DIY cable gallery
Mogami 2534 is a jacketed star-quad? no braiding required? :doghuh:
I always take the jacket off because it's thick and heavy, and I wanted to try the braid since it won't unwind or anything (although I doubt it unwinds anyway).
  • Replies 606
  • Views 263.4k
  • Harvested an old Cardas Headphone cable to make a balanced cable for the HD800. Neutrik 4-pin XLR connectors. The HD800 connectors are from Parts Connecxion and a royal PITA to work with.
  • luvdunhill
    luvdunhill
    Even scarier
  • I made some cotton sleeved speaker cables - going to get them hooked up to my horns which I moved my rack over to the side and as such needed two different length cables… couldn’t find any coconu
The Phantom power cord for heavy duty diy valve amplifiers.
-8 Gauge high voltage conductors, deep freeze treated
-Dark Matter insulation
-Non Proprietary Geometry
-OH YEA! E-DAY Connectors
-Blue Hue to match painters tape on amp
Made a pair of interconnects using some UP-OCC 22ga I bought from Nate. I modified Chris VH's silver IC recipe, using a core of 1/4" polyethylene tubing, and spiraled the wires on 2" turns, wrapped it with teflon tape, then some techflex I had laying around. They are actually more flexible than I though they would be (not bad at all).
I made a headphone cable using the silver IC recipe with some 26ga jupiter cotton-covered copper, wrapped in teflot tape. It was super flexible, but then I realized I couldn't fit the whole assembly through the boot of the 4 pin neutrik xlr. me-> :stick: <-me
Talk about hours of lost time. I'm just using some Mogami w2893 for the 650 cable for now. I'm not complaining ;D
I've thought about using some of the Neotech stuff, but I hate to use any solid conductor bigger than 26ga.
Bummer, that would've been sweet.
Man, just cut the friggen boot and finish it all off with some shrink if you have to. Or is the hard, inner diameter that the cable assembly won't pass through? If so, that's a pretty thick cable.
Yeah, right? Of course, I've already disassembled the whole thing and tried to do something else with it. I ended up just getting pissed off and doing the mogami cable super quick so I could actually listen to music (I sent the cable I had been using to John Broskie as he wanted to try his HD-650's balanced).
  • 4 weeks later...
I doubt that a Germania cable could be topped anyway. Better to just buy from her.
I find the Neutrik XLRs tough because a) I don't have a workspace, so I'm always crammed up somewhere and B) I have the shittiest helping hands on the face of the earth and can never get a good grip/angle.
I need a Panavise. Big time.
EDIT: Nice job, btw, reks.
