September 15, 201312 yr comment_599273 Since you're riding a 54 too we can compare the supersix vs caad at the next ride Report
September 15, 201312 yr comment_599285 Did 30 today with a new group and hiked 10 yesterday Vicki next week Sunday? Report
September 15, 201312 yr comment_599292 Agreed although he just needs black rings; the arms are fine as is. http://shop.praxis-works.com/50-34-BLACK-2TONE-5034-0004.htm Report
September 15, 201312 yr comment_599298 http://fairwheelbikes.com/kcnc-k3-cobweb-road-chainrings-p-4364.htmlMaybe a black outer and red inner?**BRENT** Report
September 15, 201312 yr comment_599310 im in as long as jeff lets me ride the calfee again if they dont build my bike in time. also i could most likely only do saturday. have a soccer league that starts sunday. games are 9:30 to 12, but schedule isnt out yet. Report
September 15, 201312 yr comment_599311 The Praxis rings are awesome... Just linked the KCNC because it's something else, and figured Jeff would hate them. The Praxis ones would probably be a nice upgrade over the stock ones, maybe save some weight, and definitely look a lot better on the all-black bike. Order some now and you'll be able to sell the FSA ones as new **BRENT** Report
September 15, 201312 yr comment_599312 I'm up for it. Will need to see if the bike will be built up in time. If somehow mine is and yours isn't, Justin, you can ride my caad. Report
September 15, 201312 yr comment_599314 For those who ride at night, CNN has this article for a laser light that is supposed to make a rider more visible. Report
September 15, 201312 yr comment_599315 37 miles with the shop ride. I ate/drank way too much on Saturday but it was still fun. Long way to go to be comfortable in the fast group but I enjoyed it even if I was dropped a few times. Report
September 15, 201312 yr comment_599316 We should make a head case strava group if there is such a thing Report
September 15, 201312 yr comment_599321 At the lake where my mom is camping. Stole 30 minutes or so and went riding around. Ran out of road, so I took a pic.Not pictured, the car I drove to the bridge to take the bike off the rack Justin, hit 33 or 34 coming off this bridge. Still had some room left with my compact/12-25 setup. You'll be fine.**BRENT** Report
September 16, 201312 yr comment_599334 We should make a head case strava group if there is such a thing Done. Sent invites to you, Jeff and Brent. Report
September 16, 201312 yr comment_599337 So we going to do 40 at the lake? I am tentatively in... I would drive down the day of, and head back after the ride. Will confirm or otherwise on or around Thursday. Report
September 16, 201312 yr comment_599341 @Jeff, it was just hanging on the back of someone's car, it looked like it'd fit, so I borrowed it. **BRENT** Report
September 16, 201312 yr comment_599387 I think that is a good choice Justin. I always tend to larger than smaller in frame size for myself, but then I'm a bit old school. i hope it was the right call, i didnt get to try the smaller frame w/ a longer stem. In reading bike forums, i see more people my height going with the smaller frame, but I also notice it seems to be a competition on those boards as to rides the smallest frame for their height or uses the longest stem. Plus most shorter men are adding 1-2" to their height and are so used to the lie that they believe it. I go with 5'8" and i have measured at 5'7 3/4" . So maybe those other 5'8" guys on the 52cm are really more like 5'6". I even found one where a 5'8" guy said he was sized on a 48cm CAAD10 by his LBS. i think i could brake with my elbows on a 48cm. Edited September 16, 201312 yr by justin Report
September 16, 201312 yr comment_599388 I would not worry about it too much. The current pro trends are long seat posts and stems but in your sizes I would stick with what you did. Edited September 16, 201312 yr by Dreadhead Report
September 16, 201312 yr comment_599402 The trend to small frames started in the early '90s (maybe even the '80s). The thought was weight savings of a smaller frame. A foot of seatpost showing, long stems (130-140mm). The larger frame should be more comfortable for long rides. They are also fugly. Those were hideous. And the praxis rings are hideously expensive. Of course I find the newer cranks, particularly shimano, to be hideous looking as well, so you can write that off as you wish. Report
September 16, 201312 yr comment_599403 Chris, Also you can more easily get a lot of handlebar drop on a smaller frame which flattens the back and decreases your drag. I'm not saying that it's justified if you can't put out the power to go with it but that's the thinking as well as weight (which is much less of an issue these days with almost all bikes in the pros being on the UCI limit with weights). Report
