Neko Audio D100 Impressions
  • Please log in to reply
28 replies to this topic
#1 tkam
tkam
    and then bam, here comes a bunny with a pancake on it's head
  • Administrators
  • 3,996 posts
Posted 13 May 2009 - 01:30 PM
Posted Image
Posted Image
After being a speaker only guy for awhile I wanted to put together a headphone rig again for late night listening sessions.  I had never sold my 650's so I had the headphone part covered and then I was fortunate enough to get a Dynahi at a fantastic price.  Leaving the source as the only thing left to get, I knew I wanted a dac as I was planning to use the Squeezebox as the transport.  I've heard quite a few dacs in the $1k price range over the years and none really ever satisfied me and some I flat out hated then I recalled reading this thread about a new transformer coupled dac.  I've had very good experiences with transformer coupled gear in the past specifically sources so I figured I'd give it a try.  Neko offers a 30-day money guarantee so I went ahead and ordered one.
It arrived two days later in a relatively small box but it was well padded by what looked like custom foam inserts.  The box also contained the obligatory power cable and a little manual.  Operation is pretty straight forward, it has two inputs (coax and toslink) which you can switch between using the front mounted switch.  The rest of the front panel is pretty sparse, just the Neko Audio logo a power led and a lock led.  Both led's are blue but they aren't blinding like you find on other gear.  The power switch is located on the back along with the aforementioned digital inputs and the XLR's outs.  One complaint about the chassis design, it's basically two parts the bottom and front/back panel and the top and side panels.  Due to the lack of screws on the top panel there is a little bit of a gap that can be seen between the top and back/front panels.
From a functionality standpoint the D100 has always locked onto the signal from the Squeezebox immediately.  It's worked flawlessly in that regard up to this point.
The D100 has a pretty simple layout and design, utilizing a WM8804 for digital input/receiver duties that then feeds a pair of PCM1794A's running in mono mode.  After that it's a passive I/V stage passing the signal off to a pair of Jensen JT-11-EMCF transformers.
First Impressions
During my first listening sessions two things jumped out at me, first is how amazingly transparent the D100 is and second is its tonality.  Far too many dacs in this price range impart their own sound signature or shine a light on one particular aspect.  The benchmark dac-1 is the best example of this, every time I’ve heard it and with every recording the treble always has this glare/etch to it and it drives me nuts.  I don’t want a piece of gear that’s trying to make me focus on a particular aspect of the music, anything that does that is taking away from my enjoyment of the music.  The Neko D100 does it the right way, it doesn’t impart any obvious signature of its own and it does nothing to distract me from the music itself.  I mentioned the D100 tonality as being the 2nd thing that jumped out at me and it did so for this reason, it sounds spot on.  Woodwinds, strings, drums, guitars, flutes, etc all have the correct timbre and tonal balance.
Further Impressions
After about 10 days or so of listening I have a better feel for the Neko D100’s strengths and weaknesses which I’ll be breaking out in further detail below.
Strengths
  • Transparency – further      listening has validated my initial thoughts, this is one remarkably      transparent dac
  • Tonality – same as above,      the more I listen the more I enjoy the tonality of this dac
  • Vocals – vocals are presented      effortlessly and naturally, I really enjoy female vocals with this dac
  • Dynamics – it can be punchy      as hell when needed and quiet as a mouse a second later
  • Imaging – very precise placement      and good spacing between elements
  • Non-fatiguing – can listen      to the D100 four hours on end, no listener fatigue at all
  Weaknesses
  • Softness – at the extreme      ends of the spectrum (low bass/high treble) it is a little soft.
  • Soundstage cohesiveness – some gaps in the width of the stage (could just be the typical 650 soundstage though)
  • Low bass – loses some      definition/punch at the very bottom of the frequency range
  Conclusion
The Neko Audio D100 is a winner, functionally it works flawlessly and sonically it meshes traits found in far more expensive sources with a very pleasing and enjoyable sound.  I’ve had a ton of fun listening to it and as of now have no plans to return it.  It’s a killer value and I’d take it over just about any other dac in the $1-2k price range.
Note
As I get more phones and get a chance to hear it in my speaker rig I'll add to these impressions and change anything as needed.
Posted Image
Headphones: Audeze LCD-2
Sources: Squeezebox
Headphone Amps: Burson HA-160D
Speakers: Selah Audio 3D and 3DCC
#2 boomana
boomana
    jesus gonna ride shotgun
  • Moderators
  • 7,257 posts
Posted 13 May 2009 - 02:02 PM
Very cool.  I know Wes is bringing it to CanJam, and I think with a Luxman P200 amp.  I'll make time to give it a listen.
Headphones:  SR-007BL, HF2, n_maher woodied 225s, JH13
Amps: SP Extreme Platinum/PSU, Headamp KGBH SE, LaRocco PRI, Headamp pico slim
Sources: Exemplar Denon 2900, APL Phillips SACD 1000, ipod classic, Denon DCP-100
Speakers: Cain & Cain Abbys with Bailey sub
#3 strid3r
strid3r
    High Roller
  • High Rollers
  • 237 posts
Posted 13 May 2009 - 02:10 PM
Thanks for the impressions.  Did you listen to any particular kind of music or just a little bit of everything?  The DAC also fits quite well with your avatar.
E-mu 0404 -> γ2 -> PPAv2 -> HF-2/DT531/etc.
#4 tkam
tkam
  • Administrators
  • 3,996 posts
Posted 13 May 2009 - 02:54 PM
Little bit of everything really, my tastes are pretty varied.
Posted Image
Sources: Squeezebox
#5 EdipisReks
EdipisReks
    The Picasso of Creepiness
  • Administrators
  • 34,407 posts
Posted 13 May 2009 - 03:00 PM
sounds promising.
"Science plus beer... equals good!"
--Adam Savage
#6 Hopstretch
Hopstretch
    Dowdy Kitchen ManLiving the Dream, only in africa
  • High Rollers
  • 8,254 posts
Posted 13 May 2009 - 03:11 PM
Glad the product stands up, as Wes's ad strategy also seems quite novel. I've run across the Neko Audio banner on just about every audio site I've visited in the last month or so and it seems like he's betting heavily -- if not exclusively -- on forum participation and exposure to build his brand. It'll be interesting to see how that works out.
"But people like lager!"
"They also enjoy Coldplay and voted the Nazis into power. You can't trust people."
#7 Voltron
Voltron
    HeadFest Organizer - West Coast Legal Team
  • High Rollers
  • 15,651 posts
Posted 13 May 2009 - 03:22 PM
Thanks for taking the time to write up your impressions Todd.  It does sound like a damn good value.  Is the Dynahi a pretty transparent amp?  I don't know how that amp sounds, and it will be interesting to hear your thoughts on the D100 through your speaker amp or any other headamp you have access to.  Also, have you tried the Dynahi with the APL Denon?  I'd be curious to know how it compares even though the price range is different.
On another note, it has been said before but why do these manufacturers keep using the same names for DACs and amps?  Stello, Neko, Channel Islands, Cambridge, Genesis, etc. all have D100s or DA100s and I am sure there are others.
Edited by Voltron, 13 May 2009 - 03:29 PM.
#8 tkam
tkam
  • Administrators
  • 3,996 posts
Posted 13 May 2009 - 03:59 PM
The Dynahi is about as transparent as they come, IMO it and the B22 are the top of the heap when it comes to solid state amps.
Haven't tried the APL Denon in the headphone rig yet but I might do that when I try the Neko out in the speaker rig.
Posted Image
Sources: Squeezebox
#9 NekoAudio
NekoAudio
    Member of the Trade: Neko Audio
  • Manufacturer/MoT
  • 170 posts
Posted 13 May 2009 - 08:48 PM
Thanks for posting your thoughts, tkam, and I'm very glad you're enjoying the D100. :)
Actually my master plan is to inundate you with great reviews until you can't help yourself. ;) With respect to publications, Positive Feedback Online and TONEAudio Magazine have given rave reviews and I have more positive reviews in the pipeline.
The other side is to answer any questions you have about the D100. Thus my forum participation. I also spend a lot of time answering email. I'm a very technical person and so I like people to understand why the D100 is good.
It's because I'm a geek. :p 100 lets me increment numbers like a versioning system and a D in front tells me it's a DAC. I thought about picking names from my cats. How about the Neko Audio Nami?
Wes Miaw, Neko Audio LLC
www.NekoAudio.com
#10 Augsburger
Augsburger
    High Roller
  • High Rollers
  • 5,561 posts
  • LocationOccupy Wallstreet- tent 3A, accross from the Andy Gump
Posted 13 May 2009 - 10:51 PM
Well glad to see that you will be at Can Jam Wes so I can give your DAC a listen. I hope the Luxman P200 is in the ballpark of the P100, if so that should be a really sweet match. Last I recall, you are in room Newport C table 7, the same room as Lavry, Donald North Audio, and Westone, some good company no doubt. I intend to stop by and perhaps a few others will as well.
Have you picked out the source for your system yet?
"Modern man eats knowledge without hunger"  Nietzsche.....or was it  Lucille Ball?
#11 tyrion
tyrion
    Former HeadCaser of the Y
  • Moderators
  • 7,830 posts
Posted 13 May 2009 - 10:52 PM
Nice write up Todd.  I will add this to the list of gear to check out at CanJam.
#12 Iron_Dreamer
Iron_Dreamer
    High Roller
  • High Rollers
  • 1,565 posts
  • Locationon the road again....
Posted 13 May 2009 - 11:42 PM
This DAC was already something I knew I needed to check out, and Todd's review only confirms my initial suspicions.
#13 NekoAudio
NekoAudio
  • Manufacturer/MoT
  • 170 posts
Posted 14 May 2009 - 02:38 AM
I'm bringing my MacBook which will let people listen with a wide variety of songs. I've already confirmed that the optical output doesn't have a noisy signal so that should work fine. I'm also going to have a Denon DVD player with both coaxial and optical outputs for anyone who brings a CD.
www.NekoAudio.com
#14 VPI
VPI
    World's Nicest Spy (Until he decides he needs control of you
  • High Rollers
  • 2,381 posts
Posted 14 May 2009 - 03:08 AM
Great to be able to read your review Todd as this DAC is one that I have been thinking about.
This is is definite CanJam gear list for me as I need a DAC for my Squeezebox Duet and the Benchmark DAC 1 and the Lavry DA10 that I have now are just not doing it for me and Dreadhead's review of the Weiss DAC 2 has me thinking I need to broaden my search as the Weiss was next on my list.
#15 dimitris
dimitris
    Newbie
  • Members
  • PipPip
  • 11 posts
Posted 14 May 2009 - 08:09 AM
Any impressions with speakers for us boxie guys?
#16 grawk
grawk
    Itinerant MiscreantAutocrat
  • Administrators
  • 19,602 posts
  • LocationGlen Rock, PA
Posted 14 May 2009 - 08:10 AM
Did you read his post?
Head-Case Welcome Message - Click Here if You're New!
"oh wow! oh wow! oh wow!" - Steve Jobs last words.
#17 NekoAudio
NekoAudio
  • Manufacturer/MoT
  • 170 posts
Posted 14 May 2009 - 08:18 PM
dimitris, the reviews at PFO and TONEAudio are both with speakers instead of headphones.
A Tale of Two DACs ...the Bel Canto e.One Dac 3 and the Neko Audio D100
The Neko Audio D-100 DAC
There is also a review on the Neko Audio forum D100 vs Transporter DAC--MichaelHiFi also posted a less detailed version on the AV123 Forum but their forum has undergone some changes and I can't find it there anymore.
www.NekoAudio.com
#18 dimitris
dimitris
    Newbie
  • Members
  • PipPip
  • 11 posts
Posted 14 May 2009 - 08:38 PM
Ups! Sorry i didnt notice. Thanks a lot!
#19 HeadphoneAddict
HeadphoneAddict
    Super Secret Ultra Gold Member
  • High Rollers
  • 2,811 posts
Posted 14 May 2009 - 10:12 PM
Sounds like a nice DAC.  It's interesting that the DAC has Jensen output transformers.  As a coincidence I am using a Jensen Transformers "Isomax" box to convert my PS Audio Digital Link III XLR to RCA, for use in my Stax rig (while using the RCA out to feed my dynamic amp at the same time).  I like the quality, and the sound.
If Neko comes out with something like the D200 and adds RCA out and USB input, then I would think about replacing my Apogee mini-DAC with one.  While I like the mini-DAC I think it still may have just a little flavor of it's own vs the DL3.
Feedback: HeadphoneAddict
Hopstretch said:
It puts the cups on the headphones or it gets the hose again.
#20 EdipisReks
EdipisReks
  • Administrators
  • 34,407 posts
Posted 14 May 2009 - 11:08 PM
todd and i have extremely similar tastes, i think the Neko will get some major consideration when it's time to build my "finally-got-a-real-office-now-that-building-renovations-are-done" rig gets started.
--Adam Savage
0 user(s) are reading this topic
0 members, 0 guests, 0 anonymous users
