VPI Posted August 23, 2015 Author Report Share Posted August 23, 2015 Still in the claims process. Will just end up being a re-powdercoat eventually. The curb damage I did on the bottom of my front bumper at Justin's today will be a much larger fix. Quote Link to comment Share on other sites More sharing options...
VPI Posted August 23, 2015 Author Report Share Posted August 23, 2015 Not visible. 1 Quote Link to comment Share on other sites More sharing options...
n_maher Posted August 23, 2015 Report Share Posted August 23, 2015 Nice work Jacob.Bummer Jeff. Quote Link to comment Share on other sites More sharing options...
VPI Posted August 23, 2015 Author Report Share Posted August 23, 2015 Some of the very good Audi turn out.And some othersOne for BrentAnd some for the VW crew. 4 Quote Link to comment Share on other sites More sharing options...
HemiSam Posted August 23, 2015 Report Share Posted August 23, 2015 Welding up 'o' ring grooves ?Yes, Leve. I found the cooper o-ringed gaskets to be too much work...leaked too often in my application. I push a bit of boost through a 406 C.I. motor.HS Those are some great pics, VPI. Particularly like the shot of the Cobra knock-off, aftermarket...whatever they're referred to as these days.HS Quote Link to comment Share on other sites More sharing options...
VPI Posted August 23, 2015 Author Report Share Posted August 23, 2015 (edited) And a very special one right up Brent's alley. Edited August 23, 2015 by VPI 3 Quote Link to comment Share on other sites More sharing options...
swt61 Posted August 23, 2015 Report Share Posted August 23, 2015 Love that Cougar! Quote Link to comment Share on other sites More sharing options...
grawk Posted August 23, 2015 Report Share Posted August 23, 2015 My dad had a cougar when I was a kid. I'll probably own one eventually. Quote Link to comment Share on other sites More sharing options...
VPI Posted August 23, 2015 Author Report Share Posted August 23, 2015 One more to show how screwed up that Subaru was.I would say at least a third of the tire makes no contact. Quote Link to comment Share on other sites More sharing options...
n_maher Posted August 23, 2015 Report Share Posted August 23, 2015 I guess I assumed that it was on bags and that at ride height looked a little/lot different. Quote Link to comment Share on other sites More sharing options...
VPI Posted August 23, 2015 Author Report Share Posted August 23, 2015 Nope. Ride height went up, camber stayed the same. Quote Link to comment Share on other sites More sharing options...
n_maher Posted August 23, 2015 Report Share Posted August 23, 2015 1 Quote Link to comment Share on other sites More sharing options...
HemiSam Posted August 23, 2015 Report Share Posted August 23, 2015 the negative camber hurts to look at.... HS Quote Link to comment Share on other sites More sharing options...
swt61 Posted August 23, 2015 Report Share Posted August 23, 2015 Uhm, what? Quote Link to comment Share on other sites More sharing options...
HemiSam Posted August 23, 2015 Report Share Posted August 23, 2015 Negative camber....A bit of negative camber is great for a road course. That crap hurts to look at.HS Quote Link to comment Share on other sites More sharing options...
Grahame Posted August 30, 2015 Report Share Posted August 30, 2015 While on the way from Carson City to Virginia City I spotted something that caught my interestSo we pulled over to investigate furtherAnd were not not disappointedTurns out it was something that's been going on for 44 yearshttps://www.virginiacityhillclimb.com/?page_id=2So we carried on, and saw it from the other end 8 Quote Link to comment Share on other sites More sharing options...
Grahame Posted September 4, 2015 Report Share Posted September 4, 2015 Aropos of nothing YouTube Suggested this. I found it amusing.more info: https://www.facebook.com/mfingjones Quote Link to comment Share on other sites More sharing options...
luvdunhill Posted September 6, 2015 Report Share Posted September 6, 2015 I bought some stuff from Chemical Guys, got my windows tinted and replaced my rear view mirror, which had floating oil from the auto dimming feature. I also am considering replacing one of my headlight assemblies due to fogging plastic. Can I post here? Quote Link to comment Share on other sites More sharing options...
luvdunhill Posted September 6, 2015 Report Share Posted September 6, 2015 I have a few spots that have paint on them, where likely my wife scrapped up against our garage. Is there a recommended way to remove this? Is this what "clay bar" is all about? Quote Link to comment Share on other sites More sharing options...
guzziguy Posted September 6, 2015 Report Share Posted September 6, 2015 No. Claying is a method to remove very small particles clinging to the finish. To remove paint, etc., try polish or polishing compound, in that order. Quote Link to comment Share on other sites More sharing options...
swt61 Posted September 6, 2015 Report Share Posted September 6, 2015 Believe it or not Marc, I've found the Mr. Clean eraser foam bar very effective at removing the rubbed on paint. You may then need to polish the spot to get the sheen back. Quote Link to comment Share on other sites More sharing options...
bozebuttons Posted September 6, 2015 Report Share Posted September 6, 2015 Try using some gunk Brake cleaner ,or even gas on a rag. Quote Link to comment Share on other sites More sharing options...
guzziguy Posted September 6, 2015 Report Share Posted September 6, 2015 I'm not familiar with the Gunk brake cleaners (there are six different ones here), but most brake cleaners damage paint and other finishes and specifically warn about that on the cans. Quote Link to comment Share on other sites More sharing options...
HemiSam Posted September 6, 2015 Report Share Posted September 6, 2015 What guzziguy said. I use different levels of polishes (more coarse to finner in series depending on nature of issue) from Griot's. I cannot recommend brake cleaner. It may dull your paint and it will fog plastic in my experience.I have a friend that swears by charcoal starter....a petroleum based product, but I have never tried that personally. Just watch to make sure you're not down past the foreign paint and down into some primer native to the vehicle's paint Good luck. HS PS i have had some joy with a microfibre cloth and rubbing alcohol on my boy's vehicle. Quote Link to comment Share on other sites More sharing options...
VPI Posted September 12, 2015 Author Report Share Posted September 12, 2015 Made it back to the US in time for the last Katie's of the season, unfortunately it was kind of rainy, but the lighting was nice. 1 Quote Link to comment Share on other sites More sharing options...
