Well my Northstar M192 MKII arrived today, took a little while to start using it though as I was having problems with my Squeezebox. So for now I'm using it with the EMU 0404 USB via foobar and ASIO output. I'm using the rca outputs till my new balanced cables from Nate arrive ;).
I'll post pics later but here's some early impressions:
  • detail retrival is good
  • resolution and extension are very good
  • tonality seems pretty accurate
  • soundstage (especially depth) are excellent
That's about it for now I'll add more as time goes on.
Hi-rez pics here
1280x1024 pics are attached below
Edited by tkam
:useless:
Or does it look the same as the MK1.
And if you get a chance could you try the 840c as a transport to the M192 to see if the North Star sounds better? Or see if that reviewer really was smoking the good stuff.
:useless:
It's pretty much the same case and faceplate it's really only the internals that are different.
:useless:
Good suggestion Deepak. I would be interested as well since I do have a 840c as well :). Glad your new toy arrived
I think you need to start naming each model of cables within your line. These should be called the Un (balanced) Vince (Vaughn) ©ables . UnVinceables. Ok, perhaps I should go back to work.
I like SUCKITALO better.
Yes, but don't forget about his new line, the "Elite". It's the same as the SUCKITALO but costs 5 times as much. It's for the people that irritate him! ;)
Balanced cables from Nate arrived today (thanks again nate ;) ) and the m192 mkII does sound a good bit better balanced vs single-ended. Channel separation is greatly improved and the bit of treble glare that was present single-ended is gone.
I haven't had a chance to compare them yet, they're on different floors of the house so it's a bit of an ordeal ;).
