Yeah, that plug is why I used the Woo on the XPM - no other use for it in comparison.
  • Replies 5.4k
  • Views 1.5m
You built that by hand :eek:
That some seriously good work guys.
I remember seeing it on HF thinking you sent away for them to be machined, they looked that well done.
They were machined...machined by Dr. Wood. ;) And thanks for the kind words, your free headphone stand will be shipped soon, as per our agreement. :P
Well, now we know who sells them in the US, Al! :)
Very cool! 40th Birthday present for yourself?
precision automation is such a wonderful thing...
http://gilmore.chem.northwestern.edu/ampbars.jpg
That is enough for 4 amplifiers, left another 8 at work, on monday
the same thing except 10 inches for the power supplies...
Heatsinks will be in house in about 3 weeks, program already written and
tested on a hunk of wax...
Then the front/back panels after that, then the circuit board order.
Top and bottom panels are a no brainer.
How do you test heatsinks on a hunka wax?
Ya test the gcode on the wax, not the heat :D
I'm picturing him molding the heatsinks out of wax -- :D -- but seriously, I know that's not right:
1 - what would he use for heat sources? He's not going to waste real components on that.
2 - it wouldn't work anyway -- they'd melt starting at the heat sources, rather than at the fins.
So seriously -- what is he doing -- does he already have the heatsinks molded, and he's putting a wax film on it to make sure the heat is getting dissipated evenly?
The heatsinks need to be drilled and tapped by a computer controlled mill.
He uses a similarly sized (to the production heat sink) block of wax to test the drilling routine he has made.
Dr. wood, i know you can do a better job.
Well unfortunately I don't have a resaw ATM. And my planers lowest setting is 1/4". I'd need to find a source for 1/16" exotic stock.
I suppose I could use veneers, but it would change the look slightly (more and thinner layers).
And the companion amplifier to the T2, the SRX circuit as built by stax
(the $12k thing) with help from you know who.
Option of the caddok completely non-inductive plate resistors, or the T2 current
source.
Fits in the same size chassis with the same size power supply boxes...
http://gilmore.chem.northwestern.edu/staxsrx2-1.pdf
Could be under $2500 in parts total with the good sockets and the DACT.
Blows the crap out of the ES1/2...
Got to go to a meeting, will glue the pdf's together later...
Especially with the caddok current sources, this one is a complete no-brainer
to build! Hardly any parts.
Got to go to a meeting, ...
Excellent. ;)
atempted delivery today of 346 lbs of heatsinks. I was not home, and not
notified that it was coming. Redelivery thursday... :(
There aren't enough 'eek' smileys on the whole internet to cover that one.
@@ I wonder if the guy wheeled it to your door before checking if you were home~
