February 29, 201214 yr comment_500777 Doesn't appear to have enough relays to be doing a relay-based stepped attenuator. Digital volume control? I'm sure they wouldn't be using a shunted differential pot such as this Report
February 29, 201214 yr comment_500778 The volume could be a shunted pot, right? No clue what they'd do for balance. Report
February 29, 201214 yr comment_500787 I vote balanced to single ended conversion and then back to balanced. Explains the gain and the pot. Report
February 29, 201214 yr comment_500820 That would be plausible but idiots over on HF will not like it... Report
February 29, 201214 yr comment_500829 I'm not sure they are even discussing it there yet. I'll be waiting for the usual "Yeah, Spritzer, we know if it isn't Gilmore, its shit" response when you finally do get a crack in Report
February 29, 201214 yr comment_500830 I just got an email from ttvj, they're selling it now too, $1295 Report
February 29, 201214 yr comment_500838 Think that's an input selector (balanced/unbalanced) not a balance control. If this is implausible or clumsily expressed, please consider the mitigating circumstances. Which are that I'm drunk. Report
February 29, 201214 yr comment_500843 The input selector is a toggle switch to the extreme left of the amp. The small knob is a balance control. I'm not sure they are even discussing it there yet. I'll be waiting for the usual "Yeah, Spritzer, we know if it isn't Gilmore, its shit" response when you finally do get a crack in So fucking true... Still it's a Bryston so it's certainly better than most of the crap out there. Edited February 29, 201214 yr by spritzer Report
September 25, 201214 yr comment_537190 Not to necro, but my BHA-1 finally came in (black, with female XLR connections). The sound so far doesn't suck. I have the manual here; would anyone care for me to upload the included schematic? Report
September 25, 201214 yr comment_537196 Sure, why not. Interesting to see if they claim the amp is truly balanced. Report
September 26, 201214 yr comment_537272 Here it is. Begin analysis! Here are links to my Dropbox in PDF and PNG formats. https://www.dropbox....jxhfoq/bha1.pdf https://www.dropbox....u9vovq/bha1.png Enjoy! Thanks for looking, spritzer, and anyone else who's interested...would be interested in some feedback. Edited September 26, 201214 yr by cutestory Report
September 26, 201214 yr comment_537361 Is it just me or what's the point of this amp? Why on earth would anybody build something like this? So a fully balanced amp except it isn't since the input section is single ended and with only a two gang volume control which then feeds to two amp sections per channel. It's get better though as they capacitor couple the output so one gets to enjoy the sound of a quad of 4700uf/35V electrolytic caps. I truly don't understand this amp or the logic behind it. Report
September 26, 201214 yr comment_537364 Preface with that I may be entirely off base/misunderstanding (on the balanced part): They are using the balanced signal in its original use which is to cancel noise. Then invert the SE signal out and do fully balanced amplification? Report
September 26, 201214 yr comment_537366 There is special stage to do inverting after the volume control. My gripe is that they could just have married a balanced input buffer with a quad pot and had a fully balanced amp. Report
September 26, 201214 yr comment_537367 But then they would not have gotten the noise cancellation right? Or does it just happen at the transducer? Report
September 26, 201214 yr comment_537391 Is it just me or what's the point of this amp? Why on earth would anybody build something like this? So a fully balanced amp except it isn't since the input section is single ended and with only a two gang volume control which then feeds to two amp sections per channel. It's get better though as they capacitor couple the output so one gets to enjoy the sound of a quad of 4700uf/35V electrolytic caps. I truly don't understand this amp or the logic behind it. Would you mind explaining to a layman why this is bad? I'm not a circuit guy, but I understand the bit about the input section being single ended (which does seem silly). It's the "two gang volume control" and "they capacitor couple the output" parts that I'm not groking. Thanks in advance... Report
September 26, 201214 yr comment_537393 But then they would not have gotten the noise cancellation right? Or does it just happen at the transducer? Noise cancellation of COMMON MODE noise happens wherever the phases of the signal are compared. If the phases are compared at the inputs, noise cancellation happens there. If the phases are compared across the drivers that is where the noise cancellation happens. The cool thing with amps like this is you get noise cancellation regardless of whether you use the SE or balanced outputs. With 4-boards in one box amps (icky) you only get noise cancelation when running balanced. 4boards-1box amps also amplify the noise through the whole amp, gobbling up overhead - if you get rid of the noise early (in either SE or 2ch balanced amps) you can improve performance greatly. A 2-channel balanced buffer would be infinitely better than 4-boards in one box. Separate is not equal. Edited September 26, 201214 yr by nikongod Report
September 26, 201214 yr comment_537396 Would you mind explaining to a layman why this is bad? I'm not a circuit guy, but I understand the bit about the input section being single ended (which does seem silly). It's the "two gang volume control" and "they capacitor couple the output" parts that I'm not groking. Thanks in advance... Two gang volume control means it's only stereo. Why they took what is essentially a balanced input stage and then fed it through a stereo volume control and then onto a quad output stage is just odd. Why not go all the way and go balanced through out? As for the capacitor output, this is used to block the natural DC offset of the output stage. This is a common feature in Bryston designs so I'm not surprised but it only takes a few parts to make a servo which is completely transparent (certainly more so than a PSU capacitor) and means the output can be DC coupled. Amps like the GS-X do it like this so more transparent. I do agree with Ari that RCA inputs are often badly catered for but I've all but given up on them anyway. Why bother with them when one can go fully balanced... Report
September 26, 201214 yr comment_537410 The cool thing with amps like this is you get noise cancellation regardless of whether you use the SE or balanced outputs. With 4-boards in one box amps (icky) you only get noise cancelation when running balanced. 4boards-1box amps also amplify the noise through the whole amp, gobbling up overhead - if you get rid of the noise early (in either SE or 2ch balanced amps) you can improve performance greatly. A 2-channel balanced buffer would be infinitely better than 4-boards in one box. Separate is not equal. Does this mean only the balanced output is worth listening to on this piece? Or that the whole thing is junk (relatively speaking, of course)? It also sounds like spritzer says I should be ordering an amp from Justin, which I should think about doing anyway. Report
September 26, 201214 yr comment_537412 Does this mean only the balanced output is worth listening to on this piece? Or that the whole thing is junk (relatively speaking, of course)? No, it means that there should hardly be any difference at all. Which is very cool. Ooh, unless the output impedance is different running SE and BAL. People put WAY too much importance on Balanced amps, especially in high feedback circuits. Report
September 27, 201214 yr comment_537536 Ooh, unless the output impedance is different running SE and BAL. How would one be able to tell this? Volume comparison with SE and balanced cables with the same headphones and an SPL meter? Assuming one doesn't take the beast apart, of course... Report
