August 22, 201016 yr Dinny I like the Belkin case quite a bit but I am no longer using it since getting the Defender case, If you would like to try it out let me know.
August 22, 201016 yr Thanks Jeff. The Defender case is a possibility, too, I guess. If Jack breaks this iPad, he's going to have to find a new place to live. Colin will have to take him in.
August 22, 201016 yr Not sure if anyone is interested, but I was able to use my Ipevo Free-1 (a corded USB Skype phone) with the ipad USB adaptor and Skype app. Of course, you can just use it to communicate, not for choosing contacts, opening the skype app, etc., like on a Mac or PC.
August 24, 201015 yr I cannot use my ipad upstairs in the bedroom unless I am sitting at the foot of the bed - obviously that is not the most convenient setup - because the wireless signal is too low. I have a two story house, my router (Linksys WRT54G) is downstairs, the bedroom is upstairs and at the other end of the house. I don't want to move the router because it is hardwired to the tv and PS3. I can use my laptop in bed, just not the ipad. Do you think it would be best to get an Airport Express to extend the wireless or get an Airport Extreme (or both). I think I remember reading that 5Ghz doesn't work as well as 2.4Ghz signals in a place with a lot of walls, but that could have been a bunch of BS.
August 24, 201015 yr My fairly new linksys had definite range problems before it got killed by our power issues but my new Airport Extreme has amazing range. I typically can still see the thing quite a ways from my house.
August 24, 201015 yr The Airport Extreme (one from about a revision or two ago) had a really great range compared to Linksys routers I had previously or the Actiontec router (I need to use it for FiOS) I'm using right now. With the Extreme, I never saw a drop in signal strength throughout my house, out in the yard, or at opposite end of the house down in my basement. With both Linksy and Actiontec routers, I saw/see drop in signal strength, though not enough to cause any issues.
August 24, 201015 yr OK, seems like Extreme is the way to go. I like the idea of connecting a harddrive to it. (Not sure that this is possible with the Linksys.)
August 24, 201015 yr Our Extreme is great and I am not even current on the model. Planning to be fully up to date when I finally set up NAS.
August 24, 201015 yr I cannot use my ipad upstairs in the bedroom unless I am sitting at the foot of the bed - obviously that is not the most convenient setup - because the wireless signal is too low. I have a two story house, my router (Linksys WRT54G) is downstairs, the bedroom is upstairs and at the other end of the house. I don't want to move the router because it is hardwired to the tv and PS3. I can use my laptop in bed, just not the ipad. Do you think it would be best to get an Airport Express to extend the wireless or get an Airport Extreme (or both). I think I remember reading that 5Ghz doesn't work as well as 2.4Ghz signals in a place with a lot of walls, but that could have been a bunch of BS. Shelly, I had the same problem years ago, and ended up getting a second WRT54G for the first floor of my house. It's worked well, but it was a pain to configure. I can't even remember how I did it - I had tech support on the phone and they walked me through it. I'm very interested to know if the Extreme resolves your problem for future reference... if one of my current routers dies, I'd prob look for a new solution like the Extreme.
August 24, 201015 yr If you have tomato/ddwrt on the 54G, you can boost the output power by quite a lot.
August 24, 201015 yr OK, seems like Extreme is the way to go. I like the idea of connecting a harddrive to it. (Not sure that this is possible with the Linksys.) Keep in mind hard drive sharing on Airport is rather slow. I was using it to share between my Macs and wife's Windows machine but eventually gave up since its performance got to be too frustrating.
August 24, 201015 yr Wireless routers are often recommended to be placed on the upper floors to have the best range. If you get the Extreme, maybe you can place it there?
August 24, 201015 yr If you have tomato/ddwrt on the 54G, you can boost the output power by quite a lot. I had read about that, but also read that if you don't really know what you're doing, you might brick your unit. True?
August 24, 201015 yr I had read about that, but also read that if you don't really know what you're doing, you might brick your unit. True? True. That is also true anytime you upgrade your firmware, stock or DDWRT. If you can follow the instructions to the letter and don't skimp on the time needed to power cycle properly in the instructions, should be fine.
August 24, 201015 yr I put in an airport extreme yesterday as the WRT54G and Belkin Play routers were crappy with range and holding a signal. Fingers crossed the extreme will do a better job.
August 24, 201015 yr Wireless routers are often recommended to be placed on the upper floors to have the best range. If you get the Extreme, maybe you can place it there? I would prefer to keep the router hardwired to the main tv/ps3 which would require them to be on the first floor. Smeggy: I would be very interested to hear how the Extreme works out for you in terms of range. Edit: Just saw the thing about tomato/ddwrt since my parents also have a WRT54G.
August 24, 201015 yr Author My Extreme didn't help the range over the previous crappy D-Link or a Express, but it sounds like others have had better luck. For those curious of a laptop conversion case was ever going to make it to market... KeyCase iPad Folio packs a Bluetooth keyboard, scores FCC approval -- Engadget
August 24, 201015 yr My Extreme didn't help the range over the previous crappy D-Link or a Express, but it sounds like others have had better luck. For those curious of a laptop conversion case was ever going to make it to market... KeyCase iPad Folio packs a Bluetooth keyboard, scores FCC approval -- Engadget But you lived in a cave.
August 24, 201015 yr I added an Airport Extreme a few weeks ago. It's up in the back bedroom of the townhouse and it has definitely improved the range over our previous DLink 802.11g. Before the change I couldn't use my MBP on the deck, now I get full bars.
August 25, 201015 yr Saw that folio case at the mac store yesterday when I got the AE. Didn't take a close look at it though as it was behind the counter on a shelf.
August 25, 201015 yr Ric: Is there something about your setup that might explain this (besides living in a cave).
August 25, 201015 yr I was across the street in my neighbor's driveway and I had a perfectly good signal from my Extreme.
August 25, 201015 yr The extreme solved both the range issues and the intermittent dropping I had with Belkin POS. The Belkin was Aldo an N router and I still get better coverage with the extreme.
August 25, 201015 yr I have two older Extremes, one running 2.4Hgz 802.11b/g for older gear, and one at 5Ghz 801.11n for all the Macs, Apple TV and Airport Extremes. I love the Airport Extreme's long range. I have both in our loft in the center of the second floor, and I still have good coverage at both ends of the basement (Home Theater at one end of basement with PS3 and Wii online, and the main headphone rig at the other end of basement with Airport Express > PWD).
August 25, 201015 yr So far so good. Were getting good signal strength everywhere and it hasn't pooped out yet, though it does run hot compared to the other routers I've come across, also a lot heavier. One oddity, I couldn't get my hdd to be recognized with the AE, if I connect it to my WD WINTV live that's attached to the Ae it's fine *shrugs* All in all, not too shabby. I have the mini plugged into the AE and i turned off the 'G' airport on the old mini and it runs my vnc quite well via iPad. Nice and snappy, even playing flash video. I'll probably get a USB N stick later for it.
