Schiit Asgard
I was curious but had to start reading the review with my eyes rolled, which made it difficult to continue.
First off I have to admit: I’m becoming a huge fan of headphone amps.
Really, posting that on a headphone forum? No way.
The seller describes the design of the M-Stage as being a fully discrete Pure Class A design. It appears that the left and right channels share the same power supply and then things break down to a dual mono design from there, although of course they share the same PCB. It uses high quality parts such as Nichicon KG capacitors, a smooth ALPS potentiometer, a Burr/Brown OPA2134, etc.
I stopped reading after that.
  • Replies 277
  • Views 89.3k
  • I'm all in favor of redefining drug-free as hallucinogenic-free.
You should have a listen to my NOS DAC - it uses 8x oversampling
Didn't notice that one....funny.
Oh yea, isn't every amp a cmoy "essentially"? :P
Not to derail the thread, but what is your guy's opinion on the Matrix M-Stage (another discrete amp). Matrix M-Stage amp review: simple, cheap, and excellent. - Head-Fi.org Community I know I shouldn't trust head fi but this was a convincing review. Seems like it could be an alternative and I haven;t read about noise/heat issues for it either.
Fishy. An amp which allegedly runs in class A but doesn't even get warm, yeah. Either it's a very low powered amp or it's not class A.
specs from the ebay listing I saw for a ver 2 Matrix M-Stage:
Frequency Response: 10 Hz (-0.3dB) ~ 35kHz (-1dB)
Signal to Noise Ratio: >95dB (0dB)
Distortion: <0.001% (6 mW/300 Ohms)
Input Impedance: 47 kOhms
Output Impedance: Line-out 60 Ohms, Phone-out 5 Ohms
Output Power: 200 mW/300 Ohms, 400 mW/60 Ohms
Power Support: AC 220-240V/100-120V (Please specify)
Front Panel Color: Black/Silver (Please specify)
Weight: 2 kg
Device Dimension: 280 x 110 x 42mm
Seriously though, a 15 page review for a $250 amp?
I skipped all his technical mumbo jumbo and went straight to his amp comparisons...which as I said, were pretty informative.
ok, so from the reaction, I am going to assume that the M-Stage is not viable competitor to Schitt amps.
I think what you should do is ignore that review you pasted and try to find other information about the amp or another review.
Why do I suspect that S.G.'s review on CNET is just slightly hyperbolic. I have a sneaking suspicion that I'm not getting the measure of my HE-5LE headphones with any of my amplifiers and S.G.'s review of the Asgard has me reaching for the CC hoping that the Asgard might be a magic match for a very low price. As Heinlein used to say TANSTAAFL, now $249 isn't free but it's certainly dirt cheap by high End standards. Is 15 days enough time? and I hate returning anything.
I'm going to wait. It's summer and I use my Headphones even less during the Summer so I think I'll let the dust settle a little before I bite on the Asgard hook; besides I've been selected as a Beta tester for the new PS Audio Network Bridge so that should keep me busy for a while.
15 days is enough, just make sure to turn it on and let it burn in for a while in a ventilated area, as the initial smell of electronics it gives off is a bit strong imho.
I've liked some of SG's writing in the past. He also worked at Chesky as a producer IIRC.....some decent resume material IMO. So I'm happy for Schiit (or is that "as" Schiit?) to hear he likes this and that a mainstremer like CNET gives them some good marketing.
But there is probably a bit of hyperbole involved. Part of it is likely finding a nice amp like this at such a low price; it causes the "wow" factor to go haywire....
I'm still enjoying mine, but still also using my other amps more. The glare I heard at about 30-40 hours HAS seemed to lessen somewhat (I don't think it's my ears adjusting to it, as I am using my Stax and Millett during this time as well). Still there, but a slight bit less.....
Homeboy lists Phiaton among his favorite headphones. :) I just found that amusing.
Maybe I should check em out?
Hey, they might be awesome for all I know. :D Seriously, I haven't read much of anything about them.
