spritzer
Thanks guys, it's my first soldering project. My friend did the soldering on the first one. We put the boards in the cases today and made a bit more progress. Slow and steady.
Really glad we tested all the transistors this time because we found one shorted k216. Troubleshooting that would have been a hassle.
Ah, my memory is fading :) I'd probably put it under a load and see what the voltage does. Also, check the voltage right after the first cap, check to make sure the ripple voltage isn't insane. Check the same after the regulator. Compare to the other rail.
Edited by luvdunhill
