The Multi Amp aka Dynalo Mk2
On 21 January 2016 at 11:38 AM, spritzer said:
The Susy needs max 10K so I had to use some of my TKD's.
Hey Spritzer, just wondering, what do you mean by this? Is it a gain/stability issue to use a pot of say, 50K?
Reason I ask is I'm interested in understanding what effects volume pot resistances have on amps - some people say it makes a difference, others say doesn't matter. I've had to replace quite a few old amps that have had 20 K input pots with 50 K ones just because I couldn't source any of the original ones...
  • Replies 1.6k
  • Views 519.4k
  • johnwmclean
    johnwmclean
For a completely different project I have a couple of Chinese ones, via eBay.  Two secondaries are rated at 17.5VA each - so 35VA total.
Looking at the product datasheet for Kitamura, the physical dimesions (including fixing hole spacing etc), the Chinese one correspinds to Kitamura's 25VA, so the 35VA chinese rating looks a bit hopeful.
Gotcha, thanks.
7 hours ago, kevin gilmore said:
susy is low impedance input, so you can't use a 50k pot.
10k pot max!
That is indeed the issue.  The core sizes for the R's are fixed but the Chinese manufacturers don't care too much about that.
As for posting pics, that won't work as out of a batch of two, one transformer might be fine while the other one is garbage.  Some have been truly terrible with dangerous lead wires and truly terrifying build quality.  The bottom line is that I'm staying with toroids for now.
Ok. Total off-topic time.
So, zeroed the four-wire probes. They were 0.0012 ohms. Set to slow with 10 moving average samples. Using 100 range with a 100.000 .005% resistor. Last calibration 15 years (!)
Ok, spec after 1 year (max on datasheet) is 100+40, which is ppm reading plus range. So, I think this is 100*0.01%+100*0.004% or +/- 0.014 ohms.
So, my reading is 99.981.
So, in spec? Maybe?
I tried a member's dynalo mk2 in San Jose meet today. I think it's neutral and well controlled and beats Nelson Pass headphone amp (which is shown side by side) easily.
Hi Kevin:
Is there any way to make the Susy Dynalo work in SE?
Leave the - output floating and just use the +.
Yep, and let all that balanced goodness go to waste.........  :o
SE to balanced is what you probably mean, and you can do that.
you can also do SE output, but then why?
Perzactly.
Just make sure the wires to each transducer such as the return/negative are NOT joined in the plug.
Yes, i mean SE output. I will use both SE and Balanced output but SE is always more convenient because i have 5 headphones and recable all of them will cost quite a lot.
I have another questions:
1. How do i wire the ground wire of SE output jack? to one board Gnd or to the Power supply GND?
2. I searched mouser for the Op27, there are 2 variant: Op27Gp (3.42$) and Op27Ep (6.61$), the different seem like only the operating temperature, so will the Gp work fine? I also have some spare opamps (opa1641 and opa551 which can run at +/-30V), can these work as servo opamp for the Susy Dynalo?
Thanks!
The ground on the Dynalo is shared but for lowest potential I'd connect the ground to the PSU.  Shouldn't matter though...
Too tired to look up the datasheets for those but many single opamps will work.
I used OPA445BMs on my build ,I think single OPAmps can run unity-gain stable should work fine
I use TL-071 or TL-081 for singles (or 72s and 82s for duals). From testing opamps in a discrete I/V stage (0 feedback, so touchy), these seem to pull the offset in faster and lower than the OP27s I had do. Particularly the 08x. I believe Justin used to use these in the GS-1 and probably in the GSX as well.
I've used them as well and they do work well.  Much cheaper too.
^ I know... so un-headcase though :) Wheres the fuckin' shovel...
i have over 200 op27 in stock. where i got them, no clue. but better than paying for them.
finally had to buy opa445 from mouser as i ran out.  one chip dead out of the package. have not seen that in a very long time.
That is just weird.  Never had that happen but the OPA445 is certainly not cheap so shouldn't even be possible...
On 2016-01-21 at 1:38 AM, spritzer said:
As I've been promising to do for months I'm finally working on some dynamic amps.  Here is something new, a Susy Dynalo with switchers...  ;D
Running at +/-18V there.
Are those switchers of the ready made or home made variety? Thinking about trying this, but not sure what requirements to set on switchers in this use (max ripple, for example)?
mwl168 did a run of them awhile ago, probably the newer SMD version. The TO92 silicon is not available anymore; I was probably one of the last to build that version and got lucky on finding some. He will probably weigh in on whether he has any left or not. Otherwise, someplace like seeedstudio could run boards for you for pretty cheap. The later board runs seem to use heavier copper (2oz and sometimes 4oz), but I've never had any problems with 1oz copper boards even with some rework.
Kevin has the board files on his site. I see
  • dynalobal12
  • dynalobal13
  • dynalobal15
  • dynalobal17
Not sure what the differences are between them; would have to search the thread.
