stax mafia circuit boards see updated links on page 5
Howdy,
I was looking through the google drive archives for the T2 gerber file corresponding to the original schematics but found different versions. Could someone point to which gerbers correspond to the original schematics from above. Highly appreciated. Thx.
  • Replies 127
  • Views 110.2k
  • kevin gilmore
    kevin gilmore
    I expect to now be able to spend significant amounts of time on new designs
  • kevin gilmore
    kevin gilmore
    try this, there should be over 300 files, had to remove a couple of confidential ones   see updated links on page 5
  • kevin gilmore
    kevin gilmore
    here are the current google share links https://drive.google.com/drive/folders/1r3g2TAtBUaBdiMorTWX7yYgeJ7maQbYW?usp=sharing https://drive.google.com/drive/folders/152thxfZafBmisG0CKCv6X82V-
All the T2 amp boards are a single monolithic slab (except the version I modified). The non shrunk versions are more than 400mm deep and will not fit into most diy chassis like the disapante 400mm. Also they have solder pads for a very expensive and now not easily available volume pot.
Original T2 uses almost completely obsolete transistors which are both very very expensive (if you can even find them) and almost all the sellers e.g. ebay etc are selling fake parts anyway.
t2schem.PDF
So if you have not got the transistors already from known good sources you are looking at probably looking at 10-30+ dollars PER transistor and there are a lot of transistors.... The original T2 amp board was massive... too large to fit into a 400mm deep case! so there was also various attempts to make it smaller:
t2shrunk.zip
Hence the number of different T2 gerber zip files.
I would very roughly guestimate budget $1000 just for the transistors for the amp board. If you make a build error and the magic smoke comes out things can get real expensive real quick. Building an original T2 is going to be fraught with danger and failure unless you can find a reliable source of non fake parts or have them already for a know good source. You also need resistors that can handle the high voltages without the insulation breaking down. Xicon 273 series worked for me and KOA mf1/2 seem ok. PRP appear to fail.
Joamat plus others worked on a version of the T2 which used mostly still in manufacture transistors but still requires 12 obsolete resistors:
staxt2nc3fdh7.zip   t2schemmodified.PDF
shrunk version 398mm deep:
t2shrunk2.zip
shrunk version but with solder points for an alps potentiometer
t2shrinkedv10.zip
This is the version I built. Fortunately I purchased the obsolete transistors from a very well known forum member who purchased them from a known good supplier when they were still available. There is no known version of the full T2 that only uses modern parts....
independent of this there are also three versions of the power supply, (the golden reference power supply series is not suitable because it can't handle the high voltages required for a DIT T2).
Joamat et al created a fully regulated version using the lt10 voltage reference:
   t2250kgsshv.zip   t2hvandlvpsukgsshv2.zip
(the same reference that is in the golden reference LV and HV boards so I went with this). The other designs use a ref102.
 t2schempower-2.PDF t2250.zip  t2hv2.zip
joamat told me the lt10 had lower noise and since I bulk purchased lt10 references I went with his psu boards.
I posted the modified gerbers I made and a circuit diagram for the joamat T2 plus power supplies in this thread a short time ago in the diy t2 thread https://www.head-case.org/forums/topic/6837-the-ultimate-diy-a-stax-srm-t2/page/190/. The modifications to joamats gerbers documented in the post to fit my build style (one pcb per channel, no solder points for a pot etc), a few silk screen error corrections and placed a missing track in one of the psu boards and some more ventilation space for the 3W resistors in the psu boards etc etc.
Edited by jamesmking
I have a reworked board layout of t2hvandlvpsukgsshv2 to a golden reference style T2 power supply.
James, JoeMat, thank you very much. I will be building the original T2 in the black Dr. Gilmore case with the RK50. A valuable forum member was kind enough to provide the bulk of the transistors, some are coming from BDent. Ordered everything else from mouser, custom transformers from mueller-rondo. Some parts already showed up. Will be posting in the T2 thread how everything goes.
  • 4 months later...
If anyone needs Carbon or Dynalo PCB's, I have a few left. All very high quality with 2oZ copper.
Carbon in either SMD version being built by myself or standard TH version "kgsshvcarbon6ground2".
Also SMD version Dynalo with GRLV and kits of PCB's with genuine matched MPSW56/06. I have enough from my own needs to put together a few kits.
https://i.ibb.co/fQ6bxth/IMG-2854.jpg
https://i.ibb.co/r3rdDBf/IMG-2855.jpg
https://i.ibb.co/bRQXk9c/IMG-2856.jpg
https://i.ibb.co/qjRfZWx/IMG-2857.jpg
https://i.ibb.co/wMQTjRm/IMG-2859.jpg
https://i.ibb.co/fYHX3Bg/IMG-2860.jpg
https://i.ibb.co/mBQQQhx/IMG-2861.jpg
https://i.ibb.co/py0v4CW/IMG-2862.jpg
  • 4 months later...
https://drive.google.com/drive/folders/152thxfZafBmisG0CKCv6X82V-Ch9TjMH?usp=sharing
someone please verify that both links are viewable.
fixed document link
  • kevin gilmore changed the title to stax mafia circuit boards see updated links on page 5
52 minutes ago, kevin gilmore said:
Both links are viewable. Not found is the skill for me to do anything with it.
On 10/23/2021 at 9:01 PM, kevin gilmore said:
1. boards - ok
2. documents - has 311 errors:
Quote
You are prohibited from downloading this document.
I’m trying to open Kevin gerber files in a newer version of Proteus and I get this message “Cannot parse all drill tool information from 'NC Drill Setup' section of the tool information (read-me) file.” and “Failed to successfully parse tool information (read-me) file. Gerber view aborted.”. In Proteus 8.5 gerber viewer works just fine.
What might the problem be? Any idea how to solve it are appreciated.
i've noticed that anything after 8.9 will only open gerber files that it created. also has something to do with gerber vs gerber x2. gerber seems to always work. one recent file i sent to jlcpcb as x2 failed with all sorts of errors yet the gerber version of that file was fine and the resulting circuit boards were perfect.
Thanks. So, I better keep my old out of date lap top with 8.5 installed to be able to view gerbers.
No need for old laptop. It seems as 8.5 works along with new version if they are installed in different maps.
@kevin gilmorewould you please upload to the boards folder the latest version of the dynalo smt version gerbers. As I see from older build photos it was .4 from 2016. Thank you in advance.
my latest is kgdynalobal9-cadcam which is version 1.2
i can't find anything with .4 on it
if you are talking about kerry's board, that is not my property and i don't have the gerber files for that.
or supply a link to a picture.
If I can find the most recent files, I will provide them to Kevin to upload.
I’m pretty busy, so it may take some time before I get to it.
I don't know if I'm looking wrong but I can't find a schematic for cfaelectrostatic, besides, there are no gerberas too for this project either. Are they available somewhere?
I may have the boards. PM me if interested.
I don't remember if schematic was ever posted.
i found the synthesis file it is now posted in the documents directory cfaelectrostaticschem.pdf
in the boards share there is cfaelectrostat.zip and electrostat2.zip
there are other surface mount versions that have not been posted
