- Past hour
Happy Birthday, Dan!
- Today
Cheers Dan -- Happy Birthday.
Happy Birthday, Dan!!!
many different versions. a couple of different sizes. i don't pay attention to such things. -
bbest replied to kevin gilmore's topic in Do It Yourself
Kevin thank you for your opinion 👍 What is the latest boards or schema of CFA3, cfp3largeT_1.35? -
Indulging my other hobby today, gonna record leftover salmon
Hope the river is running smooth today! Happy birthday!
you mean this grossly overpriced piece of antique design. unbalanced and lots of feedback. clone boards were available somewhere at diy audio. chassis filled with many audiofool components. like bybee's and fancy caps. if 50 watts into 8 ohms is what you really want then build my pioneer a09 clone. lots better in many ways. i could publish pictures of the zahl boards, or the mass kobo. both of which are also grossly overpriced pieces of garbage. -
So, updates from our little shelter. Since cats are now used to find proper food whenever they're hungry, they are not coming in big numbers when we put food in containers. Also the time for remaking the upper side has come. We'll redo it this summer. Also recently we added a proper sleeping place for hard weathers. We modified an old bed base, isolated it, put some rags and cushions in it. Here are the most recent pics from visitors: We had our doubts if cats wants to use the shelter for sleep but as we can see from "biscuit" marks, they do. And Şanslı (Lucky). She was abandoned (by an ex neighbour, she is neutered), was hanging around our backyard. She was attacked by a dog or dogs. Dog caught her by her lower back. There was clear bite marks. She couldn't use her back legs but after long treatment and thanks to her will, now she is fine. Bad thing is she and Şirin cannot get along. So we made a proper place for her in the building, in front of our enterance. When Şirin is not at home or sleeping, she comes in and hangs out. We named her "Şanslı" cuz, well, she survived a very bad dog attack and recovered well.
Thanks to @MLA for sending me a few FJPF2145s. To avoid turning them into smoke immediately, I’m currently still in the simulation phase. So far, the battery section appears to behave properly, at least in theory🙃 I’ll also try simulating a few alternative devices to see how they compare. From what I’m seeing so far, a Darlington configuration might actually make more sense in this position. More updates once I move from theory to reality.
The recipe I'm currently using and loving is similar, but even simpler. 2 cups self rising flour. I stick butter. I cup buttermilk. The self rising flour needs no added leveners and these biscuits rise quite tall. I use salted butter, because that's what I have. No pastry cutter though. I use a grater and grate the frozen stick of butter directly into the bowl of flour. I loosely distribute the butter and flour with my fingers, then add the buttermilk (I've also made my own with vinegar, but like the texture of buttermilk better). Same as your recipe, I'm careful to just incorporate and not overwork the dough. I'll usually fold it about 3 times after getting all of the flour hydrated by the buttermilk. Finish with the dough about 3/4" thick. And same as you, I use a biscuit cutter without twisting. I have a quite heavy round cake pan, and find they rise better in this 2" tall pan over a sheet pan. I just butter the bottom and sides. The large size biscuit cutter (about 3 1/2" diameter) takes about 18 minutes at 425 degrees. The next size down takes a few minutes less.
You can make cake flour out of AP flour by simply adding some cornstarch.
I use what I think is a very simple recipe, from Melissa Clark (NYT cooking), with slight tweaks based on what I actually have in the kitchen. Ingredients Yield:10 to 12 biscuits 230grams (about 2 cups) all-purpose flour 50grams (about ½ cup) cake flour 15grams (about 1 tablespoon) baking powder 8grams (about 2 teaspoons) sugar 6grams (about 1¼ teaspoon) fine sea salt 9tablespoons unsalted butter, chilled and cubed 1cup buttermilk, chilled I rarely have cake flour so just use 2-1/2C of whatever I have. I rarely have buttermilk so use a substitute of 1T of white vinegar and a scant C of whatever milk is in the fridge. If I am feeling really lazy I'll use salted butter and scale down the salt or sometimes I don't have unsalted butter. The technique is simple, whisk together all the dry ingredients, cut in the butter with a pastry cutter, stir in the buttermilk while try not to over mix. Turn onto a floured surface, roll until ~3/4" thick, and I use a biscuit cutter to cut the rounds making sure not to twist the cutter. Allegedly that seals off the outside and doesn't let them rise properly while baking. I've never had this recipe fail. I'm lazy, so I never brush the tops with butter - which is what 1 of the 9 (heart-attack-inducing) TBS of butter is for. So I usually just use 8 in the dough.
- Yesterday
Hello all! There is interesting amplifier Headtrip 3 level 2 https://www.wellsaudio.com/headtrip . Who heard it, says that it is better then CFA3. How you think - does it make sence to make clone of this amplifier or may be it is already exists? -
