January 26, 200917 yr comment_199682 I'm more surprised that it took this long for something like to this to come out. Report
January 26, 200917 yr comment_199687 I think Kimber has a really silly expensive one. Found it, http://www.audioconnect.com/html/kimber_usb_cable.html Report
January 26, 200917 yr comment_199688 I don't see how this is any different than audiophile coaxial and toslink and AES/EBU and BNC cables. Report
January 26, 200917 yr comment_199689 I don't see how this is any different than audiophile coaxial and toslink and AES/EBU and BNC cables. USB is a different type of "digital" signal. Report
January 26, 200917 yr comment_199690 USB is a different type of "digital" signal. Oh yeah. Forgot about that. Report
January 26, 200917 yr comment_199694 They could at least do something useful and put a ferrite on them like the Kimber has Report
January 26, 200917 yr comment_199697 The big advantage is that audiophile DIY usb cables are WAY more likely to introduce errors Report
January 26, 200917 yr comment_199774 The Locus Design Group Axis T ($549 USD for 6ft) got to sound sweet Report
January 26, 200917 yr Author comment_199915 The big advantage is that audiophile DIY usb cables are WAY more likely to introduce errors win;D Report
January 26, 200917 yr comment_199960 Also the cheaper and DIY cables cannot handle the higher "1s" and they only let the "0s" through("0s" are lighter than "1s"). The slow transmissions of "1s" can be alleviated with a special "hydro-crystallization" treatment that increases cable bandwidth and makes the music seem quicker, cleaner. IE, the "1s" have the space to travel down the cable along with the "0s". Jeez, I thought HC was full of the bright ones and this kind of stuff was understood. Report
January 27, 200917 yr comment_200129 I think if I were in the market for an "audiophile" usb cable, I'd have a good enough DAC that it re-clocks the digital data, so I wouldn't need one in the first place. Report
January 27, 200917 yr comment_200177 Honestly, people will literally fall for any old tat if it's wrapped up in enough jargon and glowing BS. Report
January 27, 200917 yr comment_200186 I think if I were in the market for an "audiophile" usb cable, I'd have a good enough DAC that it re-clocks the digital data, so I wouldn't need one in the first place.No, the point is USB is better. Report
January 27, 200917 yr comment_200194 ^^^ I think the point is, that if you have a USB DAC that uses a correctly implemented asynchronous mode (the USB Audio standard uses isochronous transfer in one of three modes: synchronous, adaptive, or asynchronous) Then you have removed the timing part of the equation - or made it irrelevant. That just leaves the data part, which for a digital cable can be either working, or broken (fail!), there is no better or worse to it. But since when has use of a decent protocol to overcome the limitations of physical medium stopped people from selling unnecessary solutions to people with more money than sense. Denon USA | AK-DL1 Report
January 28, 200917 yr comment_200868 ALO will come out with a better fatter one within a month. FIFY Report
January 28, 200917 yr comment_200883 ^^^ I think the point is, that if you have a USB DAC that uses a correctly implemented asynchronous mode (the USB Audio standard uses isochronous transfer in one of three modes: synchronous, adaptive, or asynchronous) Then you have removed the timing part of the equation - or made it irrelevant. That just leaves the data part, which for a digital cable can be either working, or broken (fail!), there is no better or worse to it. But since when has use of a decent protocol to overcome the limitations of physical medium stopped people from selling unnecessary solutions to people with more money than sense. Denon USA | AK-DL1 Ding ding ding ding.... we have a winner! ALO will come out with a better fatter one within a month that costs 3x the price of the Polestar! MOAR JENA FTFY Report
January 28, 200917 yr comment_200885 ALO will come out with a better fatter more expensive one within a month. FIFY FIFBOY Report
