4 hours ago, robm321 said:
I was interested in the clever because I can't get my French press to work without some sludge at the bottom. The clever is immersion also, so I figure it'll maintain some of the oil unlike my pour over. I may pick one up after your impressions, thanks.
Not for nothing but usually the solution is a better grind.  For starters, I'd give a slightly coarser grind a shot, assuming you're grinding your own.  Next step would be to pour through a fine mesh filter or strainer.  I still end up with just a bit of sludge in the bottom of my French-press produced coffee but I don't find it bothersome.
  • Replies 1.6k
  • Views 340.8k
  • This could be trouble. First results were very promising, if not entirely drinkable.  I'll toy with grind just a big more to get a full extraction but tomorrow morning should be fun and int
  • ^^ enjoy I was lucky that Sonja brought a Breville to the relationship.. (larger style with grinder, etc.) After several months of Costco coffee living out of the airbnb - we unpacked the ro
  • The Niche Zero arrived last week and I've gotten to use it.  So did the Chemex.  I chose the 6 cup which worked out well for my situation.  I'm the only coffee drinker in the house, but if I have a gu
I have tried a courser grind (I grind my own), but I hadn't thought about pouring through a fine mesh filter. I'll give that a shot.
Yeah, some sludge is virtually unavoidable on a french press. If you're interested in something in-between that and a paper filter (where the oils and resulting body do get reduced) I've heard good things about cloth filters. I found out about this through James Hoffman's channel; here's a link -- https://www.youtube.com/watch?v=dr_I3ZVKKb4
OTOH you could consider experimenting with sifters, but cloth filters will be more worth it IMO.
I find that if I leave the last ounce or so in the cup most of that sludge drop and stays there.
HS
I do pretty well drinking about 75% of the cup then dumping the rest as the sludge gets noticeable. I think I'll stick with the french press from time to time. Somehow, knowing that everyone else has the same issue makes it more tolerable.
  • 4 weeks later...
I think I have my Flair dialed in. The pressure gauge is a must have. This was a delicious shot made with light roast yirgacheffe, just from a grocery store, and ground just with a Bodum Bistro (you can get away with more with a manual machine, since you have complete control).  It’s a pain in the ass to make coffee this way (and I use a NanoFoamer for milk), but I rarely drink coffee, and I love the Flair. I like that it’s a pain in the ass.
16/32 in 31 seconds, not quite 9 bar. Sweet, complex, moderate acidity, good texture. You couldn’t ask for a more perfect puck or a prettier shot (not that crema adds anything useful).
Edited by EdipisReks1
Good Brothers washed Ethiopian Argo, roasted 10 days ago, Flair Royal grinder, Flair lever machine, NanoFoamer, Oatly barista oat “milk.”
I don’t think you could ask for a prettier cappuccino for the second time the grinder has been used. The shot wasn’t quite right, but I was able to profile it and make it work. It was a delicious cappuccino.
Looks awesome, ER!
I'm so pleased I finally found a local roaster worth their salt.  Fourth largest city in the U.S....you'd think it would not be that difficult.
Anyhoo, I have been using a Chemex for a few years now after many a year with the French press.  Have enjoyed the cleaner cup although it is hard to argue with all the raw oily goodness of the press.
I am drinking an Ecuadorian Pillcocaja Typica Golden Honey.  Love all the information provided by the roaster...he's a true gent interested in educating his consumers which I love.  Probably TMI, but in case someone is interested following are but a few of the details provided:
PRODUCER - Ana Maria & Nicolas Eduardo Crespo
FARM - Pillcocaja
COUNTRY - Ecuador
REGION - Azuay
VARIETAL - Typica
LOT - #4 / 570 lbs
PROCESS - Golden Honey
DRYING - 20 days, 50% Shaded African Beds
ELEVATION - 1700 masl
HARVEST - August 2020
TASTING NOTES - Tropical fruits (papaya, banana), Acai berries, Sugar Cane, Chocolate
otal roast duration: 9'20
Weight-Loss: 12.75%
The special terroir of this Ecuadorian coffee makes it a very interesting coffee to roast with a lot of carbohydrates to create a complex profile. Additionally, in the golden honey process, we have more sweetness and texture available to be developed. For this reason, we started with a lower charge temperature and reach our crack time after 8 minutes with only 1'20 minutes of development post-crack. This gives us a balanced cup of coffee with sweet berries and ripe banana notes, a berry-like acidity, a creamy body, and a chocolaty lingering finish.
https://www.memlicoffee.com/product-page/ecuador-pillcocaja-lot-4-typica-golden-honey
HS
That sounds awesome, Sam. I have had some wonderful coffee out of pour-overs. I use something similar, either V60, or Bodum’s copy of the Chemex, depending on whether I am making coffee for just me or for more: it’s my most commonly used method (try a Japanese-style iced coffee in it!).
That sounds like really good coffee. I have a new local roaster’s on my counter. I freeze coffee once it has off-gassed enough for espresso, and this particular one was roasted a week ago. I’m looking forward to fiddling around for half an hour making manual espresso with it. I do that about twice a month: it’s just so much clean up.
I revisited French Press when I saw the Hoffman Method. It makes a damned good cup. I’d suggested revisiting it too. :)
edit: I really strongly suggest trying Japanese-style iced coffee. It’s amazingly good on a hot summer morning. This isn’t quite how I make it, but it’s a good starting point. https://www.seriouseats.com/japanese-style-iced-coffee
Thanks for the reminder about the Hoffman Method. It's been awhile...
The Hoffman method is a win...as long as time allows.  Not a problem on the weekend.
Thanks for the recommend on the japanese style coffee...I'll definitely have a look.  Could be good for an afternoon given how hot it's getting here.
HS
Keep in mind that I do the exact opposite of “latte art,” on purpose, because I yam wut I yam.  This was a very good flat white. I ground the coffee (a light Honduran single origin roasted on June 21) a little too coarse, but I still got a well pressure-profiled shot: just a littlej channeling when I hit 7 bars, but not the “it’s too fine channeling.” It’s hard to explain if you haven’t used a fully manual set up.
Oatly barista blend heated on the stove and then foamed with a NanoFoamer. I could have tapped out more large bubbles before transferring to the pouring vessel, but “anti-latte art,” and all. The NanoFoamer has a bit of a learning curve, but so does a steam wand. I can reliably produce the sort of foam, hard or soft, long stretch or short, now. I’m happy enough given my kitchen situation.
4 hours ago, Craig Sawyers said:
Never heard of the Hoffmann technique. Now I have, and am definitely going to try it today!
You will not regret it, CS. Takes a bit of patience and it's best if you have a double walled French press and you will lose temp, but it is indeed very tasty.
I am excited.  Two new coffees awaiting me for my lazy Saturday and one sample Memli tossed in for sport.  This one in particular has piqued my interest...
ECUADOR - PILLCOCAJA LOT #13 - TYPICA CARBONIC MACERATION
  • Coffee Details
    FARM - Pillcocaja
    COUNTRY - Ecuador
    REGION - Azuay
    VARIETAL - Typica
    LOT - #13 / 28 lbs
    PROCESS - Carbonic Maceration for 96 hours
    DRYING - 24 days, 50% Shaded African Beds
    TASTING NOTES - raspberry jam, cherry, white chocolate, grapes
HS
Tried the Hoffman method. Bit of a faff, and not something to do if rushing to get to work - but the resulting coffee is to die for. Has real depth, but without the bitter edge from the regular French press method.
Win!
Seems a bit confusing, and is it really his method?
Win!
I agree...a bit of a PITA unless you are on a day off but it's pretty darned yummy.  And a nice change for one that's been using a press forever as I had been when I tried it a few years ago.
Time...what a trip in this environment.  Feels almost non-linear at times as I think back on the last year plus...
HS
I roast my own coffee but it's nice to sample professional stuff too.  I searched the thread and did not see this here; it's an awesome service, pulling from something like 400 roasters all over the country:
https://www.drinktrade.com/
As a pour-over guy this is something I want to try next time I’m able to use a press. The long steep time is interesting.
Not that anybody was wondering, but I discovered this morning that Chemex papers old enough to smell like good library books work (and taste) just fine once rinsed with boiling water.
Win!
If I’ve done nothing else positive for anybody else this month, I’m glad that a bit of a faff which produced pleasure in the making and consuming, from a shared YouTube video of all things, came out of mentioning, and sharing, somebody else’s hard work. A good cup.
As you weirdos across the pond would probably say, I’m chuffed.
Try Japanese-iced coffee next, Craig.
I took my own advice. Two-week old sugar process Colombian decaf (I don’t need another cup of caffeine any day of the week!). V60. 1:15. 225 ice, 225 boiling water. Pretty tasty. Nice flat bed.
