What are you Grilling now?
pepper should be added after it's grilled, as it just burns at the high temps that a good steak sear requires.  this was process only.
^This.  noticeably less bitter tasting this way.
For steaks I prefer the reverse sear method.  Takes much longer, but it allows me to prep a steak the night before and then cook it directly from the fridge (since I'm smoking it, the colder the meat is the better).  I smoke it at 225F until it reaches about 115-120F in the center, and then remove the steaks.  Crank the vents on my grill to get it raging hot, at least 600F, with my lowered cast iron grate near the coals.
  • Replies 899
  • Views 205.3k
  • I did sous vide picanha for the first time today. A simple rub of spices, smoked salt and olive oil, then cooked in the bath at 133F for 6 hours. The 'grill' part comes from very briefly finishing on
  • shellylh
    shellylh
    Having an infrared side burner on the grill is pretty fucking awesome. Thanks for the tip Marc. Indirect heat @225F for 30 minutes and then a 30 second sear per side on the infrared burner.
  • Smoked chuck roast. Much better than I expected. And a great excuse to use plenty of horseradish cream sauce.
  • 2 months later...
Speaking of ribs, some St. Louis Ribs I did a few weeks ago.
Bourbon Sauce.  Yes, I used nearly the entire bottle.
two limes
couple stocks of Rosemary off the back porch
fresh oregano
Mint
Thyme
good slosh of Olive Oil
salt and pepper to taste
all chopped up and sealed in vacuum seal for about 1.5 hours..
Grill super hot... eat... nap....
Edited by mikeymad
A Tale of Two Alcoholic BBQ Sauces
One Savory....
One Sweet...
Both kicked up a notch.
The Stone Smoked Porter with Vanilla Bean Sauce is mostly Beer, Butter, and Hot Sauce. (1 cup of Beer)
The Bourbon Sauce is mostly Bourbon, Ketchup, and Molasses.  (3 cups worth of Bourbon)
Oh, and the Glenrothes is not used in the sauce, it's because the Bourbon Sauce takes the longest to make, about an hour and a half at least.
Grilling some ribs for a Head-Case BBQ in Mayberry.  Ribs spicy and sweet when they went onto the grill and then after an hour of smoke.
Mmmm, awesome looking ribs, I have Traeger surface area envy.  :D
Memorial Day Brisket prepped for the smoke tomorrow.
Check out that Prime marbling in the Flat area.  Wow.
Not quite as pretty after being trimmed, injected, and rubbed.
... trimmed, injected, and rubbed.
Sounds like a massage parlor menu.
Looks awesome you HC BBQers.  Will be marinating some beef tonight and hoping for a similar result tomorrow.
