Home theater help....
I have a Marantz AV7005 that has been sitting in its box in an air conditioned storage unit since we moved to Florida. It is yours for the shipping cost if you want it.
  • Replies 71
  • Views 17.7k
  • I will get it out of storage tomorrow and get back to you.
  • I have a Marantz AV7005 that has been sitting in its box in an air conditioned storage unit since we moved to Florida. It is yours for the shipping cost if you want it.
  • 1 year later...
They pack a lot in that small chassis!
I'd have to hear it to get the effect, but it sounds interesting. Both subs are the same?
I've often thought about a quick 10" sub, supported by a deeper 15".
There's a guy in here named Steve that should make a joke about this.....
If anybody is seriously considering 15",  I've over inflated expectations.
Could you imagine 15" in circumference?
I sometimes have a hard time talking some into "it", at close to 1/2 of that. 😳
Anywho, back to home theater.
I'm sure you're quite familiar with packing a lot into a small chassis.
I looked at the specs on the Marantz slim model, very nice but only 50 wpc.....would need fairly efficient speakers methinks, a smaller room, or maybe use a separate multi-channel amp...
  • 2 months later...
Does anyone have the LG GX model on the included slim wall mount?
I am not sure if my wall isn’t flat or the panel isn’t flat ... but something ain’t flat.
Well, I wasted more time on this. Here is what I know.
if I put a level across the top of the bracket, the top right I can slide two washers under the straight edge and the bottom right three washers. So I thought to myself, obviously I need to space the bracket out from the wall accordingly. Well, same exact problem. When I snap the TV in, the bottom right left is about 3/8” out from the wall (other corners are flush with the wall) and there is a decided bend in the panel
The shadows from from the overhead lights here might offer a clue:
if not here are some attempts to show the problem (this is with the washers spacers installed behind the mounting bracket)
Edited by luvdunhill
  • 2 years later...
