stax t8000 clone (well sorta)
using Kerry's servo, but a resistor to make +200
by the way the alternate name of this board will be t8000DR   (DR as in done right) :D
edit: fixed font sizes
  • Replies 261
  • Views 89k
  • Now with top plate.     Aerial view, the two holes in front of outer small tubes are for balance trimmers. Adjust balance after some time of warm up and then insert jumpers for the ser
  • kevin gilmore
    kevin gilmore
    using Kerry's servo, but a resistor to make +200 by the way the alternate name of this board will be t8000DR   (DR as in done right) edit: fixed font sizes
  • Look! Top plate, 1.6 mm copper clad single sided. I do think we have copper polish somewhere in the house…
9 minutes ago, Whitigir said:
You are amazing, how about this in combination with Grounded Grid :D !
that's enough for today
One request Kevin, if this is applied to the GG circuit layout some day.
If possiblewould be nice if the PCB height could be kept within 130mm/5-1/8 inch max.
58 minutes ago, kevin gilmore said:
looks like the best I can do is about 5.7 inches
current gg board is 4.7 inches
Thanks for taking the time to look into that, Kevin.
Will gladly work around the larger dimension on my end (new cases) when this new tube input GG happens.
Got a gut feeling this will be a killer amp!
far too many projects to keep up, but it's always so tempting once you see the artwork...
i remember reading that kevin was championing the el34 ccs in the megatron, should wire that in instead so everyone gets the tube complement they want even if it's not the grounded grid output. kidding of course, even if it does sound monstrous.
1 hour ago, kevin gilmore said:
well that is one way to make a fully dc coupled megatron
i thought Megatron is already DC coupled?
Should have looked at the schematic before I spoke - yes, .22uf coupling capacitors between the stages.
Edited by mwl168
not to scale, carbon board is 5.45 x 4.72, tube output board is 5.6 x 5.52
newest versions of the boards
Woahhhhhh!!! Thanks Kevin ! I am in for a group buy of these boardS please!
if my wife could fix this kinda sandwich :D
Edited by Whitigir
I was thinking to build one adjustable DC supply to use some P88CC or 6N23P. Those have much more reasonable prices.
Filament will sit a little bit at negative. So negative LDO is preferred?
Kerry needs to publish the latest schematic with his servo.  posted version does not have enough current to drive the opto. would still work without the servo
Looking good @JoaMat :)
Here's the new schematic with the updated servo.
It would be very much appreciated if some folks could check Kevin's boards against this schematic.  Thanks :)
EDIT:  Updated schematic to match transistor values.
Edited by Kerry
Great,
a new version of offset servo. I can’t remember how many versions we have seen so far, but as I remember one of the first was found in Kerry’s KGST (and Stax T2 of course).
Any chance to shave just a few more mm off the length of the tube input Carbon boards? Maybe on the left side the zener string has space to be moved and the traces adjusted a little? Then I would be able to squeeze it into this standard size ebay case, which has 300mm internal length: http://www.ebay.com/itm/122099811096
minor differences: board looks good, don't see any problems
board uses resistor + zener string instead of U10
D3 has a 350K resistor to ground
connection of R15 changed  and values of that and R16 adjusted
Q7 Q8 Q9  Q10 are KSA1156 instead of  STN9360 on schematic
trimpot added to R12 for offset
Q13 collector has an added 100k 2W resistor
Edited by congo5
silkscreen reading error
