What to do next?
New headphones: do want.
Problems: I'm still studying Java at UW. It comsumes about 95% of my free time so regular headphone listening just doesn't happen unless I get spare time at work, which is also rare. I'll be done in June, though.
I'm thinking of three possibilities:
ATH-ESW9
Good: Good form factor for work, seem to respond reasonably well to amps.
Bad: Would I use them outside of work?
RS2i
Good: Enjoyed these when hearing the RS2 a year or so back. Would be a nice 32ohm phone for use with the Ventus or future suitable amps. Might be nice to have for a work rig, albeit maybe a little overkill.
Bad: Maybe a little pricy for leaving at work.
LS-2
Good: Well, geez! Love these. They are on the "will buy eventually" list.
Bad: Probably wouldn't get these until Summer, after completing school. They would not stay at work.
JH13: I don't have much time to get these right. Plus if these were used at work, they'd be in and out of my ears too much.
Upcoming builds:
Bijou
Buffalo dac
Some Millett Max build that I understand I can't miss.
Also in the house:
HD600
Shure SE310 (selling soon)
CK2III
Ventus
DVP-S9000ES
Theta Casanova (with a nice DAC)
Sure, the way I'm leaning is obvious. I"m just curious what my 'case friends would do.
Thanks!
  • Replies 50
  • Views 10.9k
FWIW I use the ESW9 at work, powered by an M3 and y2 DAC, and I was quite happy with the whole shebang for a long time. But compared to the new dynamic rig I am using at home (Buffalo/Crack/HD650) the work rig now just sounds flat and lifeless. I am definitely looking to upgrade to some better phones for work, but have no idea what yet. I was thinking Thunderpants, but it would be a big cash outlay......
If you want, I can lend you my ESW9 so you can see if they suit your needs. I will be selling them anyway as I just don't use them anymore (I have the ESW10JPN anyway, and I like using those on-the-go and because they look pretty).
Interesting. Well, the last time I heard HF-2s, I thought they sounded a bit flat, but its been a while.
Beefy, that Buffalo/Crack/650 rig sounds like it would be damn good. Did you ever try the ESW9 with that setup? If I could find even a few extra tubes I'd bring the (forgot to mention) MHSS to work, even though it is not nearly as nice as the Crack.
I only mentioned the HF-2's because the ESW9's were mentioned. Not that they have a similar sound signature -- they kinda do, but they kinda don't -- so much as they both have that same "fun factor". If you thought the HF-2's were a bit flat, I am no person to judge. In my case, they were just not for me, as I'm not a big fan of the Grado comfort quotient (they have to be PS-1 good or HP-2 good in order for me to still want them).
HF-2 > RS-2. I sold my RS-2's after getting my HF-2's.
Not yet. The Crack has only been in commission a short while, but I don't think I will ever bother trying the two together. The gain of the Crack is pretty high even for the HD650. With the much more sensitive ESW9, volume control would be virtually impossible.
I've been using a pair of EWS10JPNs at work for about 1-2 years now and couldn't be happier with them. I've had a ton of really high end headphones, but somehow still really enjoy the warmth and sound out of these. They provide enough isolation to hear the phone ring at the office, but also allow you to keep the music to yourself. I used to connect it to a headphone amp (RSA Mustang), but it sounds about just as good straight out of an iPod Nano. These are very forgiving of source and sound good with mostly everything I hook them up to.
bhjazz,
i'm not sure what you want in the HP. sounds to me like you just want a new pair of HPs?
cheap, awesome and comfortable: K271mkii with Beyer DT880 pads. more forgiving but similar to the K702.
Damned with faint praise. :)
ouch. since DADT has been repealed, am i allowed to come out of the closet and profress my K702 fanboi-ism?
I only have the K271 mark 1 (okay sounding, not awesome), but I agree it's a super comfortable headphone with the addition of those Beyer pads. And it gets extra workplace-friendly points for the little switch that auto-mutes them when you take them off, though if bhjazz is considering RS2i this clearly isn't an issue for him.
That I didn't know. I'm now wondering why I didn't like their signature...
I'm not sure I'd say the Millett is something you can't miss. It's a heck of a budget rig, don't get me wrong, but I'd encourage something more challenging.
Oh. Ha! I was just quoting the list of possible parts lists that are "can't miss build #2, #1" etc. Sorry for the obscure reference. Like you, I have a pile of boards that I need to work on and try out. Some day...
That sounds a lot like the Bottlehead Foreplay I built a few yeras back. Pairing that with my Classe CAV-150 with it's own 29dB gain meant touchy countrols until I could back off the gain a bit. Thanks for the reminder, though. Knowing that the ESW9 is maybe more sensitive helps me pair it with something better.
IThey provide enough isolation to hear the phone ring at the office, but also allow you to keep the music to yourself. I used to connect it to a headphone amp (RSA Mustang), but it sounds about just as good straight out of an iPod Nano.
Excellent information. I had forgotten about trying to isolate those around me. Guy next to me often cranks up his Bose Quiet Comfort. They're not so quiet in my own cube.
bhjazz,
Yeah, this gives me more focus. I want better sound than a pair of freebees, headband design so I can take them off when my supervisor stops by, sound isolation so others don't have to hear what I am listening to that day, and something that responds well to different amps and dacs.
I have added isolation to my list! I guess the RS2i is off the list, then? It seems like they won't supply much isolation.
Thanks guys. This is great information!
Brian
I'd take an SRH840 over an ESW9 any day. OK, so the A-T doesn't make you look like a dork, but sound quality (the 'phat' tone aside) is more on the Sony DJ side than AKG et al Studio - it mystifies me that among supposed audiophiles they get such a high rep.
It mystifies me how far up your own ass your head is and how you can manage to hear any headphones while up it so far.
As long as I can make fun of you for owning something from the current line of rubbish AKGs.
no problem. after all, you are the guru of AKG excellence :).
If isolation, in the sense of blocking outside sound, is high on the list, then IMO the ESW9 and K271 are both pretty questionable assuming the mkii doesn't isolate any better than the mki. They're not utterly useless but IMO neither one is all that big on isolation.
If it is not isolation that's needed but just an an absence of sound leakage that would annoy people nearby at work, then ESW9 and K271 are fine (and again, props to the K271 for auto-muting when you take it off).
When I needed some sort of approximation of real isolation at work and IEMs were too fiddly, HD25 was my choice. However this was a few years ago and options like the Shures didn't exist at the time.
It also mystifies me how people don't run simple comparisons with things they own and want to compare at the same time against another established baseline. I guess it's too much to ask.
Brb recording every live concert I go to so I can listen at home and compare to my recordings from other live concerts on my own gear so I have a baseline, because hearing things once live doesn't mean shit.
I did "run a simple comparison." It was about a year ago. I don't own any of the three I mentioned, though, and thought a discussion here would be in order. Additionally, there are two dealers in the area who have any idea what good headphones are, and they only have Senns or Grado. I'm merely shopping for opinions here.
