November 9, 200818 yr comment_174304 So, I'm working on a pair of monoblocks. swt61 has seen these monster heat sinks. 12.2" wide x 12" tall with 2.925" fins and 0.326" base, weight is 13 pounds... and I got four. I've done some thermal plots of 6 devices per heatsink on a small PCB. Each device is dissipating 14.8W x 6 devices x 4 channels ~ 350W. I'm wondering how much further I can push the devices. The sim data is very close to actual temperatures and since I don't want to drill holes under the devices for thermal probes, the simulator will be gospel. I don't really want to move the devices apart anymore, as I have a PCB in mind I'd like to accommodate, plus a design of my own. Datasheets for devices: http://www.fairchildsemi.com/ds/FQ%2FFQA12P20.pdf http://www.fairchildsemi.com/ds/FQ%2FFQA19N20C.pdf Attached are some plots and below is the tabular sim data: Thermal Design Details Heatsink type: Extrusion Part number: Extrusion: 9012 Weight: 5.26685 kg Heatsink dimensions: 309.96 mm wide x 304.8 mm long x 74.3 mm high Material: Aluminum Finish: B Environment Ambient Temperature: 25.0 C Altitude: 0.0 m Thermal Design Details Temperature Source Names %sc Power Tsink-avg Tsink-max Tcase Tjunction C C C C N2 0.3% 14.8 W 49.5 49.6 49.6 77.9 N1 0.3% 14.8 W 48.6 48.9 48.9 74.4 N3 0.3% 14.8 W 49.1 49.3 49.3 75.5 P2 0.3% 14.8 W 49.5 49.6 49.6 75.9 P1 0.3% 14.8 W 48.6 48.9 48.9 72.3 P3 0.3% 14.8 W 49.1 49.2 49.2 75.5 Report
November 9, 200818 yr comment_174323 Are you sure you want to push them any harder? I mean seriously, how much of a space heater are you trying to create? Report
November 10, 200818 yr comment_174608 I'll be making solid wood face panels for these big boys. Maple with Pink Ivory heart shaped inlays. Marc did you want little Purple Heart daisy inlays as well? No extra charge. Report
November 12, 200818 yr Author comment_175092 just bought some metal online. If anyone needs to buy from onlinemetals.com, let me know and I can send you a discount coupon as part of their refer a friend. It's an additional 5% off, which is added to their 5% discount for signing up and the 10% discount for material orders over $100. Anyways, here's what I got: Aluminum 6061-T6 Bare Extruded Square 0.375" Cut to: 11.8425" 8 @ $1.66 Aluminum 3003-H14 Perforated Sheet Round Hole 0.125" Thick (0.5" dia. holes) 0.6875" stagger Cut to: 12.0457" x 5" 4 @ $10.84 Aluminum 6061-T6 Bare Extruded Rectangle 0.375" x 2" Cut to: 4.25" 4 @ $2.55 Plastic Teflon Virgin NATURAL Extruded Round 0.8125" Cut to: 12" 1 @ $9.03 Plastic Acetal Black Round 1.375" Cut to: 12" 1 @ $9.29 Report
November 12, 200818 yr Author comment_175095 oh, and before you ask what the last two items are for.... Report
November 12, 200818 yr comment_175175 Building your own sex toy belongs on another forum! Aerius' forum. Report
November 13, 200818 yr comment_175180 Which parts of the plastic virgin are teflon and which parts are natural? At least she'll be warm Report
November 13, 200818 yr Author comment_175200 Which parts of the plastic virgin are teflon and which parts are natural? At least she'll be warm as long as the black Delrin rod doesn't get involved. Report
November 13, 200818 yr Author comment_175311 so, does anyone need anything anodized black? I found a place to do it locally, but requires a minimum order of $100... Report
November 13, 200818 yr comment_175333 so, does anyone need anything anodized black? I found a place to do it locally, but requires a minimum order of $100... Oooh... could in the future, but not right now. Report
November 20, 200817 yr Author comment_177073 this is the general idea... the heat sinks totally dwarf that big Plitron Report
November 20, 200817 yr comment_177076 so, does anyone need anything anodized black? I found a place to do it locally, but requires a minimum order of $100...Yes. Report
November 20, 200817 yr comment_177083 Yes. So you're the one that bought the chrome plated PS-1s. Report
November 20, 200817 yr comment_177101 No, I just want something -- possibly several somethings -- anodized black. Report
November 20, 200817 yr comment_177113 No, I just want something -- possibly several somethings -- anodized black. It would probably be a bad idea to anodize your penis. Just thought you might like to know. Report
November 20, 200817 yr comment_177123 this is the general idea... the heat sinks totally dwarf that big Plitron Heatsinks look undersized to me. Report
November 20, 200817 yr comment_177237 Those are some manly heatsinks! Curious as to what type of topology you are using for this amp... I have a ton of these devices and no set design yet. If you still have a referral to onlinemetals I could definitely use one for an upcoming copper sheet purchase. Report
November 20, 200817 yr comment_177277 Heatsinks look undersized to me. Yeah and John Holmes had a small pee pee. Report
