November 23, 201214 yr comment_547657 I also agree, Jeff, but I still want a flavor report. Mike, did you Traeger your pies? If so, same goes for you. Final product ready for slicing: Report
November 23, 201214 yr comment_547664 No, baked in the oven. Here is all I have left to photograph: Report
November 24, 201214 yr comment_547737 The ham was really tasty! Faxing leftovers soon. I used the holiday ham with mustard sauce recipe on the Traeger website, but I skipped the mustard sauce and my ham was only about 4lbs so I halved it. I injected the brine and the mop into the ham to make sure the flavor penetrated and it worked well. Turned out juicy and with great flavor. Will definitely do this again with a larger ham. Report
January 5, 201313 yr comment_555069 Doing some ribs this morning. Two hours in. Edited January 5, 201313 yr by VPI Report
March 11, 201313 yr comment_565330 Decided to try to improve upon the French Laundry Sous Vide Brisket by finishing it up with a bit of smoke on the Traeger. Turned out pretty good but I think I am going to go for a full Traeger smoked brisket next time. Report
May 8, 201313 yr Author comment_575253 My first attempt at Tri-Tip, Santa Maria style. Perfect medium rare. 135F at the center. Did a reverse sear method. Started at 225F with Lots of apple wood smoke. Might try heavier smoke wood like Hickory later. Tri-Tip is so lean, I'm not sure how well it will hold up to full well done smoking, to get more smoke. This cook was very short, too short for any kind of smoke ring. Maybe it's only possible with Brisket. Either way, it will make for some awesome "roast beef" sandwich leftovers. Overall, I like Tri-Tip this way better than just straight up NY Strip Steak. Cheaper and lots more quantity for the same amount of grill time. This cook, the tri-tip was super juicy. Had I to do it over again, I'd get a Traeger and a cheap ass Weber Kettle Grill. It takes forever to get a steady stream of thin blue smoke with my Keg set up. There's just something about just pressing a button and walking away. Sigh. Heheh, if I find a decent deal on a small Traeger, I might have to get one anyways. A Keg + Traeger takes up the same amount of space as a Weber + Traeger. Sure my wife would bitch about it at first, due to more of my shit eating up precious real estate, but she'd quickly stop complaining when the food keeps on coming. Report
May 10, 201313 yr Author comment_575779 I mean Cheap as in relatively speaking. Dem Green Eggs and Traegers are spendy. Report
May 11, 201313 yr Author comment_575926 I'm just envious of the one touch, push button operation of the Traegers. Plus, one doesn't need a fancy grill to get an insane inferno going for high temp searing. Granted, it's far quieter to use my Big Steel Keg set up on my balcony than a Traeger. Also, the auto temp controller uses very little power, and the Keg is very efficient and uses very little charcoal. I've actually used a small computer UPS battery to keep the temp controller running during a power blackout that happened in the middle of a long pork shoulder cook. Report
June 13, 201313 yr Author comment_582399 Smoked Tri-Tip, Brisket Style. Going to let it hit 190 and then check. *(decided against foil Texas Crutch this time, never had a problem of drying anything out in my Keg.) I have hickory chunks in the keg, and apple wood pellets in the Smoke Daddy. Edited June 14, 201313 yr by Edwood Report
June 14, 201313 yr comment_582454 getting excited: this weekend i'm going to do smoke two racks of baby back ribs and a 5 lb Boston Butt. should be good! Nice! Report
June 14, 201313 yr Author comment_582478 Just pulled one Tri-Tip at 180, just in case I ruin the other one by going all the way to 195. Definitely not as juicy, but still very soft. And man, way more flavor. Apple wood Pellets worked great, and much more consistent smoke output. I also used the same rub I used for Pork, worked really well. I love that stuff. Maybe I'll add more chipotle chili powder and black pepper next time. I'm ready for Brisket now. Although, I really like how versatile Tri-Tip is. It can be cooked like steak with roast beef like leftovers, or cooked brisket style, for smokey awesome flavor. Edited June 14, 201313 yr by Edwood Report
June 14, 201313 yr Author comment_582488 Yep, 195 is too far for Tri-Tip. Not ruined, but the one I pulled at just under 180 is much better. Probably best to pull it at 175 at most for this style. Probably 170. Got some fantastic sandwich leftovers now. By the time MOA4 comes around, I should be pretty proficient with Brisket, so is it possible to fit a brisket or two, with two butts at the same time in Al's Traeger? The smoked meat should last a little longer next time. Or maybe just all brisket. It's more expensive, but it's easier since there's no pulling with the Bear Claws. Report
June 14, 201313 yr comment_582492 Bear claws are awesome. Anyway, brisket is Mike B's specialty do you will have to consult. Easily can smoke two briskets and two butts or four of either. Let's try! Report
June 14, 201313 yr comment_582496 Well because of MOA East. And because MOA Proper sounds funny. And ackshully, now that I think about it, "MOAE" sounds a little too much like "meowy"... Report
June 14, 201313 yr comment_582499 MOA Classic?, The Original and Best, Accept no substitute? The Ultimate MOA?, You'll know when you've been MOA'd?. Please Sir, Can I Have some MOA? I Can Haz MOA? Report
June 14, 201313 yr comment_582563 I wish brisket was my specialty. It's a tough cut to master and I'm not there yet. I think I will do a brisket and butt for dinner Sunday. Nice tri-tip Ed. Report
