  • 4 weeks later...
Just curious, has anyone ever used any hardware switch debouncing before? I realize this is 100% unnecessary / overkill in this situation, on all kinds of levels, but I am going to play around with a few of the Maxim chips in this rube-goldberg-esque circuit
58b4f1a56061f_ScreenShot2017-02-27at9_40_03PM.thumb.png.9b0a151d0c43ba4c20664b964ae95ab4.png
  • 4 weeks later...
[emoji20] that circuit doesn't work. The first switch debounce output (U2) is high and then transitions to low when the momentary switch is pressed. This means U1 clear is always being asserted. What is the easy way to invert this logic? I still need half that switch to be NO for the logic that happens on the other side of H1. I suppose it's possible a half NO and half NC momentary switch might exist, but seems unlikely in the switch form factor I am using and commited to. I need to find a way to jumper U2 pin 1 and 3 and then test the other part of the circuit. Testing tiny SMD components on a dense board is hard [emoji20]
Last time I bought from them it was all authentic, even the often faked J79's.  That was a couple of years ago though so things might have changed.
  • Like 1
Anyone recognize this RCA socket and have the part number? Single channel and has that mounting hole on the top left. Also, what's the best way to remove neutral cure silicone rubber off pcbs?
Edited by mypasswordis
2 hours ago, Pars said:
Thanks! That's the closest thing I've seen so far, but then again I hadn't even found any PCB style jacks with chassis mounting hole in my search... Sadly the bottom pins aren't in the same place and there are no locking tabs like in your link. I'm not so sure about overall dimensions, either. Definitely tough. I emailed Emotiva, hopefully they will get back to me tomorrow with a part number.
I'd see if emotiva would send you a couple of them. They are after all the ones who selected them :)
Good idea! I just called and they want to charge $12.50 for just one RCA jack. Dear lord. I guess they can charge whatever they want when no one can find whatever part they're using. Gonna try to see what can be done under warranty.
Is that shipped or do they want another $8-10 for that? I'd probably try the whining approach, you know, the fucking POS broke :)
Of course they might come back with the ship it in (and pay shipping both ways :) )
I'm looking for Xicon 273-series resistors:
273-240-RC
273-511K-RC
273-240K-RC
273-820K-RC
273-62K-RC
273-390K-RC
273-300K-RC
273-91K-RC
273-560K-RC
273-6.2K-RC
273-910K-RC
273-499K-RC
273-402K-RC
273-487K-RC
273-40.2-RC
273-287K-RC
273-82-RC
Seems available from Mouser, but at 5000 minimum quantity.
So, any hint's on where to buy in less quantity or some who might have those in stock and want to let go of, please let me know.
Thanks.
  • 5 weeks later...
