November 12, 20178 yr So I've been looking at a bunch of tube/solid state hybrid dynamic amp schematics, and every one of them is some form of bad, or really bad. (one person/ex company in particular) Low voltage plate, capacitve coupling of a high impedance source into a low impedance, poor balance etc. There had to be a better way. true balanced input. dc coupling. low impedance output. no feedback. proper use of a tube (pure transconducance) etc so I came up with this, work in progress. 4 x 3 inches ubaltobaltubeschem.PDF Edited November 14, 20178 yr by kevin gilmore
November 12, 20178 yr Odd that a proper Dc coupled input is possible... I wonder if Cavalli would complain about the lack of mosfets...
November 12, 20178 yr Author board files for you updated including 100v massive overkill power supply ubaltobaltube.zip grhv100v.zip Edited November 14, 20178 yr by kevin gilmore
November 13, 20178 yr Looks a lot like the front end of an electrostatic headphone amp (T8000-ish), but with relatively low voltage transistors (except for the KSA1156). You could always substitute a MOSFET current source for the input tube tail CCS. Edited November 13, 20178 yr by JimL
November 19, 20178 yr Author there are now 2 versions of this, one with the tube on the component side, and the other on the back side for mounting megatron style. ask first.
January 9, 20188 yr If I am going to drive high independence headphones with this, what should I do? 1) add triple darlington stage like tubehybrid/CFA did 2) add paralleled darlington stage like dynahi Edited January 9, 20188 yr by joehpj
January 11, 20188 yr 2 hours ago, mwl168 said: Why does the PSU have two sets of F+/F- output? There's one tube per channel. So one set of heaters per tube
January 12, 20188 yr The filaments don't come from a common source, each has their own regulator. This makes sense because filaments require a lot of current. B+ is pretty low current so just one for both channels should be fine.
January 16, 20188 yr I am curious as well - what sort of voltage can it swing into what sort of load at what sort of distortion?
July 10, 20188 yr Since this is probably the first thing I will try from the group buy I wondered about the transformer and the VA. Looking at the input ac like this would couple 2 cheap transformers work? The +-15 is from a GRLV or something I guess or would a LM317+LM337 do the job?
July 29, 20187 yr Gonna build this from the group buy soon, On the board the silkscreen says "tube mounts on the back side of the board" but tracing the boards shows it's the same version as the one in first post. So tubes should be mounted from the top? I also have never built tube amps so I might be wrong. some questions I have: 1. How hot is the mosfet on PSU will be? Will heatsinking with chassis floor (3mm aluminum) suffice or does it need heatsink? 2. LT1085 require heatsinks or not? 3. Will it make a good preamp? Do I need to watch/match it's output impedance to the amp's input? 4. How to bias it?
July 29, 20187 yr Author here are both of them, not sure which one was in the group buy 3) Its a current mirror. So output voltage depends on impedance, currently 1100 ohms. Needs an output buffer if you are going to use it for a preamp. Edited July 29, 20187 yr by kevin gilmore
July 29, 20187 yr The group buy is the first one, cool that means it's the correct version. I was counting the tube pinouts counter clockwise. I'll try looking for a suitable buffer stage.
August 25, 20187 yr I've compiled a BOM from Digikey for the supplied GRHV based on my silkscreen from the recent group buy board. I hope others can help check if I missed anything. https://docs.google.com/spreadsheets/d/1XMu81oWk6E3mXPW6ahhEuvmhg4U497F5I5W6JPQgnNo/edit?usp=sharing You might notice there's RES 90.9K and RES 1.10K, these are because I can't find 92K resistors sold without MOQ.
September 25, 20187 yr On 7/29/2018 at 9:29 AM, kevin gilmore said: here are both of them, not sure which one was in the group buy 3) Its a current mirror. So output voltage depends on impedance, currently 1100 ohms. Needs an output buffer if you are going to use it for a preamp. Kevin, can I use the Diamond output buffer ver. 2.0 ?
July 15, 20196 yr Dear Kevin, I find the heater power supply portion to be rather handy. Would you please cut the HV supply portion away so that I can use the heater power supply portion for mini T2 project? Thanks Sam On 11/13/2017 at 7:45 AM, kevin gilmore said: board files for you updated including 100v massive overkill power supply ubaltobaltube.zip grhv100v.zip Edited July 15, 20196 yr by samsie
May 15, 20233 yr Can anyone confirm if I can use a 100V secondary trafo for the grhv100? Will it still regulate down to 100vdc without issue? Having a hard time finding a suitable 90V unit that isn't 1A+/huge.
