- Past hour
Muchas gracias, chicos A nice day. One year less to retirement. So tired…
No idea as I've never had a broken set here to experiment on. Based on this set the coating is definitely helping and I'm about 85% balanced now. The plan is to rewire them and see how much that changes. I'm not a fan headphones being out of phase in general, I always reverse it on HE60's when I work on them as they are also wired out of phase from the factory.
- Today
Tom Lehrer, song satirist and mathematician, dies at 97. Also, Tom Lehrer was still alive.
The Quiet Melodrama of Todd Hido https://aperture.org/editorial/the-quiet-melodrama-of-todd-hidos-photographs/ -
I should have more than enough left over Baltic Birch plywood for a splining jig accessorie and even more. T tracks, hold downs (another set of hold downs packaged with the long T track), knobs and a stop. All of this will make more sense once the jig is completed. Plenty of leftover Black laminate (I assume from the chop saw station), and some Ipe to build the bridge part of the jig, that will overlay the existing SawStop fence.
Brother came up this morning on his way to his place in NH. Dropped off 2 bottles of Ardbeg 25, plus additional surprises! The Ardbeg 25's come in a lovely Russian Doll type box set, the inner box has a nice metal design on it. The top of that inner box looks to click open and close on a hinged cover. The Smokiverse is another limited edition, this was an open bottle from a sampling day that one of his clients had. Looking forward to trying it, there's only a tiny bit left.
kuruk787 joined the community
myleftear joined the community
Happy birthday/Feliz Cumpleaños, my friend! (ruido de favores de fiesta)
You can't plug normal bias headphones into a Pro bias output, that will just blow them up even on trash like the D10. If it is just the plug you want to modify, no you'd need to connect the left side bias somewhere in the cable as it is only connected to the center pin.
Happy birthday!!
Cheers Antonio -- Feliz Cumpleaños! Happy Birthday, wishing you a great day -
Happy Birthday Antonio!
Happy (non AI generated) Birthday, Antonio!
Hi,can I "convert" my 6 pin male plugs to 5 pin (pro configuration) simply by removing the centre pin or will it destroy the whole set up? ( Got a pair each of old SR-5 and Gamma ). Want to reconfigure them for Stax SRM-D10. Asking for a friend...
guzziguy replied to Knuckledragger's topic in Off Topic
Saw this in a local parking lot. The first thing that came into my mind was "at least it looks a little better". -
Happy Birthday, Antonio!
Happy Birthday, Antonio! Make it great.
Happy Birthday Antonio!!
