The Menace
  • Replies 500
  • Views 102.7k
  • In addition to a regulator for the PS, a CCS plate load for the first stage will decrease distortion, a CCS cathode load for the second stage will also decrease distortion, and using a MOSFET instead
  • mypasswordis
    mypasswordis
    Hey hey, come on now, the main constraint of this exercise was OTL  give the man what he wants, even if it is worse.
The only other thing worth adding is that Pete's a friggen genius. Last night we cooked up an alternate grounding scheme that included the addition of a ground loop breaker and fourth wire through the B+ umbilical. It worked wonders.
I'm speechless. :-X
So when are you gonna let reks borrow it to give us his impressions?
I'm nervous as hell about shipping this to CanJam tomorrow so odds are when it returns home after that I won't be letting it out of my sight for a good long time. ;D
And FWIW, I don't believe in the Reks curse.
I'm looking forward to some extensive listening impressions.
Just spent a solid hour with it, 60% w/ my HD650s and 40% w/ the Woody HF-1s. My previous Wheatfield HA-2 (cousin of the Menace) couldn't drive the HF-1s very well at all. The Menace, different story altogether. I like, I like a lot. But that's like asking a parent if their kid is cute or good at sports, so let's see what comes out of CanJam for impressions and go from there.
so you're sending it to me? :kitty:
Jacob,
Round trip shipping would likely exceed $300, I'm sure you don't want to foot that bill and even if you did I finally finished a project for me. I think I'll let myself enjoy it for a while. Now, as to whether or not I'll just sell my beta22 parts, that remains to be seen.
:kitty:
it's that heavy? ouch. i was joking anyway, you can keep your filthy headphone amp.
The power supply is probably 50 to 60lbs (we'll find out tomorrow) and the amp another 15 or so. They'll require separate packaging in custom boxes and the tubes that come with it aren't exactly cheapo's either.
And thanks, I'll keep my filthy headphone amp thankyouverymuch. ;D
Nope. I'll just leave him with some work to do while I'm away. I'm sure he'll find some cables lying around while I'm gone. Oh, and about recabling your speakers, he's almost ready for that level of work, but I'd need to have them in house for a few months to make sure the jobs done right. Feel free to ship them to me any time.
Cats can't be repaired.
Sure they can. It's called neutering. It repaired all his flaws.
EDIT: grawk beat me to it.
The big sleep is the only way to fix a cat. :kitty:
Nice to hear some actual listening is going on over there Nate. The amp is going to be a big hit at the 'Jam and we're all looking forward to hearing it. Now pack it up extra careful-like and get ready for the trip!
Congrats, Nate! Good to see the amp is working great and you've finally finished your own project!
Nate it must be a great feeling to give birth to a healthy amp with the correct number of tubes and traffos! (Hands Nate cigar) But I bet the trip through the birth canal was a doosy! That's a big boy!
Congrats on a job well done and a great amp!
one point off for the gluing of the 2 caps to the chassis in the power supply...
I wanted to revisit this point as it was actually something that bothered me while I was wiring the ps/amp but I was at a loss as to how to do it differently. So I'm all ears guys, when you've got larger caps that are not going to be directly mounted to the chassis how do you go about supporting them so they're not just hung from the wires? I tried to review some of what I thought were the better examples of PTP wiring before starting to wire this amp and I didn't see much that gave me any bright ideas for smaller, but still too large to air wire, caps.
sideways capacitor clamps. Basically a loop of steel, usually with insulation and
a mounting tab you secure to the chassis.
Duct tape. You wrap the caps with a couple layers of duct tape, then duct tape it to the chassis.
One of the neater solutions I've seen so far use plastic battery holders. The caps just happened to fit nicely in a AA or C size battery holder, so the guy just glued the caps into the holder and screwed it into the chassis.
Thanks Kevin, I'll have to get busy googling. I haven't seen those at the usual suspects like Antique Electronics, Percy or Parts Connexion.
I'm sorry, but in my mind duct tape is a far worse solution than hot glue. I'm sure it's fine for insulation between the caps but as a permanent or even semi permanent mount no way. If I'm going to do something other than hot glue I want a solid mechanical connection, not adhesive.
what about some heatshrink and a common hose-clamp?
