieldy, hard to wrap my head around. are you just pressing the board against a surface?
So we actually can do it as the schematic is drawn and make darlingtons out of 2 different transistors
So ksa1156 and ksc2752 for the output transistors, as the schematic is drawn they are 750mw each the driver transistors are 8mw each so definitely surface mount and the input transistors are 50mw each
I think there might have been a better match for the ksa1156, someone go find it.
also remember that Fairchild was bought by onsemi, so lets make sure the parts are going to be there for a while
That's the correct compliment per the original NEC datasheet for 2sa1156.  I don't know about future availability.
Yup that's the correct complimentary part but who knows if they'll continue to make them.  That said, they aren't extremely high voltage so they might be of use to the normal people...  ;)
single sided even, can add a ground plane on top if necessary, current size 3.45 x 3.7 inches, i'm sure birgir will be able to shrink it in the one direction
you need 2 per channel, stack on top of each other, or next to each other.
I should probably add some mounting holes.
Just popped it into a Spice. I don't have models for the output devices, so used BC337/327s everywhere (they would blow up, but Spice doesn't care. :))
Bandwidth doesn't look too hot, even with the outputs unloaded. May have made a mistake, but the input stage looks like it's starved for current? Replacing the emitter degen Rs with 1k and bumping the ouput stage Rs accordingly (~3k) helps a lot.
Not sure how to attach the .asc, here are some screenshots.
I am sure there will be value changes once I build the thing, and since the outputs will be heatsinked it's easier to turn up the bias a bit an decrease the values of the voltage divider resistors
deleted
Edited by JimL
matching the output devices not a bad idea
board file posted, new software may not be compatible with some gerber viewers, I did it in rs274x although I can do the new gerber x2 version
changed a number of resistors, its less than 1db down at 20khz.  about 7.5 watts per board, 15 watts per channel, 30 watts total plus the power supply
joamat i'm expecting you should be able to have this done by the end of the day :D
not possible, I am several hours ahead of you Americans:popcorn::dan:
So, before breakfast tomorrow is a go...?
It will surely be done by 6pm on Monday!!
I'll look into updating the board a bit.  Might change it all SMD and into stereo channels.
So, if I understand this, it looks like this design really likes to be driven balanced.  If you have an unbalanced input (e.g. RCA) the negative input is grounded and the stator gets no signal, unlike the differential input designs which become a long-tailed phase splitter if you ground the negative input, thus providing a balanced output.  Correct?
Edited by JimL
no this is the krell/Marantz style of doing unbalanced to balanced via the low impedance - cfa input.
Marantz still does this in products today.  differential gain way less than .1db, look at the graph. schiit has trademarked this as "schiit pivot point"
my unbalanced/balanced/cast input board does the same thing.
if cavalli was not such an idiot, he could have done the same thing with his liquid cabon instead of a cheap front end opamp. By the way, liquid gold is the same fucked up mess.
