September 21, 201412 yr comment_653335 Greetings Mario, There are many people much more qualified to answer your question here, but I'll give it a shot anyway since my tastes and expiences somewhat echo your own. I currently own SR-007Mk2's and have have owned 303's in the past. I have heard a lot of 007Mk 1's. The Mk 1 has a subjectively more even and neutral overall presentation. The Mk 1 responds best with solid-state or very neutral tube amplification. The Mk 2 has a bit of a mid bass bump and a slightly more forward presentation. The Mk 1 is preferred by most here, but the Mk 2 is a very fine headphone in it's own right. With some amplification (primarily tube) the Mk 1 can sound a little recessed and dark. I build tube amplification and listen to rock music. In my system I actually prefer the Mk 2. I also prefer the Mk 2 to the LCD-3 ( also a very fine headphone), which I also own. I was very fortunate to get a one time shot at a brand new U.S. Mk 2 with warranty at essentally a used price. Like you, I was hesitant to purchase a 10 year old headphone in unknown condition for the kind of money we're talking here. Many of the Mk 1's I've seen at meets are starting to show their age. If you ever need new drivers from Stax, they will be M 2's. If I had to pay full list priceI for the Mk 2's i might have made a different decision, but I have no regrets and greatly enjoy my Mk 2's. Report
September 21, 201412 yr comment_653340 FrankCooter, Many many thanks! Tried to thank You, but since I am a noob/novice, can´t. I need to say that is exactly the words I was hoping to hear. Most important, that regarding LCD-3! Only bummer is the fact that it is almost sure I´ll need to get a new and full priced Mk II, ´cause the logics involved for my purchase are somehow troublesome. Many thanks again. Report
September 28, 201411 yr comment_654340 Cheap http://www.ebay.com.au/itm/The-left-driver-with-the-complete-earcup-for-the-STAX-SR-Omega-headphones-/301323615644?pt=UK_AudioVisualElectronics_HomeAudioHiFi_Headphones&hash=item4628497d9c Report
September 29, 201411 yr comment_654502 A cyclops with one ear, hmmm! novel. I wonder if the ear is opposite the eye, so that it can hear what it can't see.......... Report
September 29, 201411 yr comment_654504 Sounds plausible... In Stax news Kevin felt I didn't have enough stuff to work on so he's sending me his Single Power ES-2 to rebuild. I said hell no to those crazy transformers Mikhail used so I can come up with a whole new PSU design. Should be fun and a whole crapload of work. Also the Chinese KGSS clone came in from a loan with the volume control busted. Had to spend some two hours yesterday rewiring it completely but now it works perfectly and some people will not get it back on loan... Report
September 29, 201411 yr comment_654509 How you guys find time to test circlotrons inbetween repairs and modifications is totally beyond me Report
September 29, 201411 yr comment_654516 so he used something else completely different than those Plitron on the ES-1? Report
September 29, 201411 yr comment_654518 Nope, he used the Plitrons but they are just stupid. Heavy metal casing and who needs two 285VA transformers for that amp? Makes no sense when one 300VA unit is utter overkill. It will get custom made PSU too with the C- built in and everything crammed into one box...because fuck you Mikhail. I don't need an amp that is that heavy and almost a meter tall. Report
September 29, 201411 yr comment_654519 at least the es2 is a sealed power supply box. my es1 has 2 large holes in the power supply box. Report
September 29, 201411 yr comment_654527 Moar holes is better... Not sure what I'm going to do with the ES-2 PSU box. I'll find some use for it befitting the name on the front... Report
September 29, 201411 yr comment_654533 so birgir is a little bit off. With Justin's rubber feet The whole thing is 18 inches x 18 inches x 25 inches from the bottom of the power supply feet to the top of the tubes. yikes. USPS finally has pulled their heads out of their asses with slightly slower shipping for packages over 25 lbs, for a bunch less money. So only $165 to ship the brick of aluminum to Iceland. And it was over 51 lbs. Previously to ship T2 chassis which was 34 lbs was about $225 When he is done with this one, I will ship him the es1 I have. With the transformers. Then the only monster I will have left is the SS1 which is such a complete clusterfuck... Mikhail certainly was entertaining. I wonder who ended up with the gold plated sds-xlr? Edited September 29, 201411 yr by kevin gilmore Report
September 29, 201411 yr comment_654536 Mikhail was entertaining. Woo has some of that same epic fail but from them we get zero creativity, just crap engineering. Report
October 4, 201411 yr comment_655174 So I plugged in my 009s for the first time in a few weeks and there was a squeal in one of the drivers. I unplugged them right away. I'm guessing my only option here is to send them in to Yamas/Accuphase/StaxUSA or whatever else they call themselves now? I bought them back in 2011/12 when the first came out so I highly doubt they are still under warranty. Report
October 4, 201411 yr comment_655175 What kind of squeal? Are you sure it's the headphones and not the amp? I can't imagine a reason for them to develop a weird noise or failing. Report
October 4, 201411 yr comment_655176 I'm pretty sure its the 9s, but I'll see if I can wrangle up a second pair of stats just to be sure. The squeal is low volume and high frequency. Almost like the chittering of an insect. It is only on the right side. Both sides can still play music but the squeal is there regardless of whether music is playing or not as long as the 9s are plugged in. Edited October 4, 201411 yr by TMoney Report
October 4, 201411 yr comment_655177 Pretty weird indeed, but still it sounds to me more like an electronics issue than a drivers' one. Report
October 5, 201411 yr comment_655247 I'd be betting on the amp. Have you checked the output balance on the offending channel? Try it on both DC and AC voltage. DC voltage to see of the balance is close to zero and, AC voltage to see of there is some parasitic oscillation going on. If you can hear it, the meter should pick it up. Report
October 5, 201411 yr comment_655266 It could be a noisy pot in one channel but this sounds a lot like driver squeal. Report
October 5, 201411 yr comment_655271 The squeal? Dust or some debris inside the driver making a partial short between the diaphragm and stator causing the diaphragm to oscillate. Report
October 5, 201411 yr comment_655272 I thought dust as well. You said the cans have been in storage for a while yes? Unused? Report
October 5, 201411 yr comment_655277 The squeal? Dust or some debris inside the driver making a partial short between the diaphragm and stator causing the diaphragm to oscillate. I thought dust as well. You said the cans have been in storage for a while yes? Unused? I'm fairly certain this is what happened. They've been sitting on a high shelf unused for a few weeks. Is there anything I can do about dust/dirt other than send them in for servicing? The 9s seem quite a bit more difficult to take apart than the 7s. UPDATE: Testing the dust theory, I unplugged them and sprayed some compressed air at the offending driver. Problem solved, I think. The squeal is gone. Edited October 5, 201411 yr by TMoney Report
