Anything better than HD600...
shellylh
Just for the record, the DT990 was never recommended.  I was recommending the DT880, which is a completely different animal.
Oh, I knew that.  On the previous page Shelly had mentioned the DT990 though.  I just wanted to be the first to unrecommend them.   :)
Edited by acidbasement
  • Like 1
I thought both the DT770 and DT990 both had more of a boosted bass than the DT880 which was supposed to be more neutral.  I know the DT770 has a ridiculous amount of bass but thought the DT990 was like the DT880 but with boosted bass and highs or something like that.  My memory may be lying to me thought (and I've never heard the DT880, only the 990 and 770).  I guess I was into odd numbers back then.
I have to admit, I'm going on memory also, which is long enough ago that it may be failing me as well.  Also, maybe because the DT880 didn't exist at the time, compared to the DT770 it was bright and not bass heavy.  I do agree that I found the DT880 (once it came out) straightforward compared to the bass-heavy DT770 and the (to me) bright DT990.  I guess I think of it like this:
DT770 \
DT880 -
DT990 /
(Bit of an exaggeration, but it's the best I can do with ASCII.  Imagine me standing in front of you with my hand in the air with a slight slant representing bass-heaviness for the DT770, etc.  No, no, I'm not right in front of you, crowding your personal space, I'm standing next to you holding it out in front of both of us.)
Also, I have an old (pre-DT880) DT990, so maybe they were different.  I did have an HD600 at the time, and remember it having more bass than the DT990, but I don't remember what I had at the time.
I have the DT880 '05 which isn't as linear as the DT880 '03.
The DT880 '03 is the better allrounder, but, on some songs the DT880 '05 just "SINGS". That's why I still have it.
The DT880 Pro is one I don't know about, as I haven't heard it, but from what I understand, it's similar the the DT880 '03.
YMMV, as usual.
I like the HD600 more.
Yeh the HD 600's are a bit livelier than the HD650's and for me have a good overall balance for a dynamic.
I like the DT880's as they are a bit more refined and airier at the top end but not so much bass impact. It comes down to personal preference,
The other dynamic I rate against the sennheisers are the ERGO model 2's. very similar sound signature but different presentation, similar to the Jecklin electrostat.
I'm not sure if these get exported to the US or that matter much outside Europe, but if you get the chance certainly worth a listen.
:headcase: on the 600 love  :ian:  Beyers suck. Period. All of them. Period. From the once vintage holy grail DT-48 to the superuberduper T1, one of the biggest overpriced POS I've had the dubious pleasure of listening. However I can understand why some people likes them. Horses for courses.
Edited by Torpedo
Wasn't the DT-48 developed for use out in the field in very poor conditions?
Primarily for monitoring voice and other general sounds for radio and film on portable analogue tape recorders?
They are pretty indestructible, even the diaphragms are aluminium. I don't think they were really intended for high quality monitoring in a studio or music for that matter.
I'm pretty sure they were developed to prove that Beyer could build them.
They are a standard because everyone knows how they work, not because they are good. "Standard items" don't have to be good - they have to be consistent & readily available for comparison.
"In a blind test 99% of participants were able to differentiate the Beyer DT48 from a piece of shit with better than 90% accuracy (20 ABX comparisons). Of the 99% of participants with functional hearing 95% preferred listening to actual dog turd." Is a completely valid statement.
They are used for monitoring voice because that is the only thing they are good for.
My pair arrived DOA, did they have issues with construction that lead to failures?
I think the coating on the diaphragms is the most likely culprit.  Beyer used a simple voltage doubler to generate the bias voltage in the N1000 with the input limited by a 90V transient suppressor.  Same as Stax did but Beyer used 1uf caps for the doubler and they could overload the coating, slowly burning it off.  If the diaphragms are in one piece and the cable shows contact then this is pretty much the only thing that can go wrong.
So what in your opinion would be  "just the right amplification" for the T1's?
The T1's actually sounded great with just the right amplification, but "just the right amplification" required a lot of tweaking. With any other amp, they were pretty blah.
I should note that I agree with the others - the various DT880/990/T1 can sound quite nice with the right amp(s) but it does require a bit of effort to dial everything in.
