Kerry Design mini GRHV\GRLV and JoaMat mini T2 Group Buy
  • Replies 421
  • Views 117.4k
  • Just got a few boards in.  From left to right... GRHV78xxx, GRHV79xxx and to the right is a new experimental digital alternator.  It’s stackable for balanced
  • Look what I just found at my door step...
  • Here's some pics of the power supply inside a Canon build...
Please increase my order of both GRLV78 and GRLV79 to 5. Also please add 2 bare GRHVs because they're cheap and why not.
Please increase my grlv78/79 to 6 each instead of 3 each. Thanks!!!
10 hours ago, Energy said:
I would like one bare set please. Thank you!
Please read the thread and be specific about which boards you want and how many.
On 3/17/2020 at 12:12 AM, JoseA said:
I would like partially assembled boards for one set  Thank you
Please be specific.
Table updated.
Edited by mwl168
mwl168, I had a look at the bom for the gr78xx and tried to build a mouser project from it. However mouser says the kst42mtf is obsolete and out of stock. Also C3 C7 in the bom is the same as c1 and c2 but is on a seperate line... the gr79xx also uses the obsolete kst42mtf. the gr79xx also has two entries for the same cap, c1,c4 and the line c7.
Ok looks like farnell still has some stock remaining....
Edited by jamesmking
Just to confirm that I would like what is listed against my name in the table. Thanks!
Hi
sorry for the delay but quite busy down here curing people with that damn virus (not infected yet !!! thanks to my own protection hardware ....)
i will double the order so 2 sets , that would be
4x GRHVxxx (assembled)
2x GRLV78xx
2x GRLV79xx
2x main board
2x mini t2 board
Right ?and obviously i confirm the participation :)
Hi,
Sorry, to be more precise:
2x GRHVxxx (assembled)
2x GRHVxxx. Bare
2x GRLV78xx
2x GRLV79xx
2x main board
2x mini t2 board
Thanks
2 hours ago, jamesmking said:
mwl168, I had a look at the bom for the gr78xx and tried to build a mouser project from it. However mouser says the kst42mtf is obsolete and out of stock. Also C3 in the bom is the same as c1 and c2 but is on a seperate line... the gr79xx also uses the obsolete kst42mtf. the gr79xx also has two entries for the same cap, c1,c4 and the line c7.
C1, C2 and C3 are different values.
A quick look seems CMPTA42 could be a pin/package compatible part for KST42Same goes for the PNP part.
Kerry and others should be able to confirm.
Table updated.
Edited by mwl168
Apologies for not being accurate. 😅
I'd like the following: (enough for one Mini T2)
  • 2x GRHVxxx (bare)
  • 1x GRLV79xx
  • 1x GRLV78xx
  • 1x Main Board
  • 1x miniT2
2x mini T2 board
2x PSU main board
2x GRLV78
2x GRLV79
4x GRHVxxx (bare PCB)
2x GRHVxxx (partially assembled)
Please update my order.
6x GRLV78xx
6x GRLV79xx
2x main board
1x mini t2 board
Thanks
Sam
Table updated.
I think I've used MMBTA42/92 in the past successfully, though your suggestion Michael looks like it should work as well.
Kerry, the GRLV78/79xx can be usable in your dynalo mini ?
We have a few new comers to HC (<= 10 posts) that participated in this GB and have not responded to my inquiries, including direct PM, for confirmation. We need final board counts to get accurate quotes from the fab house for this GB to proceed.
The GB participants listed below please respond on this thread with your confirmation or desire to drop out by end of day this coming Sunday, March 22. If we do not receive your response , I will assume you are no longer interested and will remove you from the GB. Thanks!
stickyjon23
grendel23
zumac99
Marc Edwards
Edited by mwl168
Thank you for your time Michael.
This GB is hot!
I am still in for:
4 ea. GRHVxxx partially assembled, 2 ea. GRLV78xx, 2 ea. GRLV79xx, 2 ea. main board, 1 ea. mini T2.
Thanks,
Jay
Hi Michael,
hoping that I'm not too late, I would like to have
2x GRHVxxx
1x GRLV79xx
1x GRLV78xx
3x Main Board
3x miniT2
with much thanks!
Dear Michael, increase my GRLV78 XX, GRLV79xx numbers to 3 each from 2, please! Thanks!!, no more changes.
4 hours ago, Makoto said:
Hi Michael,
2x GRHVxxx
1x GRLV79xx
1x GRLV78xx
3x Main Board
3x miniT2
with much thanks!
Do you want the GRHVxxx partially assembled or bare boards?
I assume you know the PSU Main board is designed specifically to work with the GRHVxxx boards? Each main board takes 2 GRHVxxx boards to supply a set of  +/- HV rails.
Edited by mwl168
It's good for newbie to have the advice. I'd take the bare boards, then
6x GRHVxxx
3x GRLV79xx
3x GRLV78xx
3x Main Board
3x miniT2
Thanks!
