This stream auto-updates
  1. Past hour
  2. That sounds delightful. I've only made the traditional spaniard ones with the toasted almonds in the center. HS
  3. Today
  4. Are you OK? That tirade would have to be the least intelligible one I've ever read. Maybe a giant and calm edit would improve it so I (and probably many others) could understand what your point is.
  5. Long post, ADHD warning, am old school. With respect to the usual suspects and in danger of disrupting the circle-jerking? Which, by all means, keep at; The 007 variants were as non STAX as they could possibly get. - Certain people that would have found nirvana(tm) decades ago if only they'd bought a certain Sony, or specific Fostex/Audeze/Rosson headphones? They elected not to. Went the hard way (read: "i ride the different rain", read: i just must spend more, read: i feel so refined), when all they'd have had to do was find the chain that would be best for said type of headphone; and between interface/transport, DAC, pre-amp, amp and cabling, it does exist and in infinite variations. Only of course, they do not "believe" in chains, or do not "believe" in the need of a pre-amp, or do not "believe" in cabling, or, reasons. And instead, we're.. here. For nigh two decades now, congratulations One headphone gave them something they'd not heard before; but only because they were clueless, blame's on them for sheer ignorance. Put differently if it helps, not sure when people needing anything (insert adjective) low end pronounced or focused went for STAX? I mean, since when exactly? That's right, since never, not until that accursed thing came out. And sadly it sold well rather than flopping; sadly, because it showed, even to STAX, where the curve is. And i do blame each and every one for re-inforcing said conclusion (be it due to ignorance or monetary gain mind, yeah?). Find a few people with big pockets, there you go with the trend shifting, just like that. There were, are and shall remain many, many headphones for those folks, but.. they're not niche now are they. Where's the class, the individuality if you will.... if only you knew how many times i've seen this. Four+ decades and three continents over by now. - Contrary to elitist, individualistic, circle-jerking-focused belief? The world does not revolve around you. Sorry to break it to you. Head phones requiring significant power, ergo headphones that require significant investment in amplification, are headphones most folk cannot buy, not if they know what they're doing (and folks usually don't, not even here; i do read). The money involved to do it right is just prohibitive. You can have a halo product or two, as it drives sales all the way down, but you need a realistic approach. What you're wishing for would close STAX down, not help it grow back up; may not seem so in this glass bubble of a virtual corner, but out there, that's where it'd lead. Competition in what you're after is beyond fierce and they're too old to play the social media hype game. Entering the rest of the issues STAX faces, because those exist, yes.. nothing to do with 007 however, nothing at all. Kindly keep it real and differentiate your bloated self-want from the expansive reality governing one entire ecosystem. Kindly. Just because someone needed to say it. I mean we read your posts, if once in a while you get to read ours, yeah?
  6. Sorry for the double post, everyone. I was curious how one sources AEO-7. Here in the US it seems very hard to get since most chemical manufacturers will only ship to industrial buildings and labs. It's not like I'm trying to buy a 1 ton drum of the stuff but alas.....
  7. Bacon wrapped, Goats Cheese stuffed (pitted medjool) dates.
  8. I'm really thinking that they "gimped" the 007s design on purpose.... They moved away from the gold plated fiberglass electrodes to what appears as aluminum electrodes just like 009 and Lambdas. The outer area that was solid on the previous iterations of the 007 have also been reduced probably to reduce capacitance, but this decreases the damping on the membrane. I'm sure that the new 007 probably presents with a degree more of that midrange "rising response" that we see on nearly all the other STAX using similar design philosophy and brighter treble. The pads now resemble the dimensions of the 009 especially with the uniform opening. I think that a big part of the 007 sound was the D shaped pads which would distribute front volume modes better than a uniform circle.... The 007 was a distinct tuning in the line-up and they for reasons only known to god put it in line with the rest... Some sorta 009 lite design. I can't say I really like STAX sacrificing the engineering of their older models for "easier to drive" alternatives that don't sound as good....
  9. Beautiful fare! What did you stuff the dates with, Grahame? HS
  10. I guess he gave up the ghost when he heard Dr. Demento announce his retirement and the end of his show.
  11. Had some friends over. Started with this. Lots not shown. Ended with this. (Ice Cream not shown)
  12. RIP Tom. Listened to him a lot growing up. The Pigeons are safe now...
  13. Yesterday
  14. I'm a bit late but Happy Birthday, Antonio!
  15. Happy belated birthday Antonio!
  16. Muchas gracias, chicos A nice day. One year less to retirement. So tired…
  17. No idea as I've never had a broken set here to experiment on. Based on this set the coating is definitely helping and I'm about 85% balanced now. The plan is to rewire them and see how much that changes. I'm not a fan headphones being out of phase in general, I always reverse it on HE60's when I work on them as they are also wired out of phase from the factory.
  18. Tom Lehrer, song satirist and mathematician, dies at 97. Also, Tom Lehrer was still alive.
  19. The Quiet Melodrama of Todd Hido https://aperture.org/editorial/the-quiet-melodrama-of-todd-hidos-photographs/
  20. EDIT: Penalties! EDIT: Sorry, Antonio.
  21. I should have more than enough left over Baltic Birch plywood for a splining jig accessorie and even more. T tracks, hold downs (another set of hold downs packaged with the long T track), knobs and a stop. All of this will make more sense once the jig is completed. Plenty of leftover Black laminate (I assume from the chop saw station), and some Ipe to build the bridge part of the jig, that will overlay the existing SawStop fence.
  22. Happy Birthday!
  23. Brother came up this morning on his way to his place in NH. Dropped off 2 bottles of Ardbeg 25, plus additional surprises! The Ardbeg 25's come in a lovely Russian Doll type box set, the inner box has a nice metal design on it. The top of that inner box looks to click open and close on a hinged cover. The Smokiverse is another limited edition, this was an open bottle from a sampling day that one of his clients had. Looking forward to trying it, there's only a tiny bit left.
  24. Happy birthday/Feliz CumpleaƱos, my friend! (ruido de favores de fiesta)
  25. spritzer
    Stax plug
    You can't plug normal bias headphones into a Pro bias output, that will just blow them up even on trash like the D10. If it is just the plug you want to modify, no you'd need to connect the left side bias somewhere in the cable as it is only connected to the center pin.
  26. Happy birthday!!
  27. Cheers Antonio -- Feliz CumpleaƱos! Happy Birthday, wishing you a great day -
  1. Load more activity
