  • Replies 5.4k
  • Views 1.5m
Using just a compass and a straight-edge? The man knows his Stax.
I cheated. Justin came up with the idea. I did not think it was going to work, but it
did. I used the macro lens and took a picture at as close as i could get and still
have all the pins in the picture. Then i suck the thing into featurecam and tell
it the measured dimensions of just 2 of the pins. And it calculates the rest...
And damm close too. PDF's of that connector are just plain not available.
If this did not work, i could have used the new nikon microscope at work
which has guaranteed flat optics and a reticule for exact measurements.
justin's way was boatloads quicker.
African or European swallow hardwoods?
I'm open to suggestions. The harder the better.
nice, that's exactly what I did :)
I have noticed two problems. First, quality control isn't all that great on the Stax plugs, from what I can tell. So, just because it fits your SR-007 "perfectly", doesn't mean it will fit everyone's within 0.001". I checked around 10 or so plugs and found a good amount of variance, in fact I was rather surprised. The other problem (which really isn't a problem) are the people using the WPI socket. It's around 5-6% smaller, and over time bends the plug connectors so that they don't fit all that well in a properly sized connector.
I can also make them round and threaded just like the real stax thing. But the
diameter is going to have to increase a bit.
Time to learn how to cut threads on the NC lathe...
if anyone needs 2SC3381 for this, i have around 70 of them
My hard wood experience is quite limited but West Australian Jarrah is very nice :)
It's pretty cheap in Western Australia too! Beautiful dark red brown colour. I had some side panels made for the CD player from this wood - they look better than the original factory supplied option.
Difficult to work with though. It just eats drill bits for breakfast! ;)
Shit yeah don't I know it... complete pita to "hand" drill.
But perhaps with Dr Gilmore's CNC mill it may be ok :)
I love it when a plan comes together :D
no errors yet, and i think i can probably sail thru the rest...
http://gilmore.chem.northwestern.edu/t2chassis1.jpg
http://gilmore.chem.northwestern.edu/t2chassis2.jpg
http://gilmore.chem.northwestern.edu/t2chassis3.jpg
http://gilmore.chem.northwestern.edu/t2chassis4.jpg
http://gilmore.chem.northwestern.edu/t2chassis5.jpg
current BOM such as it is :(
http://gilmore.chem.northwestern.edu/t2parts2.xls
I'm doing a custom radius cutter for the outside from a single blade
carbide bit, edm'd for the surface i want. (because I CAN! :D)
hand drill??? what are you guys nuts??? i'm going to cnc the stax jacks...
Hand drilling is fun until you mess up. I spent the last afternoon trying to drill 32mm holes into the top of a Modushop chassis where all the air slots are with a stepped drill. I really need a 35mm+ punch.... :palm:
Starting to think about a completely custom machined knob...
Anyone with some ideas ??
The deep engraving is going to be sweet.
:eek:
how about a stylized reference to the "zeners" used in the T2 for the engraving? Some sort of artistic interpretation of the schematic
:D
Show me what you got... Be creative...
autocad 3d drawings in dxf format please...
or solidworks, or cativa....
no lines <.025 inch please.
Very nice!
What's the dimensions on the chassis?
Remember that there are 2 chassis, another identical one for the PS.
The circuit board that goes on the inside is 12 x 16.
I think the resulting chassis had better be 15.4 wide x 16.7 deep x 2.96 high
(plus feet) (plus tubes) (plus about an extra .35 for the neutrik jacks)
Still less cubic inches than a dual maestro chassis... :D
My house mate is laughing uncontrollably after I showed him this with a tape measure... his exact words were "isn't that a bit much" :)
I could make a small surf board with that much fiber glass LOL.
Crikey! What kind of people do you hang out with?
