Squeezebox Touch
Maybe I should try using this thing again. I used it once and got mad because of network security stuff at the office and never turned it on again. I hope the server software upgrade also upgrades the terrible on device server software as that was a pain to use with attached memory cards.
  • 2 months later...
  • Replies 243
  • Views 76.2k
  • Squeezebox Touch + M-Audio BX5a = instant music setup for garage work table and record cleaning area. Nice.
  • I'm going to try to get more information from Logitech UE on this.
  • Here's a little treat for the faithful   Add this as an internet radio Tune in URL   http://72.26.207.67:8014/   Save as a favorite   More details ...   http://forums.slimdevices.com/showth
Sorry for the long bump...my touch detects and SD card just fine but when I plug in my portable USB drive it doesn't sense/detect it whatsoever. It's a basic WD 250 gb portable thing, I believe formatted in FAT32
If it is USB powered, perhaps it is not able to spin up due to power draw issues? I have a Seagate portable unit that would sometimes flake out with my Squeezebox Touch, but works perfectly from my docking station's USB port.
Oh, and I'm not sure what disk format the Squeezebox requires, but I would strongly recommend reformatting to something other than FAT32. I do know that NTFS is A-O-K.
Edited by Beefy
I should add...... you should be able to hear and feel the drive spin up when plugging it into the USB port, so that one should be quick and easy to check.
I could never get a hardrive plugged straight into the Touch to work 100% of the time with the hardrive sizes that hold my entire music collection. Sometimes it would work, other times it would fail to recognize the drive. Maybe things have improved with the many firmware updates, but I stopped trying and stick to my dedicated server.
I gave up as well. Mine has been unused now since about the second week I owned it.
FWIW, I now use an AC-powered 320Gb USB drive, and it is 100% reliable. Admittedly, it is a bit of a chore to disconnect, copy music on, then wait for a re-scan...... but for me, the USB drive is still better than running the server on a separate PC all the time.
That's too bad about the USB drive not working well or consistently with Touch. That was the only reason I was thinking of replacing my good ol' Squeezebox 3 so I don't have to have a computer running as a server for it all the time.
I use mine with a server and just have it do Wake on Lan so the server is asleep all of the time (draws about 4 watts when sleeping). It's about a 1 min delay on start up but that way I get everything backed up to the cloud with Backblaze etc.
Edited by Dreadhead
^ I'd forgotten about wake on LAN. I'll see if it works with my old iMac, which is acting as the server right now.
EDIT - And, of course, my ancient iMac can't wake on network access over wireless. Argh. Perhaps it's a good thing it's screen's slowly dying.
Edited by Salt Peanuts
If you are still interested in using the touch with an external USB drive, the best thread I have read on the matter is
Touch with USB drive : mastering TinySB Lots of useful info. Of particular interest are Treepleks Posts Where he describes how to use the SD card (or usb drive) filesystem as extra virtual memory / swap space. Impressive. Hopefully someone can configure it as an app , so it will "just work" and you wont have to brush up on your command line skillz.
I have read that the Touch doesn't work very well with high amount of albums over the lan with the search and listing being laggy, is this true for the last version?
Edited by Spychedelic Whale
Do you have to keep paying the 4$ a month to keep having access to the files uploaded or only to upload new files ?
I have about 2,000 "albums" and the Touch sees them fine over wifi.
it's cloud based backup hosting so you're paying for both access and hosting. That said you don't have to worry about losing your files for any reason short of a major war or massive internet attack
That's nice, I read somewhere that it was only good if you had the computer next to you so you can make playlists.
I guess its better than to buy 4x2TB drives but if I don't pay one month for some reason my data is lost ?
They sell off your data to the highest bidder on that new show "Internet Storage Wars"
I'm assuming that they have some grace period but I don't know. I assume you can check their FAQ. I signed up when my Drobo had a error and stayed on with the fan off and ate one of the hard drives, I had images of losing all my family photos and the $ is worth the peace of mind. As an added benefit I can now pull down my lossless audio files from work so I don't need to remember to take my portable drive home.
ok got my SB today, I'm adding music to the library but this is ridiculously slow. Taking about 5 seconds per album, isn't possible to use another 3rdparty server that interacts with foobar library for example ?
How are you 'adding to the library'? If you just point the Media Server to your directory it should be much faster. Even over LAN.
You will only need to scan your library one time. Subsequent scans whenever you add music to it will be faster, as it only scans for new music.
Careful, while it's true that you can have it setup to only scan for changes there's also the option to do a full scan each time (IIRC). I always make sure that I have it setup to only scan for changes to avoid the long scan time debacle.
