From topping's previous amplifier products, the EHA5 normal amplifier section is likely to be a composite amplifier, just like the amplifiers of jds atom and benchmark things. The common practice is to combine a precision opamp1 with a higher idle current opamp2 which has a specified closed-loop gain. opamp2 is placed inside the feedback loop of opamp1, which is the "feed forward technology" claimed by some manufacturers. In fact, it introduces a huge amount of feedback, the distortion test is usually lower than what the manufacturer's specs , but I don't know whether it can drive the transformer to output such low distortion though...never tried before 😟
Edited by Kung
So it is basically what Quad was doing 50 years ago?  😉
Now given it is a step up transformer solution, the light weight of it does worry me as good quality iron has to have a certain weight to it.
8 hours ago, thebrunx said:
New King?
King of the trash maybe, not much more.  Assuming that it is well made (a big ask for Topping), it made to spec (also something I really doubt) and will not burn up headphones... This will be on par with the Stax SRM-1Mk2/3/313/323 amps in terms of performance.  Might be ahead of the 353 or D50 as they are both trash.
26 minutes ago, justin said:
this is why it's basically pointless to advertise specs anymore
Indeed and also a small issue with the 2000Vppss voltage swing, if you go much above 1200Vppss... there is a major risk of burning up the headphones.  Completely useless stats.
i have never seen a transformer output amplifier ever generate thd numbers like that. Not a single one regardless of cost.
not even the lundhall silver thing thats $5k each.
can't wait to see what a 10khz square wave looks like.
also likely that its not actually a balanced amplifier even though it has balanced inputs.
i think that kingsound made a chipamp/transformer portable. never heard anyone that liked it.
13 hours ago, Timb5881 said:
The old SRD-x Pro was a transformer driven by an amp.  That may be a he best comparison for this amp.
Indeed but I hope the power amp has moved on a bit from the early 80's...  ;)
9 hours ago, thebrunx said:
aren't Topping known for being giant killers?
It's mediocre crap from China, I don't see how that would be the case.  It's one of a host of similar products that don't stand out at all.
Hi
I recently got a stax x9000 and am using a placeholder energiser in stax srm727a (modded). I find the bass to be lacking and it to sound shrill. What energisers do you recommend that's around 3k that I can use with the stax until I save up enough for a better buy? Thanks!
::)Ray samuels the old friend of stax mafia just released a new amplifier B-21, the electrostatic part claimed 1800Vpp voltage swing with 200mA continuous current output performance just shocked me. . . Reminds me of the horribly weak output performance of the A10 he designed before, this new amp is also questionable...
  • Like 1
Holy fuck that thing is ugly and yeah... color me skeptical ;) of those numbers.  1800Vpp would point to either +/-450V or +/-500V rails (given the regular losses) so either 900V or 1000V at 200mA.  That's 180-200W, per channel and those heatsinks are not big enough for even a tenth of that.
I also love that Ray dug out a 20 year old CD player (which I'm shocked still works as I had one of those)...
so a darkstar driving transformers.
yep great idea.
no toobs :(
where else have we seen a red knob.
on the brighter side its probably better made than the viva. and cheaper.
possible spoiler:  transformers made by audiostatic, holland.
spoiler is incorrect :D
and ray clearly does not understand how current works.
What is this?
I wonder what's made everyone try their hand at making electrostatic stuff, not that I mind it but it feels like it's everyone rushing all at once
Edited by nopants
What's the price on Ray Samuels B-21?
Just to get perspective on Eletrostat/Dynamic combo amps out there..
Audio Valve Solaris $4900
https://www.headamp.com/products/audiovalve-solaris
Mal Valve Head amp three Mk 4  6000+ Euro
https://www.malvalve.de/Headamp3-E.htm
Linear Tube Audio Z10e $6950
https://www.lineartubeaudio.com/products/z10e-electrostatic-headphone-amp-integrated-amp
